Wakelocks in Android (FP1(U)/rooted FP2)
Continuing the discussion.
Hi everybody,
as adviced in other parts of the forum, I’ve installed “BetterBatteryStats” to monitor the battery usage. Edit2: BetterBatteryStats is still available from the F-Droid Archive repository, while upstream has become unfree.
Like @YtvwlD I had experienced a shorter lifetime of my (second, half a year old) battery.
This is the result of only two hours:
My CPU also was on the maximum of 1.21 GHz almost all the time.
Can somebody explain the screenshot to me, especially what the wakelocks mean, and if they are responsible for a shorter lifetime. If yes, recommendations on how to get rid of them, would be very much appreciated! :slight_smile:
Cheers Stefan
PS: I’m using @chrmhoffmann’s KitKat Version 0.9.4 on a FP1.
Edit1
I think I found the culprit (and I think ps means poll service):
I have restricted some permissions from Telegram using XPrivacy. I will see if I can solve the problem by allowing some permissions. Does anyone know, which permission it could be?
So this isn’t just me ging outside playing Ingress - it’s Telegram. :3
Which Version of Telegram do you have? The one from F-Droid or the one from the Play Store? I’ve got the one from the Play Store.
One possible solution would be to use the one from the Play Store. It uses Google Cloud Messaging to deliver your incoming messages. This has the benefit of less battery drain. But all your messages go through Google (I think).
In general, I’ve found Intel’s power top helpful for desktop systems. But it’s also available for Android.
Edit: If you have the Telegram from F-Droid, restricting Wake Locks might save your battery - but you might miss incoming messages.
I’m using Telegram 3.6.1 from F-Droid. I don’t have GApps installed, so GCM is not an option for me.
I have found a setting called “Smart Push” and according to this post on Telegram-FOSS’ Github, Telegram produces less wakeups if this setting is disabled.
Another user verified here that “Wakelocks went down to 54 in 10h with 1 min waketime instead of 3 hours and 5400 wakelocks.”
I’ll try this and report back.
PS: The option can be found here: Menu > Settings > Messages and Sounds > Smart Push
I’m using Telegram 3.7.0 from F-Droid. I have microg installed, so GCM would be an option, but I don’t want to.
I’ve disabled “Smart Push”, too. Let’s see what happens.
I’m willing to run BBStats 2.2.0.0B6 on my FP1. I do not use the services you use. I also use microg. What info do you need to compare?
I think there might be another problem than Telegram. Despite of Telegram’s wakeups (1) and wakelock time (2) going down, my FP1 is still all the time awake (3) and on maximum CPU frequency (4) most of the time.
(1)
(2)
(3)
(4)
@fp1_wo_sw_updates Thanks for the offer. I’m running BBS 1.15.0.0 from F-Droid. No microG gmscore (only unifiedNLP). Do you also experience reduced battery lifetime on @chrmhoffmann’s Android KitKat?
@YtvwlD Can you install Better Battery Stats and post some screenshots? I think it would be interesting to know, if your phone also is awake all the time, using the CPU on maximum power.
Nope. My most used app is still the browser. Feels pretty similar to me. What data would be useful for you?
Is your KitKat also awake all the time? Is your CPU on 1.21 GHz all the time?
No & No. It’s switching. I just installed BBS and walked away. This is how it looks right now:
Current CPU Stats tells me: 1.21 Ghz 2%, 497.25 Mhz 5% and Deep Sleep 93%.
Are dev options activated? No Deep Sleep sounds odd to me.
Developer options in Settings are activated (USB debugging turns itself off constantly though, but that’s another story)… Should I deactivate developer options?
Indeed. I never get into Deep Sleep! :frowning:
I’ve installed the app five minutes ago and haven’t turned off my screen yet.
Ok, thanks. Please post more screen shots, when you have not used your phone for some time (e.g. over night).
There is also a text export function that could be useful. It shows that my FP1 uses all states. But some only for a very short time …
BBS log (*click to expand*) > =================== > General Information > =================== > BetterBatteryStats version: 2.2.0.0B6 > Creation Date: 2016-04-18 21:41:09 > Statistic Type: Boot to Current > Since 4 h 25 s > VERSION.RELEASE: 4.4.4 (...) > Root perms: true > SELinux Policy: Enforcing > BATTERY_STATS permission granted: true > XPosed BATTERY_STATS module enabled: false > ============ > Battery Info > ============ > Level lost [%]: Bat.: -8%(65% to 57%) [2.0%/h] > Voltage lost [mV]: (3701-3738) [-9.2%/h] > =========== > Other Usage > =========== > Deep Sleep (): 3 h 28 m 29 s 86.7% > Awake (Screen Off) (): 7 m 9 s 3.0% > Screen On (): 24 m 46 s 10.3% > Wifi On (): 4 h 25 s 100.0% > Wifi Running (): 4 h 25 s 100.0% > No Data Connection (): 4 h 25 s 100.0% > No or Unknown Signal (): 4 h 25 s 100.0% > Screen dark (): 49 s 0.3% > Screen medium (): 23 m 56 s 10.0% (...) > ========== > CPU States > ========== > 1.21 GHz (): 10 m 41 s 4.4% > 988 MHz (): 8 s 0.1% > 754 MHz (): 7 s 0.1% > 497.25 MHz (): 20 m 58 s 8.7% > Deep Sleep (): 3 h 28 m 29 s 86.7% > ========
Do you also have “ps wakelock” as #1, active 85% of the time, in Kernel wakelocks?
PS.: I uninstalled Telegram now, but I doubt the problem to be solved, since “ps wakelock” continues to grow.
PPS.: For the coders, there are two appearances of “ps wakelock” in the FP1 kernel on Github.
According to the code, stk3171 is the proximity and light sensor driver in the FP1. It does not show in my “Kernel Wakelock” stats. Are you using applications that interact with this sensor a lot? Do you use a special launcher? Maybe it’s just an application that checks if the screen was touched … a lot. I don’t see this “ps” wakelock here.
EINT wakelock (WiFi related?) has 1% here … and it’s the highest right now.
I have this EINT wakelock, too. But the rest looks normal to me.
General Information
BetterBatteryStats version: 1.15.0.0
Creation Date: 2016-04-19 06:38:17
Statistic Type: Unplugged to Current
Since 9 h 31 m 58 s
BRAND: alps
DEVICE: ahong89_wet_jb2
MANUFACTURER: alps
MODEL: ahong89_wet_jb2
OS.VERSION: 3.4.67
BOOTLOADER: unknown
HARDWARE: mt6589
FINGERPRINT: alps/ahong89_wet_jb2/ahong89_wet_jb2:4.4.4/KTU84Q/1459928895:userdebug/test-keys
TAGS: test-keys
USER: chris
PRODUCT: ahong89_wet_jb2
RADIO: MOLY.WR8.W1248.MD.WG.MP.V14.F1.P1, 2014/07/14 13:31
Rooted: true
Battery Info
Level lost [%]: Bat.: -22% (95% to 73%) [2,3%/h]
Voltage lost [mV]: (4121-3924) [20,7%/h]
Other Usage
Screen On (): 39 m 48 s  (2388 s) Ratio: 1,8%
Wifi On (): 10 h 49 m 37 s  (38977 s) Ratio: 30,1%
Wifi Running (): 10 h 49 m 37 s  (38977 s) Ratio: 30,1%
Deep Sleep (): 7 h 20 m 2 s  (26402 s) Ratio: 76,9%
Awake (): 2 h 11 m 55 s  (7915 s) Ratio: 23,1%
Wakelocks
No reference unplugged was saved yet, plug/unplug you phone ():  (0 s) Count:1 100,0%
Kernel Wakelocks  !!! wakeup_sources !!!
EINT wakelock (): 1 h 15 m 2 s  (4502 s) Cnt:(c/wc/ec)6349/4261/6350 13,1%
event0-1623 (): 30 m 32 s  (1832 s) Cnt:(c/wc/ec)4888/138/0 5,3%
PowerManagerService.WakeLocks (): 26 m 7 s  (1567 s) Cnt:(c/wc/ec)1886/208/0 4,6%
alarm (): 5 m 49 s  (349 s) Cnt:(c/wc/ec)1352/303/0 1,0%
alarmtimer (): 4 m 35 s  (275 s) Cnt:(c/wc/ec)138/138/138 0,8%
 (): 52 s  (52 s) Cnt:(c/wc/ec)3551/435/0 0,2%
event1-1623 (): 23 s  (23 s) Cnt:(c/wc/ec)5047/138/0 0,1%
event3-1623 (): 21 s  (21 s) Cnt:(c/wc/ec)24611/138/0 0,1%
event4-1623 (): 21 s  (21 s) Cnt:(c/wc/ec)5049/138/0 0,1%
MT662x (): 14 s  (14 s) Cnt:(c/wc/ec)579/44/0 0,0%
[timerfd] (): 11 s  (11 s) Cnt:(c/wc/ec)114/17/0 0,0%
ccci1_fs (): 10 s  (10 s) Cnt:(c/wc/ec)11/1/11 0,0%
ps wakelock (): 1 s  (1 s) Cnt:(c/wc/ec)10/0/0 0,0%
ccci_modem1 (): 1 s  (1 s) Cnt:(c/wc/ec)398/0/398 0,0%
WLAN Timer ():  (0 s) Cnt:(c/wc/ec)881/8/0 0,0%
KeyEvents ():  (0 s) Cnt:(c/wc/ec)24862/164/0 0,0%
mmc1_detect ():  (0 s) Cnt:(c/wc/ec)5344/138/0 0,0%
usb ():  (0 s) Cnt:(c/wc/ec)791/128/0 0,0%
battery ():  (0 s) Cnt:(c/wc/ec)791/129/0 0,0%
mmc0_detect ():  (0 s) Cnt:(c/wc/ec)5344/138/0 0,0%
ac ():  (0 s) Cnt:(c/wc/ec)791/129/0 0,0%
eventpoll ():  (0 s) Cnt:(c/wc/ec)3659/399/0 0,0%
Alarms (requires root)
No reference unplugged was saved yet, plug/unplug you phone (): Wakeups: 0
Network (requires root)
-1 () (No reference unplugged was saved yet, plug/unplug you phone): 1.0 Bytes 100,0%
CPU States
1,21 GHz (): 1 h 59 m 37 s  20,9%
988 MHz (): 14 s  0,0%
754 MHz (): 17 s  0,1%
497,25 MHz (): 11 m 45 s  2,1%
Deep Sleep (): 7 h 20 m 2 s  76,9%
Reference overview
ref_unplugged: Reference ref_unplugged created 1 d 2 h 25 m 45 s  (Wl: null; KWl: 28elements; NetS: null; Alrm: null; Proc: null; Oth: 2 elements; CPU: 5 elements)
ref_custom: Reference ref_custom created 1 d 2 h 26 m 52 s  (Wl: null; KWl: 28elements; NetS: null; Alrm: null; Proc: null; Oth: 2 elements; CPU: 5 elements)
ref_current: Reference ref_current created 1 d 11 h 57 m 43 s  (Wl: 32 elements; KWl: 28elements; NetS: 53 elements; Alrm: 17 elements; Proc: 147 elements; Oth: 5 elements; CPU: 5 elements)
Your EINT wakelock is 13.1%, mine is only 0.2%. If EINT wakelock is WiFi related, as @fp1_wo_sw_updates states, then you could try to reset your wpa_supplicant.
As for me: The ps wakelock was caused by WaveUp, an app, which appeared recently on F-Droid. (cc @paulakreuzer, does it drain the battery on FP2 too?). When I deactivated it, my phone switched to Deep Sleep immediately. It’s in there now and counting. Thank you to @fp1_wo_sw_updates for pointing out that
KUDOS!!! :blush:
I’ll see if my battery usage per hour goes down significantly. :slight_smile:
Edit: I notified the developer of WaveUp about the issue: WaveUp produces ps wakelock (#36) · Issues · juanitobananas / WaveUp · GitLab
Be careful, maybe nothing is wrong. I have no clue what this wakelock does. We don’t even have the real code that’s been used for the ROM. I have no clue :slight_smile: But I read about channel & AP and was thinking it could be related to WLAN related stuff. But @YtvwlD – please don’t remove/modify anything right now if your phone works okay!
TLDR: Wakelocks are not always evil, they are useful. It depends. :wink:
int mt_eint_init(void)
	unsigned int i;
	int ret;
	/* assign to domain 0 for AP */
	mt_eint_setdomain0();
	**wake_lock_init(&EINT_suspend_lock, WAKE_LOCK_SUSPEND, "EINT wakelock");**
        setup_MD_eint();
        mt_eint_enable_pmic();
	for (i = 0; i < EINT_MAX_CHANNEL; i++) {
		EINT_FUNC.eint_func[i] = NULL;
		EINT_FUNC.is_deb_en[i] = 0;
		EINT_FUNC.deb_time[i] = 0;
#ifndef CTP
		EINT_FUNC.eint_sw_deb_timer[i].expires = 0;
		EINT_FUNC.eint_sw_deb_timer[i].data = 0;
		EINT_FUNC.eint_sw_deb_timer[i].function = NULL;
#if defined(EINT_TEST)
		EINT_FUNC.softisr_called[i] = 0;
#endif
#endif				/*!CTP */
Don’t worry. I didn’t have the idea to delete my working WiFi configuration. :wink:
But those wakelocks don’t really seem to be a problem:
Yes, of course.
Well, this code snippet isn’t exactly an example of readable code, is it?
Just for the sake of completeness: This is a measurement from yesterday:
General Information
Creation Date: 2016-04-19 14:54:54
Since 4 h 48 m 22 s
BRAND: alps
MANUFACTURER: alps
OS.VERSION: 3.4.67
BOOTLOADER: unknown
HARDWARE: mt6589
TAGS: test-keys
USER: chris
Rooted: true
Battery Info
Level lost [%]: Bat.: -47% (100% to 53%) [9,8%/h]
Voltage lost [mV]: (4222-3735) [101,5%/h]
Other Usage
Screen On (): 45 m 13 s  (2713 s) Ratio: 1,7%
Wifi On (): 1 m 49 s  (109 s) Ratio: 0,1%
Wifi Running (): 4 h 48 m 21 s  (17301 s) Ratio: 100,0%
Deep Sleep (): 3 h 10 m 12 s  (11412 s) Ratio: 66,0%
Awake (): 1 h 38 m 9 s  (5889 s) Ratio: 34,0%
Wakelocks
AudioMix (0): 24 m 2 s  (1442 s) Count:1572 53,2%
AudioMix (com.nianticproject.ingress.Ingress): 14 m 25 s  (865 s) Count:1544 31,9%
PollService wakeLockAcquire (com.fsck.k9.K-9 Mail): 2 m 36 s  (156 s) Count:10 5,8%
TimedEventQueue (0): 1 m 52 s  (112 s) Count:662 4,1%
AlarmManager (0): 34 s  (34 s) Count:299 1,3%
ImapFolderPusher <me>@ytvwld.de:INBOX (com.fsck.k9.K-9 Mail): 14 s  (14 s) Count:26 0,5%
RILJ (0): 11 s  (11 s) Count:809 0,4%
LocationManagerService (0): 10 s  (10 s) Count:1536 0,4%
NetworkStats (0): 8 s  (8 s) Count:71 0,3%
LocationManagerService (com.nianticproject.ingress.Ingress): 8 s  (8 s) Count:1518 0,3%
ActivityManager-Launch (0): 7 s  (7 s) Count:13 0,3%
ImapFolderPusher <me>@ytvwld.de:Drafts (com.fsck.k9.K-9 Mail): 6 s  (6 s) Count:26 0,2%
StartingAlertService (com.android.calendar.Kalender): 5 s  (5 s) Count:1 0,2%
BBS_WAKELOCK_WHILE_SAVING_REF (com.asksven.betterbatterystats.BetterBatteryStats): 4 s  (4 s) Count:3 0,1%
AlarmManager (eu.siacs.conversations.Conversations): 3 s  (3 s) Count:80 0,1%
mcs (com.google.android.gms.microG Services Core): 3 s  (3 s) Count:365 0,1%
XmppConnectionService (eu.siacs.conversations.Conversations): 3 s  (3 s) Count:186 0,1%
*sync*/com.android.contacts/org.thoughtcrime.securesms/LibreSignal (org.libresignal.LibreSignal): 2 s  (2 s) Count:2 0,1%
GpsLocationProvider (0): 2 s  (2 s) Count:12 0,1%
*sync*/com.android.contacts/org.sufficientlysecure.keychain.account/OpenKeychain (org.sufficientlysecure.keychain.OpenKeychain): 2 s  (2 s) Count:1 0,1%
de.avm.android.fritzapp.sipua.e (0): 2 s  (2 s) Count:2 0,1%
ytvwld@<host> (eu.siacs.conversations.Conversations): 1 s  (1 s) Count:908 0,0%
ImapFolderPusher <mail>:Entwürfe (com.fsck.k9.K-9 Mail): 1 s  (1 s) Count:8 0,0%
ImapFolderPusher <mail>:INBOX (com.fsck.k9.K-9 Mail): 1 s  (1 s) Count:8 0,0%
CoreReceiver getWakeLock (com.fsck.k9.K-9 Mail): 1 s  (1 s) Count:79 0,0%
*vibrator* (0): 1 s  (1 s) Count:36 0,0%
<me>@ytvwld.de (eu.siacs.conversations.Conversations): 1 s  (1 s) Count:583 0,0%
CoreService execute (com.fsck.k9.K-9 Mail): 1 s  (1 s) Count:40 0,0%
AudioMix (0): 1 s  (1 s) Count:4 0,0%
LocationManagerService (de.vodafone.meincallya.MeinCallYa): 1 s  (1 s) Count:43 0,0%
AlarmManager (com.google.android.gms.microG Services Core): 1 s  (1 s) Count:245 0,0%
ccci1_net_v2 (): 43 m 55 s  (2635 s) Cnt:(c/wc/ec)1591/1140/1591 15,2%
event0-1623 (): 8 m 54 s  (534 s) Cnt:(c/wc/ec)1442/40/0 3,1%
EINT wakelock (): 4 m 2 s  (242 s) Cnt:(c/wc/ec)2811/77/2811 1,4%
PowerManagerService.WakeLocks (): 3 m 27 s  (207 s) Cnt:(c/wc/ec)1317/73/0 1,2%
alarm (): 2 m 29 s  (149 s) Cnt:(c/wc/ec)652/53/0 0,9%
alarmtimer (): 1 m 17 s  (77 s) Cnt:(c/wc/ec)39/39/39 0,5%
ps wakelock (): 24 s  (24 s) Cnt:(c/wc/ec)6/0/0 0,1%
 (): 16 s  (16 s) Cnt:(c/wc/ec)2492/125/0 0,1%
MT662x (): 13 s  (13 s) Cnt:(c/wc/ec)5790/45/0 0,1%
[timerfd] (): 7 s  (7 s) Cnt:(c/wc/ec)56/4/0 0,0%
ccci1_fs (): 7 s  (7 s) Cnt:(c/wc/ec)17/0/17 0,0%
event1-1623 (): 5 s  (5 s) Cnt:(c/wc/ec)1441/39/0 0,0%
event3-1623 (): 5 s  (5 s) Cnt:(c/wc/ec)18617/39/0 0,0%
event4-1623 (): 5 s  (5 s) Cnt:(c/wc/ec)1441/39/0 0,0%
ccci_modem1 (): 3 s  (3 s) Cnt:(c/wc/ec)1343/0/1344 0,0%
radio-interface (): 1 s  (1 s) Cnt:(c/wc/ec)295/0/0 0,0%
PowerManagerService.Broadcasts ():  (0 s) Cnt:(c/wc/ec)2/0/0 0,0%
KeyEvents ():  (0 s) Cnt:(c/wc/ec)18830/44/0 0,0%
battery ():  (0 s) Cnt:(c/wc/ec)589/38/0 0,0%
mmc1_detect ():  (0 s) Cnt:(c/wc/ec)1528/39/0 0,0%
usb ():  (0 s) Cnt:(c/wc/ec)589/38/0 0,0%
ac ():  (0 s) Cnt:(c/wc/ec)589/39/0 0,0%
mmc0_detect ():  (0 s) Cnt:(c/wc/ec)1528/39/0 0,0%
wmtFuncCtrl ():  (0 s) Cnt:(c/wc/ec)4/1/0 0,0%
WLAN Timer ():  (0 s) Cnt:(c/wc/ec)60/0/0 0,0%
PowerManagerService.Display ():  (0 s) Cnt:(c/wc/ec)7/0/0 0,0%
eventpoll ():  (0 s) Cnt:(c/wc/ec)2548/114/0 0,0%
Processes
com.nianticproject.ingress (com.nianticproject.ingress.Ingress): Uid: 10103 Sys: 2 m 32 s  (152 s) Us: 28 m 29 s  (1709 s) Starts: 1
org.fdroid.fdroid (org.fdroid.fdroid.F-Droid): Uid: 10068 Sys: 10 s  (10 s) Us: 11 m 20 s  (680 s) Starts: 0
system_server (Android-System): Uid: 1000 Sys: 2 m 16 s  (136 s) Us: 8 m 25 s  (505 s) Starts: 0
de.vodafone.meincallya (de.vodafone.meincallya.MeinCallYa): Uid: 10096 Sys: 4 m 5 s  (245 s) Us: 3 m 2 s  (182 s) Starts: 0
(Unknown) (): Uid: -1 Sys: 44 s  (44 s) Us: 4 m 34 s  (274 s) Starts: 0
mediaserver (1013): Uid: 1013 Sys: 2 m 5 s  (125 s) Us: 3 m 4 s  (184 s) Starts: 0
surfaceflinger (Android-System): Uid: 1000 Sys: 1 m 58 s  (118 s) Us: 1 m 22 s  (82 s) Starts: 0
com.android.systemui (UID): Uid: 10117 Sys: 20 s  (20 s) Us: 2 m 46 s  (166 s) Starts: 0
kworker/u:4 (0): Uid: 0 Sys: 2 m  (120 s) Us:  (0 s) Starts: 0
com.android.phone (Telefon): Uid: 1001 Sys: 17 s  (17 s) Us: 1 m 35 s  (95 s) Starts: 0
sdcard (1023): Uid: 1023 Sys: 1 m 28 s  (88 s) Us: 7 s  (7 s) Starts: 0
com.fsck.k9 (com.fsck.k9.K-9 Mail): Uid: 10066 Sys: 15 s  (15 s) Us: 50 s  (50 s) Starts: 0
kworker/0:3 (0): Uid: 0 Sys: 1 m 2 s  (62 s) Us:  (0 s) Starts: 0
kworker/0:0 (0): Uid: 0 Sys: 1 m 1 s  (61 s) Us:  (0 s) Starts: 0
libmnlp (1021): Uid: 1021 Sys: 3 s  (3 s) Us: 51 s  (51 s) Starts: 0
kworker/0:1 (0): Uid: 0 Sys: 53 s  (53 s) Us:  (0 s) Starts: 0
kworker/0:2 (0): Uid: 0 Sys: 51 s  (51 s) Us:  (0 s) Starts: 0
kworker/u:2 (0): Uid: 0 Sys: 50 s  (50 s) Us:  (0 s) Starts: 0
kworker/u:3 (0): Uid: 0 Sys: 48 s  (48 s) Us:  (0 s) Starts: 0
com.nutomic.syncthingandroid (com.nutomic.syncthingandroid.Syncthing): Uid: 10019 Sys: 6 s  (6 s) Us: 36 s  (36 s) Starts: 0
memsicd3416x (Android-System): Uid: 1000 Sys: 41 s  (41 s) Us:  (0 s) Starts: 0
*wakelock* (): Uid: -1 Sys: 13 s  (13 s) Us: 24 s  (24 s) Starts: 0
mmcqd/0 (0): Uid: 0 Sys: 30 s  (30 s) Us:  (0 s) Starts: 0
kworker/u:5 (0): Uid: 0 Sys: 30 s  (30 s) Us:  (0 s) Starts: 0
kworker/u:0 (0): Uid: 0 Sys: 30 s  (30 s) Us:  (0 s) Starts: 0
com.asksven.betterbatterystats (com.asksven.betterbatterystats.BetterBatteryStats): Uid: 10052 Sys: 3 s  (3 s) Us: 18 s  (18 s) Starts: 0
org.microg.nlp.backend.ichnaea (org.microg.nlp.backend.ichnaea.Mozilla UnifiedNlp Backend): Uid: 10111 Sys: 18 s  (18 s) Us: 2 s  (2 s) Starts: 0
disp_config_upd (0): Uid: 0 Sys: 19 s  (19 s) Us:  (0 s) Starts: 0
kworker/u:1 (0): Uid: 0 Sys: 17 s  (17 s) Us:  (0 s) Starts: 0
bat_thread_kthr (0): Uid: 0 Sys: 16 s  (16 s) Us:  (0 s) Starts: 0
com.google.android.gms (com.google.android.gms.microG Services Core): Uid: 10104 Sys: 2 s  (2 s) Us: 14 s  (14 s) Starts: 0
org.libresignal (org.libresignal.LibreSignal): Uid: 10036 Sys: 1 s  (1 s) Us: 12 s  (12 s) Starts: 0
kworker/0:4 (0): Uid: 0 Sys: 14 s  (14 s) Us:  (0 s) Starts: 0
servicemanager (Android-System): Uid: 1000 Sys: 9 s  (9 s) Us: 1 s  (1 s) Starts: 0
com.android.mms (OMACP): Uid: 10017 Sys:  (0 s) Us: 10 s  (10 s) Starts: 0
*wakelock* (): Uid: -1 Sys: 5 s  (5 s) Us: 4 s  (4 s) Starts: 0
mtk-tpd (0): Uid: 0 Sys: 6 s  (6 s) Us:  (0 s) Starts: 0
eu.siacs.conversations (eu.siacs.conversations.Conversations): Uid: 10084 Sys: 1 s  (1 s) Us: 4 s  (4 s) Starts: 0
rild (Telefon): Uid: 1001 Sys: 4 s  (4 s) Us: 1 s  (1 s) Starts: 0
org.telegram.messenger (org.telegram.messenger.Telegram): Uid: 10073 Sys: 1 s  (1 s) Us: 4 s  (4 s) Starts: 0
org.mariotaku.twidere (org.mariotaku.twidere.Twidere): Uid: 10072 Sys: 1 s  (1 s) Us: 4 s  (4 s) Starts: 0
jbd2/dm-0-8 (0): Uid: 0 Sys: 4 s  (4 s) Us:  (0 s) Starts: 0
com.adidas.micoach (com.adidas.micoach.train & run): Uid: 10031 Sys:  (0 s) Us: 4 s  (4 s) Starts: 1
kswapd0 (0): Uid: 0 Sys: 4 s  (4 s) Us:  (0 s) Starts: 0
mtk_wmtd (0): Uid: 0 Sys: 3 s  (3 s) Us:  (0 s) Starts: 0
org.fairphone.launcher (org.fairphone.launcher.Fairphone OS): Uid: 10033 Sys:  (0 s) Us: 3 s  (3 s) Starts: 0
android.process.acore (): Uid: -1 Sys:  (0 s) Us: 3 s  (3 s) Starts: 1
disp_clean_up_k (0): Uid: 0 Sys: 3 s  (3 s) Us:  (0 s) Starts: 0
com.shazam.android (com.shazam.android.Shazam): Uid: 10088 Sys:  (0 s) Us: 2 s  (2 s) Starts: 0
mtk_stp_psm (0): Uid: 0 Sys: 3 s  (3 s) Us:  (0 s) Starts: 0
org.kde.kdeconnect_tp (org.kde.kdeconnect_tp.KDE Connect): Uid: 10087 Sys:  (0 s) Us: 2 s  (2 s) Starts: 0
netd (0): Uid: 0 Sys: 2 s  (2 s) Us:  (0 s) Starts: 0
com.android.inputmethod.latin (com.android.inputmethod.latin.Android-Tastatur (AOSP)): Uid: 10028 Sys:  (0 s) Us: 2 s  (2 s) Starts: 0
de.digitalesschwarzesbrett.dsblight (de.digitalesschwarzesbrett.dsblight.DSB): Uid: 10074 Sys:  (0 s) Us: 1 s  (1 s) Starts: 0
/init (0): Uid: 0 Sys: 1 s  (1 s) Us:  (0 s) Starts: 0
android.process.media (): Uid: -1 Sys:  (0 s) Us: 1 s  (1 s) Starts: 0
gsm0710muxd (0): Uid: 0 Sys: 1 s  (1 s) Us:  (0 s) Starts: 0
com.android.deskclock (com.android.deskclock.Uhr): Uid: 10013 Sys:  (0 s) Us: 2 s  (2 s) Starts: 0
*wakelock* (): Uid: -1 Sys: 1 s  (1 s) Us:  (0 s) Starts: 0
de.avm.android.fritzapp (de.avm.android.fritzapp.FRITZ!App Fon): Uid: 10095 Sys:  (0 s) Us: 1 s  (1 s) Starts: 0
healthd (0): Uid: 0 Sys: 1 s  (1 s) Us:  (0 s) Starts: 0
com.google.android.youtube (com.google.android.youtube.YouTube): Uid: 10079 Sys:  (0 s) Us: 1 s  (1 s) Starts: 0
tx_thread (0): Uid: 0 Sys: 1 s  (1 s) Us:  (0 s) Starts: 0
kthreadd (0): Uid: 0 Sys: 1 s  (1 s) Us:  (0 s) Starts: 0
flush-254:0 (0): Uid: 0 Sys: 1 s  (1 s) Us:  (0 s) Starts: 0
*wakelock* (): Uid: -1 Sys:  (0 s) Us:  (0 s) Starts: 0
migration/0 (0): Uid: 0 Sys: 1 s  (1 s) Us:  (0 s) Starts: 0
com.android.settings (Android-System): Uid: 1000 Sys:  (0 s) Us:  (0 s) Starts: 1
drmserver (1019): Uid: 1019 Sys:  (0 s) Us:  (0 s) Starts: 0
pmic_thread_kth (0): Uid: 0 Sys:  (0 s) Us:  (0 s) Starts: 0
dpfd (Android-System): Uid: 1000 Sys:  (0 s) Us:  (0 s) Starts: 0
org.quantumbadger.redreader (org.quantumbadger.redreader.RedReader Beta): Uid: 10070 Sys:  (0 s) Us:  (0 s) Starts: 0
mtk charger_hv_ (0): Uid: 0 Sys:  (0 s) Us:  (0 s) Starts: 0
zygote (0): Uid: 0 Sys:  (0 s) Us:  (0 s) Starts: 0
mnld (1021): Uid: 1021 Sys:  (0 s) Us:  (0 s) Starts: 0
kworker/1:0 (0): Uid: 0 Sys:  (0 s) Us:  (0 s) Starts: 0
kworker/1:2 (0): Uid: 0 Sys:  (0 s) Us:  (0 s) Starts: 0
indrora.atomic (indrora.atomic.Atomic): Uid: 10043 Sys:  (0 s) Us:  (0 s) Starts: 0
keystore (1017): Uid: 1017 Sys:  (0 s) Us:  (0 s) Starts: 0
mtk_agpsd (1021): Uid: 1021 Sys:  (0 s) Us:  (0 s) Starts: 0
ksdioirqd/mmc2 (0): Uid: 0 Sys:  (0 s) Us:  (0 s) Starts: 0
su (0): Uid: 0 Sys:  (0 s) Us:  (0 s) Starts: 0
wpa_supplicant (1010): Uid: 1010 Sys:  (0 s) Us:  (0 s) Starts: 0
ksoftirqd/0 (0): Uid: 0 Sys:  (0 s) Us:  (0 s) Starts: 0
ion_mm_heap (0): Uid: 0 Sys:  (0 s) Us:  (0 s) Starts: 0
org.sufficientlysecure.keychain:sync (org.sufficientlysecure.keychain.OpenKeychain): Uid: 10083 Sys:  (0 s) Us:  (0 s) Starts: 1
kworker/2:1 (0): Uid: 0 Sys:  (0 s) Us:  (0 s) Starts: 0
sh (0): Uid: 0 Sys:  (0 s) Us:  (0 s) Starts: 0
org.sufficientlysecure.keychain (org.sufficientlysecure.keychain.OpenKeychain): Uid: 10083 Sys:  (0 s) Us:  (0 s) Starts: 1
com.android.calendar (com.android.calendar.Kalender): Uid: 10006 Sys:  (0 s) Us:  (0 s) Starts: 1
com.android.providers.calendar (com.android.providers.calendar.Kalenderspeicher): Uid: 10001 Sys:  (0 s) Us:  (0 s) Starts: 1
migration/1 (0): Uid: 0 Sys:  (0 s) Us:  (0 s) Starts: 0
bdi-default (0): Uid: 0 Sys:  (0 s) Us:  (0 s) Starts: 0
mdlogger (com.android.shell.Shell): Uid: 2000 Sys:  (0 s) Us:  (0 s) Starts: 0
kworker/1:1 (0): Uid: 0 Sys:  (0 s) Us:  (0 s) Starts: 0
ccci_mdinit (Android-System): Uid: 1000 Sys:  (0 s) Us:  (0 s) Starts: 0
6620_launcher (Android-System): Uid: 1000 Sys:  (0 s) Us:  (0 s) Starts: 0
mtkGD (Android-System): Uid: 1000 Sys:  (0 s) Us:  (0 s) Starts: 0
flush-179:0 (0): Uid: 0 Sys:  (0 s) Us:  (0 s) Starts: 0
drvbd (Android-System): Uid: 1000 Sys:  (0 s) Us:  (0 s) Starts: 0
ccci_fsd (9996): Uid: 9996 Sys:  (0 s) Us:  (0 s) Starts: 0
vold (0): Uid: 0 Sys:  (0 s) Us:  (0 s) Starts: 0
file-storage (0): Uid: 0 Sys:  (0 s) Us:  (0 s) Starts: 0
fotabinder (0): Uid: 0 Sys:  (0 s) Us:  (0 s) Starts: 0
adbd (com.android.shell.Shell): Uid: 2000 Sys:  (0 s) Us:  (0 s) Starts: 0
disp_detect_ali (0): Uid: 0 Sys:  (0 s) Us:  (0 s) Starts: 0
ueventd (0): Uid: 0 Sys:  (0 s) Us:  (0 s) Starts: 0
ksoftirqd/1 (0): Uid: 0 Sys:  (0 s) Us:  (0 s) Starts: 0
jbd2/mmcblk0p5- (0): Uid: 0 Sys:  (0 s) Us:  (0 s) Starts: 0
flush-0:25 (0): Uid: 0 Sys:  (0 s) Us:  (0 s) Starts: 0
flush-0:21 (0): Uid: 0 Sys:  (0 s) Us:  (0 s) Starts: 0
sync_supers (0): Uid: 0 Sys:  (0 s) Us:  (0 s) Starts: 0
jbd2/mmcblk0p6- (0): Uid: 0 Sys:  (0 s) Us:  (0 s) Starts: 0
com.artifex.mupdfdemo (com.artifex.mupdfdemo.MuPDF): Uid: 10085 Sys:  (0 s) Us:  (0 s) Starts: 0
khubd (0): Uid: 0 Sys:  (0 s) Us:  (0 s) Starts: 0
wdtk-1 (0): Uid: 0 Sys:  (0 s) Us:  (0 s) Starts: 0
jbd2/mmcblk0p3- (0): Uid: 0 Sys:  (0 s) Us:  (0 s) Starts: 0
jbd2/mmcblk0p2- (0): Uid: 0 Sys:  (0 s) Us:  (0 s) Starts: 0
wdtk-2 (0): Uid: 0 Sys:  (0 s) Us:  (0 s) Starts: 0
org.sufficientlysecure.keychain:remote_api (): Uid: -1 Sys:  (0 s) Us:  (0 s) Starts: 1
mmcqd/0boot0 (0): Uid: 0 Sys:  (0 s) Us:  (0 s) Starts: 0
mmcqd/0boot1 (0): Uid: 0 Sys:  (0 s) Us:  (0 s) Starts: 0
mmcqd/1 (0): Uid: 0 Sys:  (0 s) Us:  (0 s) Starts: 0
hang_detect (0): Uid: 0 Sys:  (0 s) Us:  (0 s) Starts: 0
mtk battery_kth (0): Uid: 0 Sys:  (0 s) Us:  (0 s) Starts: 0
wdtk-3 (0): Uid: 0 Sys:  (0 s) Us:  (0 s) Starts: 0
wdtk-0 (0): Uid: 0 Sys:  (0 s) Us:  (0 s) Starts: 0
org.sufficientlysecure.keychain:remote_api_2 (org.sufficientlysecure.keychain.OpenKeychain): Uid: 10083 Sys:  (0 s) Us:  (0 s) Starts: 0
com.mediatek.bluetooth (UID): Uid: 1002 Sys:  (0 s) Us:  (0 s) Starts: 0
com.mediatek.voicecommand (com.mediatek.voicecommand.Sprachbefehl): Uid: 10055 Sys:  (0 s) Us:  (0 s) Starts: 0
kblockd (0): Uid: 0 Sys:  (0 s) Us:  (0 s) Starts: 0
com.google.android.gms (): Wakeups: 364
  Alarms: 358, Intent: org.microg.gms.gcm.mcs.HEARTBEAT cmp={com.google.android.gms/org.microg.gms.gcm.McsService}
  Alarms: 6, Intent: org.microg.gms.gcm.mcs.RECONNECT cmp={com.google.android.gms/org.microg.gms.gcm.TriggerReceiver}
org.telegram.messenger (): Wakeups: 289
  Alarms: 289, Intent: {org.telegram.messenger/org.telegram.messenger.ApplicationLoader}
  Alarms: 0, Intent: {org.telegram.messenger/org.telegram.messenger.NetworkAlarm}
  Alarms: 0, Intent: {org.telegram.messenger/org.telegram.messenger.NotificationRepeat}
eu.siacs.conversations (): Wakeups: 174
  Alarms: 174, Intent: ping cmp={eu.siacs.conversations/eu.siacs.conversations.services.EventReceiver}
org.mariotaku.twidere (): Wakeups: 72
  Alarms: 18, Intent: org.mariotaku.twidere.REFRESH_DIRECT_MESSAGES
  Alarms: 18, Intent: org.mariotaku.twidere.REFRESH_TRENDS
  Alarms: 18, Intent: org.mariotaku.twidere.REFRESH_NOTIFICATIONS
  Alarms: 18, Intent: org.mariotaku.twidere.REFRESH_HOME_TIMELINE
com.android.phone (): Wakeups: 64
  Alarms: 0, Intent: com.android.internal.telephony.dataconnection.DataConnection.DC-1.action_retry
  Alarms: 64, Intent: com.android.internal.telephony.data-stall
  Alarms: 0, Intent: com.android.internal.telephony.data-reconnect.default
  Alarms: 0, Intent: com.android.phone.UPDATE_CALLER_INFO_CACHE cmp={com.android.phone/com.android.phone.CallerInfoCacheUpdateReceiver}
com.fsck.k9 (): Wakeups: 27
  Alarms: 27, Intent: com.fsck.k9.service.BroadcastReceiver.fireIntent cmp={com.fsck.k9/com.fsck.k9.service.BootReceiver}
android (): Wakeups: 6
  Alarms: 0, Intent: android.intent.action.TIME_TICK
  Alarms: 0, Intent: com.android.server.action.NETWORK_STATS_POLL
  Alarms: 6, Intent: android.content.syncmanager.SYNC_ALARM
  Alarms: 0, Intent: android.net.ConnectivityService.action.PKT_CNT_SAMPLE_INTERVAL_ELAPSED
  Alarms: 0, Intent: com.android.server.NetworkTimeUpdateService.action.POLL
  Alarms: 0, Intent: android.intent.action.DATE_CHANGED
  Alarms: 0, Intent: com.android.server.IdleMaintenanceService.action.UPDATE_IDLE_MAINTENANCE_STATE
  Alarms: 0, Intent: com.android.server.action.UPDATE_TWILIGHT_STATE
com.shazam.android (): Wakeups: 3
  Alarms: 3, Intent: com.google.android.gms.measurement.UPLOAD cmp={com.shazam.android/com.google.android.gms.measurement.AppMeasurementReceiver}
com.nianticproject.ingress (): Wakeups: 2
  Alarms: 2, Intent: com.nianticproject.ingress.ACTION_PAUSE_LOCATION_TRACKER cmp={com.nianticproject.ingress/com.nianticproject.ingress.alarms.NemesisAlarmHandlingService}
  Alarms: 0, Intent: {com.nianticproject.ingress/com.nianticproject.ingress.NemesisActivity}
de.vodafone.meincallya (): Wakeups: 1
  Alarms: 1, Intent: {de.vodafone.meincallya/com.tm.monitoring.TMService}
10019 (ccmni0) (com.nutomic.syncthingandroid.Syncthing): 31.0 MBytes 59,4%
10103 (ccmni0) (com.nianticproject.ingress.Ingress): 8.0 MBytes 15,1%
10019 (lo) (com.nutomic.syncthingandroid.Syncthing): 5.0 MBytes 9,8%
10019 (Wifi) (com.nutomic.syncthingandroid.Syncthing): 3.0 MBytes 6,9%
10068 (ccmni0) (org.fdroid.fdroid.F-Droid): 1.0 MBytes 3,1%
10066 (ccmni0) (com.fsck.k9.K-9 Mail): 724.0 KBytes 1,3%
10104 (ccmni0) (com.google.android.gms.microG Services Core): 623.0 KBytes 1,1%
10036 (ccmni0) (org.libresignal.LibreSignal): 500.0 KBytes 0,9%
0 (ccmni0) (0): 292.0 KBytes 0,5%
0 (lo) (0): 157.0 KBytes 0,3%
10095 (Wifi) (de.avm.android.fritzapp.FRITZ!App Fon): 146.0 KBytes 0,3%
10066 (Wifi) (com.fsck.k9.K-9 Mail): 143.0 KBytes 0,3%
10084 (ccmni0) (eu.siacs.conversations.Conversations): 113.0 KBytes 0,2%
10072 (ccmni0) (org.mariotaku.twidere.Twidere): 111.0 KBytes 0,2%
10070 (ccmni0) (org.quantumbadger.redreader.RedReader Beta): 71.0 KBytes 0,1%
10084 (Wifi) (eu.siacs.conversations.Conversations): 51.0 KBytes 0,1%
10033 (ccmni0) (org.fairphone.launcher.Fairphone OS): 48.0 KBytes 0,1%
10073 (ccmni0) (org.telegram.messenger.Telegram): 43.0 KBytes 0,1%
0 (Wifi) (0): 19.0 KBytes 0,0%
10103 (Wifi) (com.nianticproject.ingress.Ingress): 17.0 KBytes 0,0%
10104 (Wifi) (com.google.android.gms.microG Services Core): 10.0 KBytes 0,0%
1021 (ccmni0) (1021): 7.0 KBytes 0,0%
10079 (ccmni0) (com.google.android.youtube.YouTube): 7.0 KBytes 0,0%
10087 (ccmni0) (org.kde.kdeconnect_tp.KDE Connect): 4.0 KBytes 0,0%
10096 (ccmni0) (de.vodafone.meincallya.MeinCallYa): 4.0 KBytes 0,0%
10036 (Wifi) (org.libresignal.LibreSignal): 4.0 KBytes 0,0%
10087 (Wifi) (org.kde.kdeconnect_tp.KDE Connect): 1.0 KBytes 0,0%
10019 (p2p0) (com.nutomic.syncthingandroid.Syncthing): 928.0 Bytes 0,0%
10073 (Wifi) (org.telegram.messenger.Telegram): 716.0 Bytes 0,0%
1000 (Wifi) (Android-System): 643.0 Bytes 0,0%
0 (p2p0) (0): 576.0 Bytes 0,0%
0 (ccmni1) (0): 152.0 Bytes 0,0%
CPU States
1,21 GHz (): 1 h 27 m 7 s  30,2%
988 MHz (): 1 m 57 s  0,7%
754 MHz (): 2 m 58 s  1,0%
497,25 MHz (): 6 m 5 s  2,1%
Deep Sleep (): 3 h 10 m 12 s  66,0%
Services
Active since: The time when the service was first made active, either by someone starting or binding to it.
Last activity: The time when there was last activity in the service (either explicit requests to start it or clients binding to it)
See http://developer.android.com/reference/android/app/ActivityManager.RunningServiceInfo.html
de.avm.android.fritzapp (de.avm.android.fritzapp.service.BoxService)
  Active since: 3 m 11 s
  Last activity: 1 d 1 h 50 m 18 s
  Crash count:0
com.mediatek.bluetooth (com.mediatek.bluetooth.AdvancedService)
  Active since: 1 m 50 s
  Last activity: 1 m 50 s
  Crash count:0
org.libresignal (org.thoughtcrime.securesms.service.MessageRetrievalService)
  Active since: 2 m 45 s
  Last activity: 22 h 18 m 28 s
  Crash count:0
com.android.phone (com.android.phone.BluetoothPhoneService)
  Active since: 1 m 52 s
  Last activity: 1 m 52 s
  Crash count:0
com.google.android.gms (org.microg.nlp.geocode.GeocodeServiceV1)
  Active since: 1 m 51 s
  Last activity: 1 m 51 s
  Crash count:0
org.kde.kdeconnect_tp (org.kde.kdeconnect.Plugins.NotificationsPlugin.NotificationReceiver)
  Active since: 1 m 46 s
  Last activity: 18 h 24 m 43 s
  Crash count:0
com.android.systemui (com.android.systemui.ImageWallpaper)
  Active since: 1 m 49 s
  Last activity: 1 m 49 s
  Crash count:0
com.google.android.gms (org.microg.gms.wearable.WearableService)
  Active since: 1 d 13 h 6 m 1 s
  Last activity: 21 h 56 m 15 s
  Crash count:0
com.nutomic.syncthingandroid (com.nutomic.syncthingandroid.syncthing.SyncthingService)
  Active since: 1 d 12 h 50 m 34 s
  Last activity: 1 d 1 h 50 m 10 s
  Crash count:0
com.google.android.gms (com.google.android.gms.analytics.service.AnalyticsService)
  Active since: 1 d 19 h 39 m 57 s
  Last activity: 1 d 1 h 20 m 39 s
  Crash count:0
com.android.inputmethod.latin (com.android.inputmethod.latin.LatinIME)
  Last activity: 22 h 21 m 52 s
  Crash count:0
com.asksven.betterbatterystats (com.asksven.betterbatterystats.services.EventWatcherService)
  Active since: 1 d 2 h 25 m 45 s
  Last activity: 1 d 1 h 49 m 58 s
  Crash count:0
com.android.systemui (com.android.keyguard.KeyguardService)
  Active since: 1 m 47 s
  Last activity: 1 h 53 m 56 s
  Crash count:0
com.fsck.k9 (com.fsck.k9.service.PushService)
  Active since: 1 d 20 h 12 m 30 s
  Last activity: 1 d 1 h 50 m 11 s
  Crash count:0
com.google.android.gms (org.microg.gms.gcm.McsService)
  Active since: 3 m 4 s
  Last activity: 1 d 1 h 51 m 39 s
  Crash count:0
org.sufficientlysecure.keychain:remote_api (org.sufficientlysecure.keychain.remote.OpenPgpService)
  Active since: 1 d 13 h 30 m 28 s
  Last activity: 1 d 1 h 30 m 9 s
  Crash count:0
com.google.android.gms (org.microg.nlp.location.LocationServiceV2)
  Crash count:0
org.sufficientlysecure.keychain:remote_api_2 (org.sufficientlysecure.keychain.remote.OpenPgpService2)
  Active since: 1 d 2 h 31 m 45 s
  Last activity: 19 h 1 m 2 s
  Crash count:0
org.libresignal (org.thoughtcrime.securesms.service.KeyCachingService)
  Active since: 1 d 19 h 24 m 6 s
  Last activity: 1 d 1 h 4 m 53 s
  Crash count:0
com.android.bluetooth (com.android.bluetooth.a2dp.A2dpService)
  Active since: 2 m 9 s
  Last activity: 2 m 9 s
  Crash count:0
com.google.android.gms (org.microg.gms.location.GoogleLocationManagerService)
  Active since: 1 d 19 h 41 m 59 s
  Last activity: 1 d 1 h 21 m 1 s
  Crash count:0
com.android.systemui (com.android.systemui.SystemUIService)
  Active since: 1 m 48 s
  Last activity: 1 m 48 s
  Crash count:0
system (android.hardware.location.GeofenceHardwareService)
  Crash count:0
org.kde.kdeconnect_tp (org.kde.kdeconnect.BackgroundService)
  Active since: 2 m 44 s
  Crash count:0
com.mediatek.voicecommand (com.mediatek.voicecommand.service.VoiceCommandManagerService)
  Crash count:0
org.telegram.messenger (org.telegram.messenger.NotificationsService)
  Active since: 11 h 24 m 26 s
  Last activity: 21 h 11 m 15 s
  Crash count:0
de.vodafone.meincallya (com.tm.monitoring.TMService)
  Active since: 7 m
  Last activity: 1 d 37 m 17 s
  Crash count:0
com.android.phone (com.mediatek.CellConnService.PhoneStatesMgrService)
  Last activity: 2 m 56 s
  Crash count:0
com.android.phone (com.android.stk.StkAppService)
  Active since: 2 m 8 s
  Last activity: 3 m 1 s
  Crash count:0
indrora.atomic (indrora.atomic.irc.IRCService)
  Active since: 16 h 55 m 25 s
  Last activity: 21 h 40 m 27 s
  Crash count:1
com.android.bluetooth (com.android.bluetooth.hfp.HeadsetService)
  Crash count:0
org.mariotaku.twidere (org.mariotaku.twidere.service.RefreshService)
  Active since: 1 d 20 h 5 m 15 s
  Crash count:0
org.microg.nlp.backend.ichnaea (org.microg.nlp.backend.ichnaea.BackendService)
  Crash count:0
system (com.android.internal.backup.LocalTransportService)
  Last activity: 1 m 47 s
  Crash count:0
system (com.android.location.fused.FusedLocationService)
  Crash count:0
com.android.inputmethod.latin (com.android.inputmethod.latin.spellcheck.AndroidSpellCheckerService)
  Active since: 1 d 11 h 50 m 52 s
  Last activity: 21 h 7 s
  Crash count:0
com.shazam.android (com.shazam.android.service.player.MusicPlayerService)
  Active since: 12 h 11 m 12 s
  Last activity: 21 h 56 m 8 s
  Crash count:0
com.android.phone (com.android.phone.TelephonyDebugService)
  Crash count:0
eu.siacs.conversations (eu.siacs.conversations.services.XmppConnectionService)
  Active since: 12 h 1 m 11 s
  Crash count:0
com.android.bluetooth (com.android.bluetooth.pan.PanService)
  Last activity: 1 m 46 s
  Crash count:0
Reference overview
ref_unplugged: Reference ref_unplugged created 1 d 15 h 25 m 49 s  (Wl: 0 elements; KWl: 27elements; NetS: 55 elements; Alrm: 17 elements; Proc: 0 elements; Oth: 3 elements; CPU: 5 elements)
ref_charged: Reference ref_charged created 1 d 15 h 25 m 50 s  (Wl: 1 elements; KWl: 27elements; NetS: 55 elements; Alrm: 17 elements; Proc: 0 elements; Oth: 3 elements; CPU: 5 elements)
ref_current: Reference ref_current created 1 d 20 h 14 m 11 s  (Wl: 31 elements; KWl: 30elements; NetS: 55 elements; Alrm: 17 elements; Proc: 131 elements; Oth: 5 elements; CPU: 5 elements)
Edit: But the ratio from awake
to screen on
still doesn’t look right.
