Good to see that you could solve it. Chris’ and our build could potentially be close enough to not have to factory reset. However, wiping Dalvik cache is probably always necessary.
Did everyone here come from Chris’ build? Or are there also some people that updated from Kola Nut 1.8.7? In general this is the more important case to test, because most of our users will take that path.
Yes, this solves many problems (although Dalvik Cache is on the data partition which means that you don’t need to wipe Dalvik Cache if you factory reset).
But please don’t all factory reset before flashing: Most people will want to update from Kola Nut without loosing any data. Therefore it would be great if these scenarios are also covered by our tests.
Yes, I can verify that. I will look into it.
Ohoh, that needs to be fixed. Probably it’s too much work and doesn’t make sense to list each and every non-translated string. But, is there a pattern to it? What parts are in English and what parts are in French?
Yes, it is the very same launcher.
Great to hear.
Thanks a lot everyone. Keep up the good work!
