Is there a fairphone package of gapps to bypass the installer and install it via cwm?
Yes. This was the first thing.
Hi All,
I’m about to update, I’m happy to do an in place upgrade without wipe to see how this goes.
Quick question, if I do an in place upgrade will I keep my existing google apps? Or will I lose access to them until the google apps installer is made available?
Steve
Not yet.
No.
Yes. Although, some people have had limited success in using different recoveries to install OpenGapps (see above). This is not supported by Fairphone though
Thanks Jftr,
That’s a bit of a blow, perhaps it’s worth holding out for the official gapps package.
I managed to install OpenGapps without much trouble. In fact I installed the mini package and downloaded what I needed from the Play store.
So, for the time being this may be a solution while waiting for “supported” installation to work.
TL;DR: Reinstalling google app fixes the issue.
In fact I resolved the issue with the google app by uninstalling it via the play store. Then after I started the google app, provided by the installed gapps package (which were not uninstalled because it is a system app), it told me that a newer Google App package is available at the play store. I installed it and it works. Maybe the installed version of the google app was 4.4.4 compatible, but not for 4.4.2.
Updated my FP1 (not FP1U) through the fairphone updater. Works fine so far.
Several crashes from google apps and apps from the playstore. Installing CWM recovery and opengapps micro package (and wiping cache and dalvik cache) from there helped to get at least the playstore back.
Some apps kept crashing. Re-installing crashing apps from the playstore seem to fix this for me.
Language issues cannot be verified, english locale seems okay
The issue with the white lines during boot appears for me as well, see photo below.
first results are pretty good.
As said, opengapps nano work, appStore works, just installed some updates including DAVDroid and öffi.
GPS seems to work ok, never had such a short fix time with any official FP release (this has been true for the inofficial release as well).
Phone works,
k9mail works
Firefox works.
Battery usage is normal, but I am not representative here because of low utilization of my phone.
Did anybody use encryption? This would be my next thing; didn’t do it on inofficial because I had to reinstall from scratch once.
Are there any topics that should be tested intensively?
Good to hear that it works for you.
I think I’ve found the issue with the white line and will include it with the next test release.
Good to hear.
That sounds great.
No, nothing in particular, just all normal usage scenarios that any user could think of
If at least these following are covered, would be great:
I’m probably forgetting lots of stuff. That’s also one of the reasons why we really appreciate everyone’s help: We could never think of all the ways you use your beloved Fairphone
→ Strange, that looks like my FP2.
https://forum.fairphone.com/t/white-line-on-left-and-top-side-of-bootscreen/18602
Actually the problem is not really a problem: The boot logo is an image the size of the screen. That image has a small border with a slightly different color which looks very bright). That means: This is not really an issue and can easily be fixed. Maybe we also change it for FP2.
Is it possible to install it as an update on the Kitkat from chrmhoffmann?
Several people did that already - so yes.
Got the G letter on the status bar for my second SIM card although it’s mobile data is not activated on this card.
Re: SDCard: Yes, that’s a policy change in 4.4. further up in this thread, there is a link to the netApp utility that fixes the permission issue.
I can not connect to the wifi network at work anymore, which uses a PEAP authentication method.
Thanks for reporting. It’s noted, we will investigate.
Is anyone able to confirm this already? Maybe anyone is using eduroam?
All works fine!
I will try Eduroam tomorrow!
Like in the build from chrmhoffmann it is not possible to enter the phone number in Settings->Sim management for Sim 1, only for Sim 2 it is possible. Well not important!
The new launcher is much better! But I use the nova launcher prime…
Why is this “only” 4.4.2?
And what is the difference to 4.4.4?
