Hi and welcome to the community forum
A quick search will find you a valuable topic by urs.
If you need the silver coloured ones then the FP5 spare screws are reported to fit the FP4 for the screen.
Thanks @OldRoutard. I knew the Screws for Fairphone 1, FP2, FP3, FP4, FP5 guide already but I didn’t see any FP5 ‘official’ screw specs there.
It’s good to know that the silver (required) screws will fit.
Thanks.
Hello @OldRoutard,
you there right and I hereby confirm that the silver colored screws
from the FP5 replacement kit are fitting for FP4 too.
My FP4 now charges again and to replace the USB-C connector was quite
easy even for me with high vision disability (50% with glasses).
Thanks again,
Timo
(Attachment timo_gerke.vcf is missing)
