End of obligatory piece of text that is part of all topics in which people talk about putting unofficial batteries in their Fairphones.
Overview/comparison of batteries
| Model | available | correct size | capacity | ||
| F1B101 / F1B102 | 2000/2100mAh |
Batteries that fit FP1 exactly
Original battery (sold out)
There are 2 battery types:
Model: F1B101/ F1B102
Dimension: 6,1x5,3x0,45cm/6,1x5,3x0,45cm
Capacity: 2000mAh/2100mAh
Voltage: 3,7V / 3,8V
Producer: Fenghua / 3Sun/Maxell
Assembled: Guandong, China/Shenzhen,China
Remark:
Some of the first type (F1B101) batteries from Fenghua tended to “bloat”. batteryguide
Webshop
Official Fairphone 1 battery - sold out
Changhong HonPhone V9 (same design, available again (rebuilt))
Model: W20S ?
Dimension: 6,1x5,3x0,45cm?
Capacity: 2000mAh
Voltage: 3,7V
Producer: Fenghua?
Webshops
AliExpress - HonPhone battery - sold out!
Menostader.de - HonPhone battery - sold out!
AliExpress – Stonering battery | rebuilt HonPhone – available
AliExpress – Wisecoco battery | rebuilt HonPhone – available
(there are more shops/sellers within AliExpress that offer these battery types – the two mentioned are just examples; see reviews soon)
Batteries that don’t fit exactly, but have been tried by forum users:
use at your own risk! Wrong batteries can damage your phone and overheat! ![]()
Huawei HB5N1H - 1500mAh and 1800mAh
use at your own risk!!!
battery has not the same length as FP1 original battery!
Testreport from Hermann
battery temperature values are not correct - possible overheat will NOT be detected!!!
Testreport from Stefan and Karsten
Model: HB5NH1
Dimension: 51,3x50,8x5,6mm (more details)
Capacity: 1500 / 1800mAh
Voltage: 3,7V
Producer: ?
Webshops
HB5N1H battery is sold by e.g.
VHBW/Electropapa
and other battery replacement companies.
spacers are required!!! Do not use any flamable materials inside the phone! ![]()
Heat resistent rubber (e.g. FPM, see picture above) as it is used in laptops as spacer for harddrives is better than flamable materials!
Samsung EB-L1G6LLU 2100mAh
Useful Links:
