FP4 Replacement Screws
According to a tweet found by @urs_lesse, FP support will not provide replacement screws.
I ordered some screws for the FP3 and one set also contains M1.4x3.5mmm what would be the size oft the FP4 screws. However, the measurement of the screws seem a bit odd, because the indicated lenght seem to be the total lenght and not the thread only (further info here). As I have no FP4 and nothing to properly measure those mini screes, is there anyone with an FP4 who would be willing to test the screws to see if they fit, then I would send a few?
I will be measure the screws of my fp4 tomorrow and give the answer here …
Hmmm… measuring yours does not help to find out if the potiential replacement screws I have here would fit. The size of M1.4x3.5mm is from the FP tweet so this should not be the question, still it doesnt harm to verify :blush:
OK. You can send me one, too. If you want and I can test it for you. No problem. :wink:
There are black and silver screws in the FP4
Both have the same size
M1.4x5mm
Thats a big difference to what was stated on Twitter, so good you measured it.
In general, the length of screws with countersunk head (flat on top, cone-shaped, tapering towards the thread, meant to more or less disappear flush in the component) is measured including the head. Screws with a raised head (cylinder head, filister head, pan head etc., which stays outside of the component) are measured without the head.
(Source: Metric Bolt Measuring Guide | How to measure a Fastener | Pro-Bolt)
:arrow_right: Also, everything said on screwdriver types applies here as well.
OK, in FP4 Countersunks are used and so the total length is 5mm.
Just to set the record straight:
I will ask our CS team to publish these specs somewhere on the support pages as well.
Cheerio
Thanks @gabrieleb . Don’t forget to mention the proper screwdriver tip (PH00 ?) on the support pages :wink:
Has somebody found a shop for such screws? My research so far did only provide screws with thicker heads.
Like this, maybe
https://www.amazon.com/M1-4-Machine-Stainless-Phillips-M14-45-M-SS-TP/dp/B01MDUM4FP
sorry unavailable :frowning:
The screws mentioned here as too long for the FP3 seem to fit as replacement for the FP4
Hey hey,
I am trying to find some screws for my fp4 but i am not finding any. Did someone find a website. I saw the amazon link and they have stock but i dont feel like spening money on 100 screws, i need like 4:p
i used these to google screws.
  • Thread Size: M1.4
  • Threaded Length: 4.5mm
  • Head: Thin Pan Head Phillips Drive
It seems they usually come as 4 or 5 and not 4,5 (Am I doing something wrong?)
even phoneshops don’t have the screw
Fairphone will soon offer FP5 screws. Let’s wait for the specifications, but at least the silver screws might be a fit for the FP4 (modules, but perhaps not the screen) as well, see my photo here:
And welcome here in the Community :+1:
Not that cheap…
ich habe es bei Aliexpress bestellt und die passen. Irritierenderweise hat es auf Aliexpress nicht für jeden Schraubentyp das passende Bild, aber man erhält die richtigen Schrauben, wenn man das entsprechende Feld anwählt: https://www.aliexpress.com/item/32486381834.html
Hi all,
sorry for addressing this topic again. I see now Fairphone is providing Replacement Screw Sets for FP5 are these sets also usable for FP4?
If not Fairphone should think providing sets for FP4 an maybe FP3(+) too.
Thanks,
Timo
