Here you can find the official FP4. Fairphone OS Release Notes
Android 12
Current release-Forum Topic
Software Version: FP4.SP21.B.048.20230215
Security Patch Level: 5th of February, 2023
Update size: 374.79 MB
List of changes:
Experience-related improvements
The automatic minimum brightness has been reduced, following the feedback received from our users.
Other improvements
- A bug that was causing the Bluetooth audio to stop working when the aptX HD codec was selected, has been fixed.
- Third-party apps are now also able to access and use the wide-angle sensor of the camera module.
First Android 12 release 1st Feb 2023
Android 11 releases (FP4):
Summary
FP4.FP4G.A.170.20220920
- Release Date : 2022.10.03
- Security Patch Level: 5th of September, 2022
- Change log:
- Fixed an issue that was causing a debug folder to appear on the root of the data partition, also on non-debug software.
- Fixed an issue that was causing the thumbnails of media to appear slowly when using Windows 10 File Explorer.
- The Wi-Fi module will now prioritize 5 GHz frequency over 2.4 GHz on the same network, when available.
- The network compatibility for several carriers has been enhanced.
- Forum Thread: Software update: FP4.FP4G.A.170.20220920
- Download : -
FP4.FP44.A.149.20220722
- Release Date : 2022.08.08
- Security Patch Level: 5th of July, 2022
- Change log:
- The camera’s auto-focus and white balance features have been improved.
- Forum Thread: Software update: FP4.FP44.A.149.20220722
- Download : -
FP4.FP40.A.142.20220628
- Release Date : 2022.07.11
- Security Patch Level: 5th of June, 2022
- Change log:
- Camera tuning update.
- Forum Thread: Software update: FP4.FP40.A.142.20220628
- Download : -
FP3W.A.128.20220516
- Release Date : 2022.05.30
- Security Patch Level: 5th of May, 2022
- Change log:
- Added automatic power-off when idle in Fastboot mode for 10 minutes.
- Improved performance of microphone in Signal app.
- Improved retention of mobile network settings after update.
- Forum Thread: Software Update: Fairphone 4 FP3W.A.0128.20220516
- Download : -
FP3V.A.116.20220414
- Release Date : 2022.04.25
- Security Patch Level: 5th of April, 2022
- Change log:
- Improved OIS calibration experience after installing new camera module. [4]
- Forum Thread: Software update: FP4.FP3V.A.116.20220414
- Download : -
FP3T.A.107.20220316
- Release Date : 2022.04.04
- Security Patch Level: 5th of March, 2022
- Change log:
- Addressed an issue that was causing, under certain conditions, the microphone to record with a lower volume than normal in some third-party apps.
- Addressed an issue that was causing pictures taken in 48MP mode to be overexposed, in certain conditions.
- The “TCO Certified” logo has been added to the boot-up screen.
- Addressed multiple minor issues that were causing, in rare conditions, certain apps/services of the device to crash or to be unresponsive.
- Forum Thread: Software update: FP4.FP3T.A.0107
- Download : -
FP3S.A.103.20220221
- Release Date : 2022.03.04
- Security Patch Level: 5th of February, 2022
- Change log:
- MyFairphone app updated to version 2.1.5
- Addressed an issue that was causing an incorrect message to be shown when trying enable OEM unlocking with no internet connection.
- The default date has been changed to 11/11/2021 during the Setup Wizard (OOBE) when no internet connection is available.
- Forum Thread: Software Update: FP4.FP3S.A.103.20220221
- Download : -
FP3R.A.099.20220112
- Release Date : 2022.02.04
- Security Patch Level: 5th of December, 2021
- Change log:
- Camera performance improvements [3]
- Fingerprint sensor performance improvements [3]
- Fixed an issue that was causing Google Play system updates to be unavailable.
- Fixed an issue that was causing errors during SD card formatting and use.
- Forum Thread: Update FP3R.A.099
- Download : -
FP3Q.A.094.20211213
- Release Date : 2021.12.21
- Change log:
- Forum Thread: FP4, security update, december 5 2021, called FP3Q.A.094 though
- Download : -
FP3N.A.091.20211118
- Release Date : 2021.11.29
- Security Patch Level: 5th of November, 2021
- Change log:
- Added the possibility to hide/show the network name on the status bar when on the main screen.
- Fixed some incorrect animations during the Setup Wizard.
- Forum Thread: 🇩🇪 FP4 // SW Update // FP3N.A.091
- Download : -
FP4.FP3I.A.081.20211026 [2]
- Release Date : ?
- Security Patch Level: 5th of September, 2021
- Change log: ?
- Forum Thread: -
- Download : -
A.067 [1]
- Release Date : ?
- Security Patch Level: ?
- Change log: ?
- Forum Thread: -
- Download : -
