Updating LineageOS 16.0 for microG via TWRP + feature test
I dont know how to fix it :slight_smile:
Chris
Okay. :slight_smile:
Update Installed via custom TWRP 3.2.3 … although currently no luck with encryption.
TWRP 3.3.1-0 (Releases) seems to have trouble with encryption in general.
  • lineage-16.0-20190708-microG-FP2.zip (Changelog)
    • Security patch level:
      up to date (Settings - Security & location - Trust)
      5 July 2019 (Settings - About phone - tap on Android version)
    • Vendor security patch level:
      out of date (Settings - Security & location - Trust)
      1 April 2018 (Settings - About phone - tap on Android version)
The following things work for me so far:
  • call / be called
  • send SMS / receive SMS
  • internet via WiFi
  • internet via mobile network
  • location
  • compass
  • screenshot
  • main camera (new module) works correctly with Open Camera, stock camera App not checked, didn’t operate the flash correctly last time I checked.
  • main camera (new module) video recording
  • selfie camera (new module)
  • selfie camera (new module) video recording with stock camera App not checked, worked correctly last time I checked, Open Camera records only black if surrounding light is too dark or changes into too dark while you move.
  • USB connection to PC / MTP
  • alarm (no alarm sounding with volume set too low.)
  • MyPhoneExplorer 1.8.12
  • Root access (Settings - System - Advanced - Developer options - Root access)
  • USB OTG
  • WiFi hotspot
  • Bluetooth (data connection, music playback … pairings survived the update)
  • FM radio
  • weather (Yorecast with my own OpenWeatherMap API Key, Weather Widget)
For reporting bugs see the bottom of this page.
Just a FYI. With LOS 16 + microG + latest TWRP I did a clean install without encryption. Then I enabled encryption. LOS updates work, flawless (not in the very beginning). The only issue I got is that I need to mount from terminal + OTG + USB key if I want to install say Magisk. Cause for the life of me I can’t find the sdcard mount point (if it even exists). In the past I needed to do the same for the LOS update.
At long last, there’s an OpenWeatherProvider for 16.0 at https://download.lineageos.org/extras, but I didn’t try it yet.
Edit 1 day later: It works :+1: .
  • lineage-16.0-20190812-microG-FP2.zip (Changelog)
      1 August 2019 (Settings - About phone - tap on Android version)
  • call / be called
  • internet via WiFi
  • location
  • compass
  • screenshot
  • USB OTG
  • WiFi hotspot
  • FM radio
  • weather (OpenWeatherProvider with my own OpenWeatherMap API Key)
    1 April 2019 (Settings - About phone - tap on Android version)
Think its 2018, isnā€˜t it?
We all would be happy if not, right?
Thanks for noticing, corrected.
Curse you, copy and paste :slight_smile: …
Don’t install lineage-16.0-20190827-microG-FP2.zip, as it will not boot, because it is based on a regular LineageOS build which doesn’t boot.
  • lineage-16.0-20190819-microG-FP2.zip (Changelog)
  • call / be called
  • internet via WiFi
  • location
  • compass
  • screenshot
  • USB OTG
  • WiFi hotspot
  • FM radio
  • lineage-16.0-20190908-microG-FP2.zip (Changelog)
  • call / be called
  • internet via WiFi
  • location
  • compass
  • screenshot
  • USB OTG
  • WiFi hotspot
  • FM radio
  • weather (OpenWeatherProvider with my own OpenWeatherMap API Key … I don’t get a connection to OpenWeatherMap quite often lately … so updates to the weather status are still coming in, but not every time they should according to schedule)
Can also report LOS with microG works once more, like a breeze. Just had issue that my microSD was not recognized after boot, and device was hot. After putting it off for a while and starting it, problem went away.
In case anybody wonders … the 20190910 build is still at Security patch level 1 August 2019, so if you are on 20190908 there’s one less reason to bother.
  • lineage-16.0-20190917-microG-FP2.zip (Changelog)
      5 September 2019 (Settings - About phone - tap on Android version)
  • call / be called
  • internet via WiFi
  • location (Edit: had some temporary problems reported starting here, which turned out to be unrelated to the build)
  • compass
  • screenshot
  • USB OTG
  • WiFi hotspot
  • FM radio
Have you tried (Mira)cast recently?
No. I would have to go look whether I even have a device to test this with.
Edit: I’m not able to test this.
My AV receiver doesn’t do Miracast. And my Samsung TV (2010 C-Series) could perhaps do it with an additional App, but the internet is inconclusive about this, and I make it a point to not hook my TV up to the internet anyway.
As I don’t have a use case myself, I’m not motivated enough currently to get a Miracast dongle only for testing.
  • lineage-16.0-20191015-microG-FP2.zip (Changelog)
      (Regular LineageOS got October 5 patch level early today, so I thought I’d give it a shot … too soon.)
  • call / be called
  • internet via WiFi
  • location
  • compass
  • screenshot
  • USB OTG
  • WiFi hotspot
  • FM radio
:warning: If you are updating to the new version of microG (2.9) via F-Droid the location services will stop working and microG starts to crash.
I hope it will soon be solved, because I cannot revert the update :sweat_smile:
You can revert to system version:
Settings -> Apps & notifications -> See all … apps -> microG Services Core -> three dot menu -> uninstall updates.
Afterwards you must configure your backends again.
I did that, but keep in mind that you also have to re-register all the apps that need GCM services! (-> by reinstalling them)
  • lineage-16.0-20191022-microG-FP2.zip (Changelog)
      5 October 2019 (Settings - About phone - tap on Android version)
  • call / be called
  • internet via WiFi
  • location
  • compass
  • screenshot
  • USB OTG
  • WiFi hotspot
  • FM radio
  • weather (OpenWeatherProvider with my own OpenWeatherMap API Key … connection to the service seems very unreliable lately)
