Updating LineageOS 15.1 for microG via TWRP + feature test
Edit: I just saw there’s a preliminary new modem.zip, but I didn’t use that yet …
So … you can flash the new modem files, and you will get the fancy fastboot mode LED and vibration, and you can turn on the phone again while charging, but if you want the modem files for fixing e.g. the shutdown bug, those fixes are somewhere else, as explained here …
https://forum.fairphone.com/t/fp2-fairphone-os-fairphone-open-19-02-1/48239/30?u=anotherelk
And in case you want to try flashing the Fairphone (Open) OS boot.img to a LineageOS installation …
Update Installed via TWRP 3.2.3-0 (Releases)
The following things work for me so far:
  • call / be called
  • send SMS / receive SMS
  • internet via WiFi
  • internet via mobile network
  • location
  • compass
  • screenshot
  • main camera (new module) works correctly with Open Camera, stock camera App not checked, didn’t operate the flash correctly for ages.
  • main camera (new module) video recording
  • selfie camera (new module)
  • selfie camera (new module) video recording with stock camera App not checked, worked correctly last time I checked, Open Camera records only black if surrounding light is too dark or changes into too dark while you move.
  • USB connection to PC / MTP
  • alarm
  • MyPhoneExplorer 1.8.11
  • Root access (Settings - Developer Settings - Root Access)
  • USB OTG
  • WiFi hotspot
  • Bluetooth (data connection, music playback … pairings survived the update)
  • FM radio
  • weather (Your local weather with my own OpenWeatherMap API Key, Weather Widget)
For reporting bugs see the bottom of this page.
And here is a Settings reference.
There was no new update yesterday right?
The LineageOS community seems to be in the process of rescheduling builds, because they recently set 15.1 builds back to weekly in order to be able to have nightly 16.0 builds (for supported devices) …
There’s no new LineageOS for microG build for the Fairphone 2 yet.
Lineage+Microg update arrived yesterday. Updated today :slight_smile:
  • modem-19.02.1_2019-03-04.zip
    Baseband version: 4437.1-FP2-0-08 (Settings - System - About phone)
    How to make your own modem.zip
    • The phone now turns on when pressing the power button while charging.
    • Fastboot mode is now recognizable by three vibrations when starting as well as by the LED blinking blue continuously.
  • lineage-15.1-20190309-microG-FP2.zip (Changelog)
    Security patch level: 05 Feb 2019 (Settings - System - About phone)
    Vendor security patch level: 01 Apr 2018 (Settings - System - About phone)
    • The flashlight workaround is no longer necessary for actions in connection with the new camera module, e.g. turning off the phone, rebooting into recovery from Android, starting encryption.
  • call / be called
  • internet via WiFi
  • location
  • compass
  • screenshot
  • alarm
  • USB OTG
  • WiFi hotspot
  • FM radio
  • call / be called
  • internet via WiFi
  • location
  • compass
  • screenshot
  • alarm
  • USB OTG
  • WiFi hotspot
  • FM radio
  • call / be called
  • internet via WiFi
  • location
  • compass
  • screenshot
  • alarm
  • USB OTG
  • WiFi hotspot
  • FM radio
  • call / be called
  • internet via WiFi
  • location
  • compass
  • screenshot
  • alarm
  • USB OTG
  • WiFi hotspot
  • FM radio
TWRP 3.3.0-0 is out, but it has trouble with encryption.
  • lineage-15.1-20190508-microG-FP2.zip (Changelog)
    16.0 builds will be out from May 12 on, so this is most likely the final 15.1 build.
    Security patch level: 05 Apr 2019 (Settings - System - About phone)
  • call / be called
  • internet via WiFi
  • location
  • compass
  • screenshot
  • alarm
  • USB OTG
  • WiFi hotspot
  • FM radio
  • weather (Yorecast, formerly “Your local weather”, with my own OpenWeatherMap API Key, Weather Widget)
