✏ A little Guide to ... Fairphone's Batteries (FP1 & FP2)
This is a wiki post, please consider improving it by clicking the green pencil symbol on the top right.
Continuing the “A little Guide to…” series after the GPS Guide
According to @ben 's Poll’s result and the number of posts on the forum another thing a lot of Fairphone users struggle with is the battery.
So again I’m gathering all the tips and solutions for battery related problems that can be found on the forum.
If you need a new battery you’ll get one for the FP2 in the shop, for the FP1 you’ll need to check out alternative battery models ( :warning: These batteries might not be tested for safety and could explode!).
If you need a charger check out the community charger list or get a UK charger from the FP shop.
Problems and Solutions
1. First check if your battery is bloated (esp. FP1)
:warning: If you have any problems with your (FP1) battery, check whether it is bloated. (Perform a spin test to make sure) If so, take it out, don’t use it anymore and dispose of it properly. Here is the official support article.
2. Wrong charging status.
Many Fairphone users experience problems where the battery’s charging level quickly drops and/or stays the same on certain levels. Sometimes this is a precursor for a bloating battery and sometimes the battery’s firmware just has to be reset: follow the #dic:kickstart entry for instructions.
3. Phone discharges quickly (and gets hot)
(See discussions: FP1, FP2)
If this happens to you, first try the battery reset from above. If the problem persists, check if it could be:
  • a defect SD card (like described here)
  • a bad connection (like here).
  • an app that causes a “wakelock” (meaning that the CPU is on 100% all the time and does not go to Deep Sleep. You can use the app 'Better battery stats (Play Store) to diagnose the problem. More info on the procedure can be found here.)
  • this Android 5 bug
  • this Android 6 bug
If neither is the case but you still don’t get through the day with a fully charged battery scroll down for some tips to prolong a battery charging cycle (actually read this whole guide as most issues could present themselves as a draining battery).
4. Battery sits loosely in frame (FP2).
If you sometimes have problems charging your FP2 and experience reboots when your phone is slightly “shocked” (eg when you put it down on the table) then your battery likely doesn’t sit well in the frame.
@BeMiGro first suggested fixing this buy putting paper into the gap(s) and here you can see a visual illustration of the workaround.
5. Charging Problems.
If charging doesn’t work well, take your phone out of your case (if you have one), reboot and try a different/better (more expensive) cable/usb slot/adapter/socket.
If your FP2 battery is completely empty and doesn’t charge see the #emptybattery guide.
  • When charging is a problem, try charging with a datacable. Cheap charging cables have 2 wires, whilst data cables have 4 wires.
  • Use cables with a large wire gauge. OEM cables of large smartphones usually fall in this category. Thinner cables have been confirmed to cause charging misbehavior.
  • If moving/wobbling/touching the cable during charging interrupts the charging process (charging animation toggles between on/off)
    a) check if your USB-Port/Connector of your FP is dirty and clean it carefully with a screw driver
    b) check if the whole USB-Port became loosen, which could indicate a broken soldering point at the motherboard
  • General information for using the original FP1(U) charger (1A, 5V)
    a) While correct charging with the original FP charger it should consume 5.5 Watts while showing the charging animation (check with external power meter)
    b) BUT: the charging animation is also running, when the charger only consumes 2 or even 0.4 Watts or less (e.g. due to bad electrical contacts)
    c) thus be aware, that charging overnight not necessarily mean a full battery, if you are suffering form contact problems like this!
  • Try setting USB debugging to “on” in the “Developer options” screen if charging behavior becomes erratic (problem observed on a FP2 with FP open). Cycling through the different USB connection options in the “Developer options” screen also appears to stabilize charging behavior.
6. Overheat Warning.
Some FP1 users experience paradox warnings that their battery is overheated at temperatures around 0°C. If your battery isn’t actually hot, you can simply ignore the message, but keep in mind that a cold battery will be used faster, also, try to re-heat a bit your battery before charging (simply let the phone go back to a “normal” temperature before plugging it).
Maintenance Tips
  • According to this article as shared by @drcyber it’s best to keep charging levels between 40% and 80% whenever possible (albeit without explaining why). Full charges from 0% to 100% are supposedly not good for your battery.
    The app Battery Charge Limit can help with that.
  • Don’t store your phone fully discharged for a long time.
  • Try to keep your phone/battery away from extreme temperatures and rapid temperature changes.
  • More tips can be found on Fairphone’s Support Article.
  • Just for comparison reasons: The original FP1(U) Battery with 2000 mAh should take 2 hours to completely load (0%–>100%) if a charger with 1 Ampere is used (e.g. the original FP charger, it should consume ~5.5 Watts)
How to prolong a single charging cycle
If you plan on spending a prolonged weekend in the wild without having access to electricity to charge your phone these tips might help:
  • Turn the screen background down. A great way to do so on FP1 is by using the Gravity Box Module, which quickly lets you change the background light by sliding over the top of the screen, on FP2 the brightness slider is found in the notification panel anyway.
  • Turn off all connections you don’t need (wifi, 3g, bluetooth, …)
  • According to @BroX the App Greenify helps saving battery.
  • FP2 has a battery saving function (Settings > Battery > More Options (three dots))
  • For more tips check the FP2 battery saving challenge as well as this, and this topic and the official blog post here.
Wrong Myths
  • Darker backgrounds use up less battery. (@ben corrected my mistake here)
  • Keeping a fully charged phone plugged in can damage your battery. (See discussion here)
Some numbers
Power consumption during charging (phone power off, measured with a power meter):
FP1: P=5.5W => 1,1 A if 5V is provided => calculation: 1h50m for a full charge (2000 mAh), ~2h in reality!
FP2: P=7.7W => 1,54 A if 5V is provided => calculation: 1h36m for a full charge (2450 mAh), if linearity is assumed
If we multiply with 80% efficiency of charger/FP-electronic we end up at FP1=0,9A and FP2=1,2A.
Tested with original FP1-charger and cable, which is designed for 1A@5V (=5W)
FP2 Battery health and duration?
Battery switching from chargin to not charging every second
Battery problems (wrong charging status / battery might be dying)
:de: Fairphone FP1 startet nicht mehr
List of most popular questions in this forum
Fairphone gets very Hot and Battery drains quickly
Charging stuck at 98%
FP turns off without notice
Urgent- my FP refuses to charge battery!
Charging does not work properly
I bought and Fairphone and since then ......AAAAAAAAARRRRGH
Charging but not charging
:de: Akku Probleme mit Fairphone 3
FP2 not charging
FP1U Battery charging: very slow / not working at all
Phone is now complete dead - can't switch on
:fr: Ma batterie ne se charge plus!
FP2 completely dead (no red LED, reset/battery removing doesn't work)
Battery does not charge over 28%
Deep uncharged fp2 stays in slowcharge, turning on and off constantly
Strange battery behaviour
FP2 Battery Problems (drains quickly, CPU gets hot) - See batteryguide for workarounds
:pencil2: A Little Guide to ... Troubleshooting Your Fairphone (any model)
FP2 shuts itself down with full battery
Erratic Cellular Network Behavior (FP1U)
Welcome! Introduce yourself here!
Battery charging is not working properly
Reduced battery lifetime after update to kola nut 1.8.5. and display exchange
Battery bloated
Buttons pressed randomly
After update battery problem
My phone has decided it doesn't like being charged
FP1 slowing down significantly
Fairphone won't turn on (clear eMMC)
Phone's serious's problem!
Battery drop from 50% to 15% every time
FP2 Won't turn on or charge - See first post for troubleshooting
:fr: Batterie fairphone 2 se décharge hyper rapidement
:de: Problem mit Akku Laden
:de: Die batterie wird sehr rasch wieder leer
FP1 completely unresponsive
Wifi drains battery after Marshmallow Upgrade - See first post
FP2 won't turn on - stuck in restart loop
FP3 Battery Life Experiences
Multiple problems lately
Phone off with black screen, red LED (not blinking), getting hot (after physical impact)
FP2: Fairphone Open 19.08.1 release
No sign of life after LineageOS+microg upgrade attempt
[SOLD] Verkaufe Fairphone 2 (weiß/blau/transparentes Cover) DE - (English description below)
Charging the FP2 / cable problems
Frozen FP2 can't reboot
I can't use my fairphone 2 anymore (crazy touchscreen, reboots…)
Fairphone 2 does not boot any more - battery broken?
File transfer from Mac
FP2 in The infinitive reboot Heaven
FP2 GPU gets too hot
Battery drain after battery reset and other measures
Bought a new battery for FP1 but it fails regularly
Battery life on new FP2
Fast draining battery, can't run ADB to make BetterBatteryStats work
Help needed - FP2 went hot and does not light up any more
Support request not answered after over 3 weeks
:de: Akku verliert viel Strom im Ruhezustand
FP don't turn on ! I'm Hopeless
:de: :gb: Lebensdauer des neuen Akkus/ Lifespan of the new battery
OpenOS showing Google and Play Store apps
FP2 lässt sich nicht mehr einschalten
Random Battery charge level
Battery fault, turns on and off and doesn't change for 50% charge
Battery problem, and no answer from fiarphone support for weeks now!
Unresponsiveness, spontaneous rebooting, long reboots, gaps in battery usage history
My FP2 died yesterday and now it won't turn on; it only shows a red light LED
Phone keeps rebooting on its own
Possible virus in phone
Too many Battery problems / FP1 very first batch
Battery low+hot
:gb: :de: Water (drops) damaged Volume up button / Stuck in recovery/fastboot
Battery charging issue ? Phone not turning on anymore
FP1U not charging while switched on
Battery and charging time
Can I use pc charger?
:fr: Fairphone en Français
We need a real wiki-Site
First impressions Fairphone 2
Phone won't charge until after reboot
Should I buy Fairphone 2?
Extensive issues w/FP1U - I just want it to function reliably
LED lighten if power is on without battery inside?
Voice Transmission Problem
FP1 doesn't start anymore
Fairphone 4 running /e/OS won't turn on
FP2 is dead, solid red notification LED for some minutes
Battery only charges when fairphone is turned off
FP1 charging - 17-19% constantly
Fairphone 2 won't charge
