same here, I’d like to know what the official response is when it comes…before I order a new module…have same prob as everyone here, no focus on close shots.
If you’re bold you can tried to create you own module now Just try to swap the sensor with something from the same family.
I also opened a support ticket and uploaded a video. 1 week later I phoned in an they sent me a replacement module free of cost.
Same problem here, especially when the light is low.
What about the people who received a new module ? Did it solve the focus problem ?
On my side, i got an answer from the support saying that this issue is known and replacing the module won’t fix it… they think it’s a software problem and they said they’re working on it.
Yes, the new module solved my problem. However, my problem was different from what you describe. My camera never focused at all, it was completely independant from the light condition. Besides a working focus, picture quality did not improve with the new camera module.
Just got my new camera module. Focus problem solved.
2 weeks from writing the service request until delivery of the camera module and the change of the module is really easy.
Thank you FP support team
Glad to have my Fairphone.
I think I found the root cause of the focusing issue.
After reading through all the post here I concluded it has to be an hardware problem, not wanting to wait for a long time and being without a phone I descided to open the phone and check the camera module for hardware issues. My first suspect was bad contacts but they all looked ok. After removing the camera sensor out of the module housing I noticed that the sticky foam used to mount the sensor in the housing was the real issue. The piece of foam has been misalligned and physically limiting the movemont of the camera lens causing the focus problems. Carefully removing it and alligning it how it should be fixed all my focus issues. Now my camera works like a charm.
So the good news here is, it’s easy to fix. To bad that a few cents of double sticking foam caused all these issues.
This definitely did the trick for me, thanks @Npsm! Focussing now works a lot better than before! Just for those of us, who need some help with disassembling the camera module…
First remove the camera module as described in:
(you can change the language settings in the top menu)
As soon as you have removed the camera module, you will see one more tiny screw that needs to be removed to disassemble the camera module:
Also remove the latches (2 on one side and one more on the other side):
Then you should be able to easily remove the back cover of the camera module (perhaps you might want to use a tiny screwdriver as a lever). The open camera module should look like this (the actual camera within the red circle):
You will actually need a screwdriver now to carefully remove the camera from its mount as it is firmly attached to the mount by sticky foam (the foam that is actually causing the focus problems). Once removed from the mount, you can realign the sticky foam so that it does no longer disturb the movement of the lens of the camera. It should look like this in the end:
Reassemble all the parts carefully and enjoy your new FP2 camera feeling:
(taken on my FP2 with the realigned sticky foam)
Thanks to @Npsm for this great solution!
Nice one. I wonder if someone from FP will confirm this. Can you tell us if it is just too much foam or if the foam is just in the the wrong spot? I can’t really tell from the pictures.
Sorry, my old digital camera is not too good… No, the foam is simply misaligned…
So right in the middle & center at the front of the camera sensor is the right place, right?
Updated, so that nobody gets confused.
Yes, so that the hole in the foam sits just over the camera lens… Otherwise the foam jams the lens… I have edited the respective picture in my above post… It should become pretty obvious once you have opened the module …
Jochen17, Great guide on fixing it!
Totally worked! Thanks a lot!
On my side, taking pictures works perfectly. The focus problem occurs only when i record some video. Does anyone else have the same issue ?
Just in case you haven’t found this topic using the search function in the meantime:
Exactly ! I don’t know why i didn’t find this topic before… It’s seems a lot of people have the same issue as me. Thanks for the link.
Thank you so much for this fix!
It was quite easy and camera now works perfectly!
Hey there, you will also find relevant information about how to proceed in the support article:
Please be careful with doing this.
Opening (and performing self-repair on) modules voids the warranty of the specific module.
