✏ A little guide to... using SD cards
Android 6 introduced new options for using an SD card in your phone. When you format an SD card or insert a new SD card, you’ll have two options: Internal/phone/adopted storage or external/portable storage. The option that most closely matches older Android versions is the external option.
There are a couple of things to take into account when choosing which option works best for you:
TL;DR: Formatting as internal will allow you to store apps on it and have it encrypted with the system internal storage, whereas formatting as external allows you to have data you can take out of your phone and back in. But formatting it as internal may cause numerous issues with basic features of the phone (camera, storage, audio players, …) and is highly advised against.
  • Formatting as internal storage (:warning: see warning below about such :warning:) means that…
    • your SD card and the internal phone storage will no longer be visible as separate areas in file managers on the phone and in file managers on your computer when you connect it via e.g. MTP and will be considered as a single storage.
    • you have to make a choice where you want your user data (pictures, music, videos, PDFs etc.) to be stored: Internal storage or SD card. This will become the only storage location which is accessible when connecting your phone to a PC. You can move all your data from the phone to the SD card (and back) at any time - as long as there is enough free storage.
    • it may decrease the performance of the phone, as reading/writing the SD-card is slower than the internal storage. If apps are stored on the SD-card this can make them significantly slower.
    • the maximum file size is only limited by the size of the SD card.
    • Android controls where newly installed apps are stored. After installation, many (but not all) apps can be moved from the internal storage to the SD card and vice versa by the user.
    • to remove the SD card, you need to move all your data (user data and apps) back into internal memory first. If the card is removed without going through this process, there will be problems using the phone normally. If you have more data than fits in internal memory, you’ll need to remove data until it does.
    • any data stored on the SD card is encrypted, as it potentially contains sensitive data (app logins etc.). The key used for the encryption is stored in the device. :warning: Factory resetting your phone deletes the key and renders any data on the SD card unreadable (provided nobody finds a practical way of cracking 128bit encryption).
    • :warning: if ever the card or the phone breaks/dies, the data on the other device might be irremediably lost, and for the phone the internal storage broken (which means you may need to do a dic:hardreset or a reinstallation from scratch) while formatting as external storage allows to access the data independently from the other part
:warning: Formatting the SD card as internal storage on the FP2 (since A10 upgrade), FP3 (since A10 upgrade) and FP4 is confirmed to cause functional and significant storage issues (data loss, empty SD-card, camera unable to shoot photos, etc) often requiring a factory reset. Forum topics here for FP2 (among others), here for FP3 and here for FP4.
If you experience issues after formatting as internal storage, please contactsupport to report bug and remember to avoid formatting as internal storage whatever your phone model is!
  • Formatting as external storage means that…
    • the SD card will show as a separate folder in your phone.
    • there will be an eject icon to the right of the SD card
    • the SD card can be taken out to be used in other devices, e.g for file transfer
    • data on the SD card is not encrypted, and can be read by anyone who has physical access to the SD card (e.g. when your phone is lost or stolen).
    • the maximum file size is 4 GB, which can be an issue if you want to store movies on the SD card (except if you format it yourself in another format such as exFAT)
    • you can not move apps to the SD card. All apps will be stored in the phone’s internal storage.
    • Android limits the access that apps have to the SD card (as a security feature). Despite these changes having been announced quite a while ago, not all apps have been updated to make use of the new system for requesting access to the SD card. In addition, some apps do not support changing the location for storing data at all (e.g. the pre-installed camera app - alternatives are available). For some other apps, enabling the use of the ‘Storage Access Framework’ will allow access to the SD card (NB: Storage Access Framework is deprecated as of android 11). Apps may still be limited to a folder on the SD card that is created by Android for use by the app - Android/data/app.package.name
How to reformat your SD-card
Open the files app, go in the root location of your SD-card, tap the three dots menu and tap on format.
Phones and SD cards break. Remember to regularly back up your data (to an external device!). Loss of data due to faulty SD-cards is common.
Lists of recommended/compatible SD cards can be found here:
:pencil2: List of compatible micro SD / SDXC cards for FP3
:pencil2: List of compatible micro SD / SDXC cards for FP4
SD Disk is nowhere to be seen - as if it doesn't exist
How does the fairphone 2 manage data if an SD card is declared as internal storage?
SD card full, lots of space on phone but can't use
SD card Format Lineage OS / Android Stock ROM
Troubles and doubts about future using my FP2
FP3 - SD Card as internal storage - Data Lost
SD card accidentally formatted as internal, how to get apps "unmigrated"
"SD-Karte wird von diesem Gerät nicht unterstützt" :de: :uk:
Lots of issues I've been dealing with for a long while now. Wanna know how to fix them
SD Card formatting on Android 11
New micro SD - move files wizard - all pictures/videos are gone - camera malfunction
Fairphone doesn't recognize SD card
Camera does not work after transferring pictures to SD card, nor does downloading picutures
microSD-Card encryption
Store my pictures on a sd card
Checking out Fairphone 5 before I buy
:de: Kalender löscht alle Einträge - wiederholt
Cameras and flashlight stopped working
App issues after update
:de: SD karte von samsung fehlt, Gerät wieder einlegen
Fairphone kept turning off after a few seconds, now doesnt turn on at all
Fairphone3 pushing out Nano SIM cards
Cannot phone/message my SIM-imported contacts
Bug with Instagram
:pencil2: FP3 Customisation and User options
:fr: FP3 mise à jour android 13 : bloquée sur la finalisation de la mise à jour système
Cannot get phone to accept SD card
Micro sd not reconized, impossible to find photos
My phone restarts by itself
Should I get a Fairphone 3 or 3+?
FP3+ apps crashing
App does not really install again (reinstallation leads to app shutdown)
System hangs on receiving calls from apps using /e/OS
Android 10 - MicroSD as phone storage
FP3+ randomly crashes
Alarm with the phone off
Help with apps and storage
Can't download Telegram Images
Which apps support SD card storage?
Fairphone 3: Micro SD-Card 128 GB - Pics from my cam not accessible, whatsapp pics not downloadable
How to improve reduced speed of operation
FP3 SD using it to store music
:gb: :fr: Way too sensitive
:fr: Arborescence de mon appareil
Graphi UI App not responding
Trouble accessing (read/write) external SD card on Fairphone 3 running /e/ OS
Kia ora, are there any Fairphone users from Aotearoa, New Zealand here?
Camera not working after inserting SD card
Camera app problems
Display and/or battery issue - phone won't fully boot
Apps not working properly on Fairphone 3
Help I can't transfer my photos to my laptop
:fr: Magnetophone app ne fonctionne pas
Some SD card-stored apps not updating
Impossible to save images on my Fairphone 3
Play Books crash
'Out of space' warning when plenty of space available
Camera says SD card full
"Sounds keeps stopping" message; can't change Ringtone or other Notification sounds
Video; audio and visual out of sync
A10 - SD card phone storage issue
Problem deleting photos/videos/files from internal storage
I'm looking for a fairphone
Phone not connecting incoming or outgoing calls
Phone keeps restarting itself after charging in Uganda
Youtube stutters in full screen mode
:de: Interner Speicher und SD Memory Card nicht auslesbar/beschreibbar
Extremely slow USB connection
FP4 only in Camouflage-Green Military Look?
Speakers and Microphone not working
Microphone doesn't work in some apps (FP3)
Not enough storage to install Twitter?
Display artefacts and occasional freezes
Slow camera experience
New SD Card issues
Taking screenshot in this app is not allowed
Update destruction
Difficulty getting FP2 to boot
:fr: Arrêt aléatoire du fp3
Fairphone folder empty when connecting via USB
Fairphone 4 - What is wrong with this thing?
Software Update: 3.A.0134.20211116
Fairphone 3 plus sound, calls, microphone not working
:fr: Photos bloquées dans le fairphone 2
DCIM directory on SDcard got empty and blocked after integration process
Multiple problems - very slow phone crashes frequently
:de: FP2 - Interner gemeinsamer Speicher fast voll - wie bekomme ich wieder mehr Speicherplatz?
LineageOS on FP3+ is disappointing, is /e/ any better ? Should I go back to Google?
FP4 - usb-c sd card reader
Android 11 lags and bugs on FP3
:fr: FP3 sous A11 ; installation carte SD : perte données whatsapp - téléchargement ne marche plus
Can't save Screenshot on FP3 with SDCard as internal
White noise with wired headphone
My whatsapp pictures are gone without backup
My FP3+ keeps trying to reboot
Lost mobile connection after A.0016.6 update
:fr: Fairphone 3 ne démarre plus et ne charge plus
:fr: Application se ferme au démarrage
FP3+ Screen colour split down the centre
FP3: Pixel camera app / Google Camera Port
Back to home screen whenever the screen goes off
TWRP for Fairphone 3
FP3 DB Navigator App
Official LineageOS 20 for FP3/FP3+
Forgot pattern password on Fairphone 4
:fr: Installation carte SD et perte photos du téléphone. HELP
NFC crashes FP3 badly when active and any NFC chip present for a few seconds, reboot fails
FP3+: Issues with Android 13 update
Ghost inputs on FP4
Android system update won't finish
:pencil2: List of compatible micro SD / SDXC cards for FP5
FP3+: SIM not recognised after reboot during finalisation of Android 13 update
:us: Fairphone owners in the USA
Foto app closes
Storage on SD card
My 1+ year review of Fairphone 3
How to listen to music from SD card?
Should I keep my Fairphone 3+ or get a Fairphone 5?
🇫🇷 Problème utilisation Carte SD
:fr: Fairphoneurs sur PARIS
Signal app crashing on fairphone 3
Corrupted SD and lost data (after transfer)
🇫🇷 Problème de mémoire
🇨🇵 stockage Google vs stockage interne ? Fichier?
Bugs after system update. Camera won't start, photos have disappeared
Fairphone 4 eOS: problems with pre-installed Fotogalerie
All unsaved data lost after waking phone up..Settings?
1.5tb card in FP5 - Issues
Customize home screen
Storage reporting wrong values for SD card formatted as internal
Mini SD card for Fairphone 6
Camera won't take photos due to lack of space
:de: Zwei Probleme, Ladefunktion & Hintergrundbild
File management Fairphone 4 problematic
Can I swap the SD card for a bigger one?
SD card not working suddenly
Some apps don't see the SD card
Switch to open source Operating System
FP5 Camera stops working (as soon as it is >25°C outside?)
Using SD card for expanding internal storage. Now cannot use camera anymore
Data on SD card not readable/card not recognized after few days or restart
Cannot read data from SD card formatted as internal storage anymore
Booting gets stuck - maybe full storage
Fairphone 5 Low FPS in games
Reversing use of SD card as internal memory to external#FP3
Very low speaker volume
Fp4 android says low storage space when lots of the storage is free
Authentication problem wifi
FP3 connectivity issues
FP3 some apps repeatedly crash
Weird behavior with memory space
Fairphone 3 Camera issue
Camera is not storing pictures after ugrade to Android 10
Fairphone novelty (novelties?) to come on 30 September 2021
Problems with my new fairphone 3+
How can I perform a file system check
Problem with my FP3 and bigger problem with support
Unable to add songs on playlists
Fairphone 3 slowing down
Problems transferring apps to remove internally configured sd card
