I came from Kola Nut, without using the factory reset. Everything seemed fine till I tried to update google apps and I got stuck on the Setup Wizard error. After that I installed CWM and installed opengapps. I have not lost any data during all this.
May I ask which package of opengapps you installed? did you have any problems with the keyboard?
I used the aroma one. I did not install the google keyboard during aroma selection process. I did try installing it from google play afterwards, but am getting an error. Was considering rerunning the aroma installer to try and install it from there (I miss the key swiping).
The error I get is:
Package file was not signed correctly. Uninstall the previous copy of the app and try again.
I guess the previous version might be left overs from the Kola Nut version, but I donāt see any method to remove the leftovers.
But can you use the keybord? or you get an error message?
You could try Swiftkey keyboard⦠itās great!
I have no issues using any of my keyboards (Android AOSP keyboard or hackerās keyboard)
Just installed over the port of CRMHoffmann.
Easy doing:
adb reboot recovery
clear cache, clear dalvik.
adb sideload (downloaded rom)
adb sideload (opengapps nano)
adb reboot
Happily seeing the new rom.
Even XPosed is installable again.
Desktop image stayed, launcher configuration naturally not.
NetApp SDFix still necessary in order to make osmand work.
Iāll be sharing issues WHEN they arise.
Up to now, it looks quite good.
YES!!! This is so great! it was so easy to install I couldnāt believe it!!!
Iām using XPosed also and now the NextApp SDfix (for those searching it as itās not on F-Droid).
On 4.2.2 it is not necessary to use it as it was a decision made for kitkat. But would it be possible for you guys to integrate it or better, add a setting / installer like thingy - as it was reasoned to be a security feature - to enable it without external apps? Iām using it for osmand and syncthing (Music library as itās to big for the internal space and i want it in sync on my devices against hardwarecrashes).
Does someone know how newer Androidversions like 5.x oder 6.x (soon 7.x) handle it?
I came von Kola Nut 1.8.7
Hi everyone!
I installed the update this morning. These are my experiences so far:
- update process from Kola Nut worked like a charm. I didnt wipe any caches or did a factory reset.
- I can confirm the 1-pixel line on the bootscreen. In my case there was a line on the left and also one on the top.
- There are random google play service errors. So far they seem not to interfere with any function or app.
- Play store doesnāt work
I also updated from the unofficial rom without any issues beside of the translation things. (Installed it via sideloading with CWM. Also used the nano package of gapps.)
Just to be curious, beside of the fact that it is Android version 4.4.2, which security patch level is applied? Is this rom at the head of the current security updates provided from google?
I donāt know which security updates are included (I donāt find the information in the settings where the were in the unofficial port), but i just saw that the fairphone build is using Android 4.4.2 (Settings->About phone) but the unofficial used 4.4.4 (with modifications).
Will this be bumped too?
None yet.
Yes, thatās the plan: Update to 4.4.4 and include all security updates.
Weāre currently not taking any feature requests because our focus is on stabilizing the build and include security fixes. Sorry for now.
Installed over 4.4.4 port by @chrmhoffmann (so itās a⦠downgrade ;)) + last open gapps mini package. I just wiped cache and dalvik cache. Also installed NextApp SDfix.
Everything OK till now including:
- Gmail working with many accounts including a Microsoft Exchange one
- PlayStore working
- Minuum keyboard working
- Dual SIM working
Minor points:
- Blank one pixel vertical line on left side of the first splash screen
- Light background on first init screens: text not much visible + battery consumption
I use English as system language: no problem on this side.
Can you please elaborate on these issues? What init screens do you mean? The ones from the GApps package? The bootanimation?
And what can you say about battery consumption?
Edit: And of course also thanks for testing the other stuff and confirming that it works ![]()
24 posts were split to a new topic: Battery level drops in FP1(U) alpha
There is a first splash screen with āFAIRPHONE powered by androidā. Then a boot animation which starts with two quick screens ~āStart a movementā, then a screen with āLOADINGā blinking. This last one has a light grey then grey background which lasts more than 10 seconds: very flashy under nightly conditions and this display burns battery uselessly, and the text āLOADINGā is white: not so much readable on grey background.
Battery: at this time Android System got the first place with 25% since yesterday evening. I will check again by the end of the day.
I have an issue with the google app - it crashes shortly after open it. Hereās the relevant logcat:
LogCat
I/dalvikvm(19370): Could not find method android.os.UserManager.getUserProfiles, referenced from method com.google.android.apps.gsa.shared.util.cc.bh
W/dalvikvm(19370): VFY: unable to resolve virtual method 2492: Landroid/os/UserManager;.getUserProfiles ()Ljava/util/List;
D/dalvikvm(19370): VFY: replacing opcode 0x6e at 0x001c
D/dalvikvm(19389): threadid=10: interp stack at 0x5fe3e000
D/dalvikvm(19389): init ref table
D/dalvikvm(19389): init mutex
D/ActivityManager( 692): getContentProviderImpl: from callerandroid.app.ApplicationThreadProxy@42ff5f30 (pid=19370) to get content provider com.google.android.voicesearch
V/ActivityManager( 692): getContentProviderImpl: can't get cpi from packagemanager
E/ActivityThread(19370): Failed to find provider info for com.google.android.voicesearch
D/ActivityManager( 692): getContentProviderImpl: from callerandroid.app.ApplicationThreadProxy@42ff69b0 (pid=19370) to get content provider com.google.android.gsf.gservices
W/ActivityManager( 692): Permission Denial: opening provider com.google.android.gsf.gservices.GservicesProvider from ProcessRecord{42a78408 19370:com.google.android.googlequicksearchbox:search/u0a17} (pid=19370, uid=10017) requires com.google.android.providers.gsf.permission.READ_GSERVICES or com.google.android.providers.gsf.permission.WRITE_GSERVICES
W/System.err( 692): java.lang.SecurityException: Permission Denial: opening provider com.google.android.gsf.gservices.GservicesProvider from ProcessRecord{42a78408 19370:com.google.android.googlequicksearchbox:search/u0a17} (pid=19370, uid=10017) requires com.google.android.providers.gsf.permission.READ_GSERVICES or com.google.android.providers.gsf.permission.WRITE_GSERVICES
W/System.err( 692): at com.android.server.am.ActivityManagerService.getContentProviderImpl(ActivityManagerService.java:8317)
W/System.err( 692): at com.android.server.am.ActivityManagerService.getContentProvider(ActivityManagerService.java:8590)
W/System.err( 692): at android.app.ActivityManagerNative.onTransact(ActivityManagerNative.java:705)
W/System.err( 692): at com.android.server.am.ActivityManagerService.onTransact(ActivityManagerService.java:2265)
W/System.err( 692): at android.os.Binder.execTransact(Binder.java:404)
W/System.err( 692): at de.robv.android.xposed.XposedBridge.invokeOriginalMethodNative(Native Method)
W/System.err( 692): at de.robv.android.xposed.XposedBridge.handleHookedMethod(XposedBridge.java:631)
W/System.err( 692): at android.os.Binder.execTransact(Native Method)
W/System.err( 692): at dalvik.system.NativeStart.run(Native Method)
E/AndroidRuntime(19370): FATAL EXCEPTION: main
Unfortunately for the moment I wonāt look into Google Apps issues yet since we donāt give support for OpenGApps. We can only support installations of GApps through our updater (which is not there yet, sorry).
Additionally, your issue seems to stem from having Xposed installed. Have you tried wiping Dalvik Cache?
