LineageOS 15.1 settings reference (Wiki)
LineageOS 15.1 settings (in several parts due to 42.000 character limit)
Settings
  • Network & Internet (Wi-Fi, Mobile, Data Usage, Hotspot)
    • three-dot menu
      • Reset Wi-Fi, mobile & Bluetooth
        • RESET SETTINGS
    • Wi-Fi (direct On/Off)
      • On/Off
      • (list of available Wi-Fi networks)
      • Add network
      • Wi-Fi preferences
        • Turn on Wi-Fi automatically (To use, select a network rating provider) (On/Off)
        • Open network notification (Notify when a high-quality public network is available) (On/Off)
        • Advanced
          • Install certificates
          • Network rating provider
            • None / Google
          • Wi-Fi Direct
            • RENAME DEVICE (top right)
          • WPS Push Button
          • WPS Pin Entry
          • MAC address (info)
          • IP address (info, IPv4 and IPv6)
      • Saved networks
        • (tap on network)
          • FORGET
        • Add network
    • Mobile network
      • Mobile data (Access data using mobile network) (On/Off)
      • Roaming (Connect to data services when roaming) (On/Off)
      • Data usage
        • cogwheel
          • Billing cycle
          • Set data warning (On/Off)
          • Data warning
          • Set data limit (On/Off)
          • Data limit
        • (tap on App)
          • Wi-Fi data (Enable usage of Wi-Fi data) (On/Off)
          • Mobile data (Enable usage of mobile data) (On/Off)
          • Background data (Enable usage of mobile data in the background) (On/Off)
          • Unrestricted data usage (Allow unrestricted data access when Data Server is on) (On/Off)
      • Advanced
        • Preferred network type
          • LTE / 3G / 2G
        • Automatically select network (On/Off)
        • Network
          • (choice of available networks)
        • Access point names
          • “+” (Edit access point)
            • three-dot menu
              • Save
              • Discard
          • three-dot menu
            • Reset to default
          • (choice of APNs)
    • Data usage
      • three-dot menu
        • Mobile network (link)
      • (tap on usage bar)
        • Set data usage warning
      • Data Saver
        • On/Off
        • Unrestricted data
          • three-dot menu
            • Show system / Hide system
          • (list of Apps with On/Off toggle for unrestricted data)
      • Mobile data (On/Off)
      • Mobile data usage (link)
      • Billing cycle (link)
      • Wi-Fi data usage (link)
      • Network restrictions
        • (tap on metered Wi-Fi network)
          • Automatic / Metered / Not metered
    • Hotspot & tethering
      • USB tethering (Share phone’s Internet connection via USB) (On/Off)
      • Wi-Fi hotspot (On/Off)
      • Set up Wi-Fi hotspot
      • Bluetooth tethering (Share phone’s Internet connection via Bluetooth) (On/Off)
    • SIM cards
      • SIM slot 1 (On/Off)
      • SIM slot 2 (On/Off)
      • (Preferred SIM for) Mobile data
        • (name of SIM card 1) / (name of SIM card 2) / Ask every time
      • (Preferred SIM for) Calls
      • (Preferred SIM for) SMS messages
      • VPN
          • Edit VPN profile
        • (tap on VPN)
      • Aeroplane mode (On/Off)
  • Connected devices (Bluetooth, Cast)
    • Bluetooth (direct On/Off)
      • (tap on paired device to connect)
      • cogwheel for paired device
        • Name
        • Use for … (several options dependent on device) … (On/Off)
        • Forget
      • Pair new device
      • Device name (Rename this device)
        • (enter text)
      • Received files
      • Phone’s Bluetooth address (info)
    • Cast
      • three-dot menu
        • Enable wireless display
    • Printing
      • (tap on printing service)
        • three-dot menu
          • Add printer
        • On/Off
      • Add service
    • USB
      • Charge this device / Transfer files / Transfer photos (PTP) / Use device as MIDI
  • Apps & notifications (Permissions, default apps)
    • (tap on App)
      • UNINSTALL or DISABLE
      • FORCE STOP
      • App notifications
        • On/Off
        • Allow notification dot (On/Off)
        • (App-specific settings)
      • Permissions
        • three-dot menu
          • All permissions (info)
        • (App-specific permissions) (On/Off)
      • Storage
        • CLEAR DATA or MANAGE SPACE
        • CLEAR CACHE
      • Data usage
      • Battery
        • DISABLE
        • FORCE STOP
        • Background activity (App can run in the background when not in use) (On/Off)
        • Battery optimisation (Optimising battery use)
          • arrow down
            • Not optimised
            • All apps
          • (tap on App)
            • Optimise (Recommended for better battery life)
            • Don’t optimise (May drain your battery more quickly)
      • Open by default
        • Open supported links
          • Open in this app
          • Ask every time
          • Don’t open in this app
        • Supported links
        • CLEAR DEFAULTS
      • Memory
        • three-dot menu
          • Force stop
      • Modify system settings
        • Allow modify system settings (On/Off)
    • Notifications
      • App notifications
        • three-dot menu
        • arrow down
          • All apps / Apps: Turned off
        • (tap on App)
          • On/Off
      • On the lock screen
        • Show all notification content / Hide sensitive notification content / Don’t show notifications at all
      • Allow notification dots (On/Off)
      • Heads-up (Display priority notifications in a small floating window) (On/Off)
      • Default notification sound
        • (sound selection)
      • Battery light
        • Battery light (On/Off)
        • Pulse if battery low (On/Off)
        • Colours - Battery low
          • (colour selection)
        • Colours - Charging
        • Colours - Fully charged
        • Brightness levels - Normal
          • (percentage)
          • RESET
        • Brightness levels - Do Not Disturb
          • (percentage)
          • RESET
      • Notification light
        • Notification light (On/Off)
        • Choose colours automatically (On/Off)
        • Default
          • Pulse length and speed
            • Always on / Very short / Short / Normal / Long / Very Long
            • Very fast / Fast / Normal / Slow / Very slow
          • RESET
          • (percentage)
          • RESET
          • (percentage)
          • RESET
        • Advanced - Lights with screen on (On/Off)
        • Advanced - Use custom values (On/Off)
          In case of On:
          • Phone - Missed call
            • RESET
          • Phone - Voicemail
            • RESET
          • “+” (top right, add per app control)
    • App permissions
      • (tap on permission)
        • three-dot menu
        • (list of Apps) (On/Off)
        • Additional permissions
    • Advanced
      • Default apps
        • Assist & voice input
          • Assist app
            • (App selection)
          • Use text from screen (Allow the assist app to access the screen contents as text) (On/Off)
          • Use screenshot (Allow the assist app to access an image of the screen) (On/Off)
          • Voice input
        • Browser app
          • (App selection)
        • Home app
          • (App selection)
        • Phone app
          • (App selection)
        • SMS app
          • (App selection)
        • Weather
          • ADD WEATHER PROVIDER
        • Opening links
          • Instant app (Open links in apps, even if they’re not installed) (On/Off)
          • Instant apps preferences
            • Instant Apps account (Choose a Google Account to use with Instant Apps)
          • (tap on App)
              • Open in this app / Ask every time / Don’t open in this app
              • Supported links
                • (info)
              • Other defaults (info)
              • CLEAR DEFAULTS
      • Emergency alerts
        • Allow alerts (Receive emergency notifications) (On/Off)
        • AMBER alerts (Child abduction ermergency bulletins) (On/Off)
        • Extreme threats (Extreme threats to life and property (On/Off)
        • Severe threats (Severe threats to life and property (On/Off)
        • Emergency alert history
          • three-dot menu
            • Settings (link)
        • Vibrate (On/Off)
        • Alert reminder sound
          • Once / Every 2 minutes / Every 15 minutes / Off
        • Developer options - ETWS test broadcasts (Test broadcasts for Earthquake Tsunami Warning System) (On/Off)
        • Developer options - CMAS test broadcast (Test broadcasts for Commercial Mobile Alert System) (On/Off)
        • Developer options - Show opt-out dialogue (Show an opt-out dialogue after displaying the first CMAS alert (other than Presidential Alert).) (On/Off)
        • Developer options - Speak alert message (Use text-to-speech to speak alert messages) (On/Off)
        • Developer options - Use full volume (Ignore volume and do not disturb preferences) (On/Off)
      • Special app access
        • Battery optimisation (link)
        • Device admin apps
          • (list of apps) (On/Off)
        • Do Not Disturb access
        • Display over other apps
          • three-dot menu
          • (tap on App)
            • On/Off
        • VR helper services
          • three-dot menu
          • (tap on App)
            • On/Off
        • Notification access
        • Picture-in-picture
          • (tap on App)
            • On/Off
        • Premium SMS access
        • Unrestricted data
          • three-dot menu
        • Usage access
          • three-dot menu
          • (tap on App)
            • On/Off
        • Install unknown apps
          • three-dot menu
          • (tap on App)
            • On/Off
  • Battery
    • three-dot menu
      • Show full device usage / Show app usage
    • (tap on percentage or battery visualisation)
      • (battery usage projection graph)
      • Breakdown since last full charge (info)
    • Last full charge (info)
    • Screen usage since full charge (info)
    • Battery saver and performance (Adjust power saving features and device performance)
      • Extreme power saver (Restrict device performance and background activity to save power) (On/Off)
      • Automatic power saver
        • Never / 5% / 15% / 25%
      • Performance profile
        • Power save / Efficiency / Balanced / Quick / Performance
      • Battery percentage (Show battery percentage in status bar) (On/Off)
      • Adaptive brightness (Optimise brightness level for available light) (On/Off)
      • Sleep
        • 15 seconds / 30 seconds / 1 minute / 2 minutes / 5 minutes / 10 minutes / 30 minutes
      • Ambient display
        • New notifications (Wake screen when you receive notifications) (On/Off)
      • (tap on system component or App according to three-dot menu choice)
        • (info)
  • Display (Wallpaper, sleep, font size)
    • Brightness level
      • (percentage slider)
    • LiveDisplay (Optimise your screen based on the time of day and ambient conditions to improve readability and reduce eyestrain)
      • Display mode
        • Automatic / Off / Day / Night
      • Colour temperature
        • Day (Kelvin slider)
        • Night (Kelvin slider)
        • RESET
      • Colour calibration (Calibrate on-screen colours)
        • Red (percentage slider)
        • Green (percentage slider)
        • Blue (percentage slider)
        • RESET
    • Wallpaper
      • (list of wallpaper sources)
    • Advanced
      • Style (Choose system colours)
        • Style
          • Automatic (wallpaper) / Automatic (time of day) / Light / Dark
        • Accent colour
          • Default / Tomato / Cherry / Lavender / Blueberry / Cyan / Forest / Pumpkin / Banana / Cocoa
        • Dark mode
          • Default / Black
        • Automagic (Tune the style to match your wallpaper)
          • Suggested style: (automatic combination) (CANCEL/APPLY)
      • Sleep (link)
      • Rotation settings
        • Auto-rotate screen (On/Off)
        • Rotate lock-screen (On/Off)
        • Rotation modes - 0 degrees (On/Off)
        • Rotation modes - 90 degrees (On/Off)
        • Rotation modes - 180 degrees (On/Off)
        • Rotation modes - 270 degrees (On/Off)
      • Font size
        • Small / Default / Large / Largest
      • Display size
        • Smallest / Smaller / Small / Default / Large / Larger
      • Expanded desktop (Expand your desktop space by hiding the status bar, navigation bar, or both)
        • On/Off
          -(tap on App)
          • Hide nothing / Hide status bar / Hide navigation bar/ Hide both
      • Screen saver
        • Current screen saver
          • (choice of screen savers)
        • When to start
          • While charging / While docked / While charging or docked / Never
        • START NOW
      • Ambient display (link)
      • Tap to sleep (Double-tap on the status bar or lockscreen to turn off the display) (On/Off)
      • Wake on plug (Turn the screen on when connecting or disconnecting a power source) (On/Off)
  • Sound (Volume, vibration, Do not disturb)
    • Media volume (slider)
    • Alarm volume (slider)
    • Ring volume (slider)
    • Notification volume (slider)
    • Link ring & notification volumes (On/Off)
    • Increasing ring volume (On/Off)
      • Start volume (slider)
      • Ramp-up time (seconds slider)
    • Also vibrate for calls (On/Off)
    • Do not disturb preferences
      • Priority only allows (Reminders, Events, Alarms, Selected callers)
        • Reminders (On/Off)
        • Evens (On/Off)
        • Alarms (Alarms are always a priority and make sound) (On/Off disabled)
        • Messages
          • From anyone / From contacts only / From starred contacts only / None
        • Calls
        • Repeat callers (If the same person calls a second time within a 15-minute period, allow it) (On/Off)
      • Block visual disturbances
        • Block when screen is on (Prevent notifications silenced by Do not disturb from peeking or popping on screen) (On/Off)
        • Block when screen is off (Prevent notifications silenced by Do not disturb from turning on the screen or pulsing the notification light) (On/Off)
      • Automatic rules - Weekend (direct trashcan)
        • trashcan
        • On/Off
        • Rule name
          • (enter text)
        • Days
          • Monday (On/Off)
          • Tuesday (On/Off)
          • Wednesday (On/Off)
          • Thursday (On/Off)
          • Friday (On/Off)
          • Saturday (On/Off)
          • Sunday (On/Off)
        • Start time
          • (time selection)
          • keyboard / clock (toggle time input method)
        • End time
          • (time selection)
          • Priority only / Alarms only / Total silence
        • Alarm can override end time (Stop at the end time or next alarm, whichever comes first) (On/Off)
      • Automatic rules - Weeknight (direct trashcan)
        • trashcan
        • On/Off
        • Rule name
          • (enter text)
        • Days
          • Monday (On/Off)
          • Tuesday (On/Off)
          • Thursday (On/Off)
          • Friday (On/Off)
          • Saturday (On/Off)
          • Sunday (On/Off)
        • Start time
          • (time selection)
        • End time
          • (time selection)
      • Automatic rules - Event (direct trashcan)
        • trashcan
        • On/Off
        • Rule name
          • (enter text)
        • During events for
          • Any calender
          • (list of calendar accounts)
        • Where reply is
          • Yes, Maybe or Not replied / Yes or Maybe / Yes
      • Automatic rules - Add more
        • (add a new rule)
    • Phone ringtone
      • (sound selection)
    • Advanced
        • (sound selection)
      • Default alarm sound
        • (sound selection)
      • Dial pad tones (On/Off)
      • Screen-locking sounds (On/Off)
      • Charging sounds
        • Enable (Play a sound when connecting or disconnecting a power source) (On/Off)
          • Vibrate (On/Off)
          • Notification sound
            • (sound selection)
      • Touch sounds (On/Off)
      • Vibrate on tap (On/Off)
      • Volume adjustment sounds (On/Off)
      • Emergency alerts (link)
  • Storage
    • Internal shared storage
      • FREE UP SPACE
      • Storage manager (On/Off)
      • Photos & videos
        • three-dot menu
        • (tap on App) (link to App’s storage settings)
        • (tap on folder)
          • (view folder)
      • Music & audio
        • three-dot menu
          • Sort by name / Sort by size
        • (tap on folder)
          • (view folder)
      • Games
        • three-dot menu
      • Movie & TV apps
        • three-dot menu
        • (tap on folder)
          • (view folder)
      • Other apps
        • three-dot menu
      • Files (opens Files App)
      • System (info)
    • Portable storage - sdcard1 (direct eject)
      • (opens Files App)
  • Security & privacy (Screen lock)
    • Screen lock
      • None / Swipe / Pattern / PIN / Password
      • direct cogwheel
        • Automatically lock
          • Immediately / 5 seconds / 15 seconds / 30 seconds / 1 minute / 2 minutes / 5 minutes / 10 minutes / 30 minutes
        • Power button instantly locks (Except when kept unlocked by Smart Lock) (On/Off)
        • Directly show PIN entry (Skip the swipe to unlock screen and immediately begin PIN entry) (On/Off)
        • Lock screen message
          • (enter text)
        • Scramble layout (Scramble PIN layout when unlocking device) (On/Off)
        • Display music visualiser (On/Off)
        • Display media cover art (On/Off)
    • Lock screen preferences (Hide sensitive notification content)
      • On the lock screen (Hide sensitive notification content)
        • Show all notification content / Hode sensitive notification content / Don’t show notifications at all
      • Add users from lock screen (On/Off)
        • (enter text)
    • Trust
      • Privacy Guard
        • reset symbol
          • CANCEL / OK
        • three-dot menu
          • Enabled by default (On/Off)
          • Show notification (On/Off)
          • Show built-in apps (On/Off)
          • Advanced
            • three-dot menu
              • Show user apps (On/Off)
              • Reset allow/deny counters
            • LOCATION / PERSONAL / MESSAGING / MEDIA / DEVICE / RUN IN BACKGROUND / BOOTUP / ROOT ACCESS / OTHER (switch permission category)
            • (tap on App)
              • (list of App-Specific permission settings)
        • (tap on App) (Privacy Guard On/Off)
      • LineageOS statistics
        • Stats collection (allow installation metrics and device statistics to be collected) (On/Off)
        • Preview data (info)
      • SMS message limit (Apps can send … messages in 1 minute before requiring confirmation)
        • Always confirm / 5 / 10 / 30 / 50 / 100 / 200
      • Security alerts - SELinux status (On/Off)
      • Build signature (On/Off)
    • Location
      • On/Off
      • Mode
        • High accuracy (Use GPS, Wi-Fi, Bluetooth or mobile networks to determine location) / Battery saving (Use Wi-Fi, Buetooth or mobile networks to determine location) / Device only (Use GPS and device sensors to determine location)
      • App-level permissions
        • three-dot-menu
      • Scanning
        • Wi-Fi scanning (Improve location by allowing system apps and services to detect Wi-Fi networks at any time) (On/Off)
        • Bluetooth scanning (Improve location by allowing system apps and services to detect BLuetooth devices at any time) (On/Off)
      • Recent location requests - (tap on App) (link to Apps & notifications)
      • Location services - (tap on service) (service-specific info + settings)
    • Show passwords (Display characters briefly as you type) (On/Off)
    • Device admin apps
    • SIM card lock
      • (card name in slot 1)
        • Lock SIM card (Require PIN to use phone) (On/Off)
        • Change SIM PIN
      • (card name in slot 2)
        • Change SIM PIN
    • Encryption & credentials
      • Encrypt phone
        • (starts encryption preparations if not encrypted already)
      • Storage type (info)
      • Trusted credentials (display trusted CA certificates)
        • SYSTEM / USER (switch context)
        • (tap on installed certificate)
          • (info)
          • DISABLE / OK
      • User credentials (View and modify stored credentials)
      • Install from SD card (Install certificates from SD card)
        • (prompts for file location)
      • Clear credentials (Remove all certificates)
        • CANCEL / OK
    • Trust agents
      • (list of agents) (On/Off)
    • Screen pinning
      • On/Off
  • Users & accounts
    • Users
      • You (profile text) (Admin)
        • Profile info
          • (provide picture)
          • (enter text)
      • Guest
        • (switch to Guest user)
        • direct cogwheel
          • Turn on phone calls (On/Off)
      • Add user
    • Accounts for (current user) - (tap on user account)
      • (App-specific account info + settings)
      • Account sync
        • three-dot-menu
          • Sync now
        • (App-specific syncing settings)
      • REMOVE ACCOUNT
    • Add account
    • Emergency information (Info & contacts for (current user))
      • three-dot menu
        • Clear all
      • Medical information - Edit information
        • Name
          • (enter text)
        • Address
          • (enter text)
        • Blood type
          • 0+ / 0- / A+ / A- / B+ / B- / AB+ / AB+ / H/H / Unknown
        • Allergies
          • (enter text)
        • Medications
          • (enter text)
        • Organ donor
          • Yes / No / Unknown
        • Medical notes
          • (enter text)
      • Emergency contacts - Add contact
        • (contact selection)
    • Automatically sync data (Let apps refresh data automatically) (On/Off)
  • Accessibility (Screen readers, display, interaction controls)
    • Volume key shortcut
      • On/Off
        • Shortcut service
          • (App selection)
        • Allow from lock screen (On/Off)
      • Downloaded services - (tap on App)
        • On/Off
      • Screen readers - Text-to-speech output
        • Preferred engine
          • (engine selection)
          • direct cogwheel
            • (engine-specific settings)
        • Language
          • Use system language / (engine-specific language selection)
        • Speech rate (slider)
        • Pitch (slider)
        • PLAY
        • RESET
      • Display - Font size (link to Display)
      • Display - Display size (link to Display)
      • Display - Magnification
        • Magnify with triple-tap
          • On/Off
        • Magnify with button
          • On/Off
      • Large mouse cursor (On/Off)
      • Click after cursor stops moving
        • On/Off
          • Delay before click (slider)
      • Power button ends call (On/Off)
      • Touch & hold delay
        • Short / Medium / Long
      • Audio & on-screen text - Mono audio (Combine channels when playing audio) (On/Off)
      • Audio & on-screen text - Captions
        • On/Off
          • Language
            • (language selection)
          • Text size
            • Very small / Small / Normal / Large / Very large
          • Caption style
            • use app defaults / White on black / Black on white / Yellow on black / Yellow on blue / Customise
              • Customisation options - Font family
                • (font selection)
              • Customisation options - Text colour
              • Customisation options - Text opacity
                • 25% / 50% / 75% / 100%
              • Customisation options - Edge type
                • Default / None / Outline / Drop Shadow / Raised / Depressed
              • Customisation options - Edge colour
              • Customisation options - Background colour
              • Customisation options - Background opacity
              • Customisation options - Caption window colour
      • Experimental - High-contrast text (On/Off)
      • Experimental - Colour correction
        • On/Off
        • Correction mode
          • Deuteranomaly (red-green) / Protanomaly (red-green) / Tritanomaly (blue-yellow)
      • Experimental - Colour inversion (May affect performance) (On/Off)
  • System (Languages, time, backup, updates)
    • Languages & input
      • Languages
        • three-dot menu
          • Remove
        • (long-tap on language to drag to desired spot, No. 1 spot is the system language currently used)
        • Add a language
      • Virtual keyboard
        • Android Keyboard (AOSP)
          • Languages
            • Use system languages (On/Off)
          • Preferences
            • Auto-capitalisation (Capitalise the first word of each sentence) (On/Off)
            • Double-space full stop (Double tap aon spacebar inserts a full stop followed by a space) (On/Off)
            • Vibrate on keypress (On/Off)
            • Sound on keypress (On/Off)
            • Pop-up on key press (On/Off)
            • Voice input key (On/Off)
          • Appearance & Layouts
            • Theme
              • Material Light / Material Dark / Holo White / Holo Blue
            • Customised input styles
              • “+” (Add style)
                • Language - (language selection)
                • Layout - QWERTY / QWERTZ / AZERTY / Dvorak / Colemak / Bépo / PC
                • CANCEL / ADD
              • (tap on style)
                • CANCEL / REMOVE / SAVE
          • Gesture typing
            • Enable gesture typing (Input a word by sliding through the letters) (On/Off)
            • Dynamic floating preview (See the suggested word while gesturing) (On/Off)
            • Show gesture trail (On/Off)
          • Text correction
            • Personal dictionary
              • (tap on dictionary)
                • “+” (add a word)
                  • trashcan
                  • (Type a word)
                  • Shortcut - (enter optional Shortcut)
                • (tap on word)
                  • trashcan
                  • (change the word)
            • Add-on dictionaries
                • Delete
            • Block offensive words (Do not suggest potentially offensive words) (On/Off)
            • Auto-Correction (Correct mistyped words automatically with spacebar and punctuation) (On/Off)
            • Show correction suggestions (Display suggested words while typing (On/Off)
            • Personalised suggestions (Learn from your communications and typed data to improve suggestions) (On/Off)
            • Suggest contact names (Use names from Contacts for suggestions and corrections) (On/Off)
            • Next-word suggestions (Use the previous word when making suggestions) (On/Off)
          • Advanced
            • Key pop-up dismiss delay
              • No delay / Default
            • Keypress vibration duration
              • (ms slider)
              • DEFAULT
              • CANCEL / OK
            • Keypress sound volume
              • (slider)
              • DEFAULT
              • CANCEL / OK
            • Key long-press delay
              • (ms slider)
              • DEFAULT
              • CANCEL / OK
            • Emoji for physical keyboard (Physical Alt key shows the emoji palette) (On/Off)
            • Show app icon (Display application icon in the launcher (On/Off)
        • Manage keyboards
          • (list of keyboards) (On/Off)
      • Physical keyboard
        • Show virtual keyboard (Keep it on screen while physical keyboard is active) (On/Off)
        • Keyboard shortcuts helper (Display available shortcuts)
          • (info)
      • Advanced (Input assistance)
        • Spell checker
          • On/Off
            • Languages
            • Default spell checker
              • (spell checker selection)
              • direct cogwheel
                • Look up contact names (Spell checker uses entries from your contact list) (On/Off)
        • Auto-fill service
          • (service selection)
          • Add service (link to Google Play Store)
        • Personal dictionary (link)
        • Pointer speed
          • (slider)
        • Text-to-speech output (link)
    • Buttons
      • Navigation bar - Show arrow keys while typing (Display left and right cursor buttons while typing. Overrides IME switcher. (On/Off)
      • Navigation bar - Buttons and layout
        • Layout
          • Normal / Compact / Left-leaning / Right-leaning
        • Invert button layout (On/Off)
        • Extra left button type
          • Clipboard / Keycode / Keyboard switcher / None
        • Extra right button type
      • Navigation bar - Home long press action
        • No action / Open/close menu / Recent apps switcher / Search assistant / Voice search / In-app search / Launch camera / Turn screen off / Last app / Split Screen
      • Navigation bar - Home double tap action
      • Navigation bar - Recents long press action
      • Power button - Power menu
        • Screenshot (Long-press for partial screenshot) (On/Off)
        • User switcher (On/Off)
        • Bug report (On/Off)
        • Lockdown (On/Off)
      • Power button - End call (End the current call by pressing the power button while the display is off) (On/Off)
      • Power button - Long press for torch (Activate the torch by long pressing the power button while the display is off) (On/Off)
        • Automatically turn torch off
          • Never / 1 minute / 2 minutes / 5 minutes / 10 minutes
      • Camera button - Wake device (On/Off)
        • Screen peek (A half press will keep the screen on only while the button is held down) (On/Off)
      • Camera button - Launch camera (A long press and release will launch camera) (On/Off)
      • Volume buttons - Wake device (On/Off)
      • Volume buttons - Answer call (Answer incoming calls by pressing the volume buttons) (On/Off)
      • Volume buttons - Control playback (Seek music tracks by long pressing the volume keys while the display is off (On/Off)
      • Volume buttons - Control ringtone volume (Volume keys control ringtone volume) (On/Off)
      • Volume buttons - Keyboard cursor control
        • Disabled / Volume up/down moves cursor left/right / Volume up/down moves cursor right/left
      • Volume buttons - Reorient (Swap volume buttons when the screen is rotated (On/Off)
    • System profiles
      • three-dot menu
        • Reset
          • CANCEL / OK
        • App groups
          • “+” (New app group)
            • (Enter profile name)
            • CANCEL / OK
      • On/Off
      • Default / Silent / Vehicle (direct cogwheel)
        • trashcan
        • three-dot menu
          • Import current device settings
        • Name - (Rename)
        • Triggers which will activate this profile - Wi-Fi
          • WI-FI / BLUETOOTH
            • (tap on network or device)
              • On connect / On disconnect / No trigger
          • BLUETOOTH / WI-FI
        • Wireless & networks - Bluetooth
          • Leave unchanged / Turn off / Turn on
        • Wireless & networks - GPS
        • Wireless & networks - Wi-Fi
        • Wireless & networks - Auto-sync data
        • Wireless & networks - Data connection
        • Wireless & networks - Portable Wi-Fi hotspot
        • Wireless & networks - Preferred network type (name of SIM card in slot 1)
        • Volume overrides - Alarm
          • Override volume (On/Off)
            • (slider)
        • Volume overrides - Media
            • (slider)
        • Volume overrides - Ringtone
            • (slider)
        • Volume overrides - Notification
            • (slider)
        • System settings - Ring mode
          • Normal / Vibrate / Mute / Leave unchanged
        • System settings - Aeroplane mode
        • System settings - Lock screen mode
        • System settings - Screen brightness
          • Override brightness (On/Off)
            • (slider)
        • System settings - Ambient display
        • System settings - Notification light
      • “+” (add profile)
    • Status bar
      • Quick pulldown
        • Off / Right / Left
      • Network traffic monitor (Show current network traffic levels in the status bar)
        • Display mode
          • Disabled / Upload only / Download only / Upload and download
          • Auto hide (Hide the traffic monitor when there is no activity) (On/Off)
          • Traffic measurement units
            • Kilobits per second (kb/s) / Megabits per second (Mb/s) / Kilobytes per second (kB/s) / Megabytes per second (MB/s)
          • Show units (Whether to show traffic measurement units in the statusbar) (On/Off)
      • System icons (Control which status bar icons are shown)
        • Headset (On/Off) (On/Off)
        • Work profile (On/Off)
        • Cast (On/Off)
        • Hotspot (On/Off)
        • Bluetooth (On/Off)
        • Do not disturb (On/Off)
        • Volume (On/Off)
        • Wi-Fi (On/Off)
        • Ethernet (On/Off)
        • Battery
          • Always show percentage / Show percentage when charging / Don’t show this icon
        • Alarm (On/Off)
        • Clock (On/Off)
      • Clock position
        • Right / Centre / Left
      • Show seconds (Show hours, minutes, and seconds) (On/Off)
      • AM/PM style
        • Normal / Small / Hidden
      • Brightness slider (Adjust brightness from the Quick settings) (On/Off)
      • Auto brightness (Show toggle for adaptive brightness near the slider) (On/Off)
      • Brightness control (Adjust brightness by sliding across the status bar) (On/Off)
    • Gestures
      • Jump to camera
        • Jump to camera (To quickly open camera, press the power button twice. Works from any screen.) (On/Off)
    • Date & time
      • Automatic date & time (Use network-provided time) (On/Off)
      • Automatic time zone (Use network-provided time zone) (On/Off)
      • Set date
        • (date selection)
      • Set time
        • (time selection)
      • Select time zone
        • (time zone selection)
      • Use 24-hour format (On/Off)
    • Reset options
        • RESET SETTINGS
      • Reset app preferences
        • CANCEL / REST APPS
      • Erase all data (factory reset)
        • RESET PHONE
    • About phone
      • LineageOS updates
        • refresh symbol
        • three-dot menu
          • Preferences
            • Auto updates check (On/Off)
            • Delete updates when installed (On/Off)
            • Mobile data warning (On/Off)
      • Status (Phone number, signal, etc.)
      • Battery status (info)
      • Battery level (info)
      • SIM status
        • (info)
      • IMEI information
        • (info)
      • IP address (info)
        • Wi-Fi MAC address (info)
      • Bluetooth address (info)
        • Serial number (info)
        • Uptime (info)
      • Legal information
        • Third-party licenses
          • (info)
        • LineageOS legal
          • (info)
        • Google legal
          • (info)
        • System WebView licenses
          • (info)
      • Contributors
        • Search
          • (search for contributors)
        • three-dot menu
          • Contributions info
            • (info)
        • (zoom + drag to see details of LineageOS logo made off contributors’ names)
      • Model (FP2)
      • Android version (8.1.0)
      • LineageOS version (info)
      • LineageOS API level (info)
      • Android security patch level (info)
      • Vendor security patch level (info)
      • Baseband version (info)
      • Kernel version (info)
      • Build date (info)
      • Build number (info, tap several times to activate Developer options)
      • SELinux status (info)
Developer options
Settings
  • System
    • Developer options (to activate these, tap on Settings - System - About phone - Build number several times)
      • On/Off
      • Memory
        • 3 hours / 6 hours / 12 hours / 1 day
        • Memory used by apps
          • three-dot menu
            • Sort by max. use / Sort by avg. use
          • (tap on App)
            • (info)
        • Apps started on boot (link to Privacy Guard)
      • Development tools
        • Developer options (link to Developer options)
        • Developer options (displays message as if not enabled yet)
        • (tap on development tool)
          • (tool-specific actions + settings + info)
      • Take bug report
        • Interactive report / Full report
        • REPORT
      • Advanced restart (When unlocked, include options in the power menu for restarting into recovery or bootloader) (On/Off)
      • Desktop backup password
        • (set up or change password)
        • CANCEL / SET BACKUP PASSWORD
      • Stay awake (Screen will never sleep while charging) (On/Off)
      • HDCP checking
        • Never check / Check for DRM content only / Always check
      • Enable Bluetooth HCI snoop log (Capture all Bluetooth HCI packets in a file (On/Off)
      • Running services (View and control currently running services)
        • SHOW CHACHED PROCESSES / SHOW RUNNING PROCESSES
        • (tap on service)
          • STOP or SETTINGS / REPORT
      • Picture colour mode (Use sRGB) (On/Off)
      • WebView implementation
        • (implementation selection)
      • System UI demo mode
        • Enable demo mode (On/Off)
          • Show demo mode (On/Off)
      • Quick settings developer tiles
        • Show layout bounds (On/Off)
        • Profile GPU rendering (On/Off)
        • Force RTL layout direction (On/Off)
        • Windows animation scale (On/Off)
      • Root access
        • Disabled / Apps only / ADB only / Apps and ADB
      • Manage root accesses (View and control the root rules) (link to Privacy Guard)
      • Android debugging (Enable the Android Debug Bridge (ADB) interface) (On/Off)
      • Debugging notify (Display a notification when USB or network debugging is enabled) (On/Off)
      • ADB over network (Enable TCP/IP debugging over network interfaces (Wi-Fi, USB networks). This setting is reset on reboot) (On/Off)
      • Revoke USB debugging authorisations (Revoke access to USB debugging from all computers you’ve previously authorised?)
        • CANCEL / OK
      • Local terminal (Enable terminal app that offers local shell access) (On/Off)
      • Bug report shortcut (Show a button in the power menu for taking a bug report) (On/Off)
      • Select mock location app
        • (App selection)
      • Enable view attribute inspection (On/Off)
      • Select debug app
        • (App selection)
      • Wait for debugger (Debugged application waits for debugger to attach before executing) (On/Off)
      • Verify apps over USB (Check apps installed via ADB/ADT for harmful behaviour.) (On/Off)
      • Logger buffer sizes
        • Off / 64 K / 256 K / 1 M / 4 M / 16 M
      • Store logger data persistently on device
        • Off / All / All but radio / kernel only
      • Wireless display certifiction (Show options for wireless display certification) (On/Off)
      • Enable Wi-Fi verbose logging (Increase Wi-Fi logging level, show per SSID RSSI in Wi-Fi Picker) (On/Off)
      • Aggressive Wi-Fi to mobile handover (When enabled, Wi-Fi will be more aggressive in handing oder the data connection to mobile, when Wi-Fi signal is low) (On/Off)
      • Always allow Wi-Fi Roam Scans (Allow/Disallow Wi-Fi Roam Scans based on the amount of data traffic present at the interface) (On/Off)
      • Mobile data always active (Always keep mobile data active, when Wi-Fi is active (for fast network switching).) (On/Off)
      • Tethering hardware acceleration (Use tethering hardware acceleration id available) (On/Off)
      • Select USB Configuration
        • Charging / MTP (Media Transfer Protocol) / PTP (Picture Transfer Protocol) / RNDIS (USB Ethernet) / Audio Source / MIDI
      • Show Bluetooth devices without names (Bluetooth devices without names (MAC addresses only) will be displayed) (On/Off)
      • Disable absolute volume (Disables the Bluetooth absolute volume feature in case of volume issues with remote devices such as unacceptably loud volume or lack of control.) (On/Off)
      • Enable in-band ringing (Allow ringtones on the phone to be played on BLuetooth headsets) (On/Off)
      • Bluetooth AVRCP Version
        • AVRCP 1.4 (Default) / AVRCP 1.3 / AVRCP 1.5 / AVRCP 1.6
      • Bluetooth Audio Codec
        • Use System Selection (Default) / SBC / AAC / Qualcomm® aptX™ audio / Qualcomm® aptX™ HD audio / LDAC / Enable Optional Codecs / Disable Optional Codecs
      • Bluetooth Audio Sample Rate
        • Use System Selection (Default) / 44.1 kHz / 48.0 kHz / 88.2 kHz / 96.0 kHz
      • Bluetooth Audio Bits Per Sample
        • Use System Selection (Default) / 16 bits/sample / 24 bits/sample / 32 bits/sample
      • Bluetooth Audio Channel Mode
        • Use System Selection (Default) / Mono / Stereo
      • Bluetooth Audio LDAC Codec: Playback Quality
        • Optimised for Audio Quality (990kbps/909kbps) / Balanced Audio And Connection Quality (660kbps/606kbps) / Optimised for Connection Quality (330kbps/303kbps) / Best Effort (Adaptive Bit Rate)
      • Show taps (Show visual feedback for taps) (On/Off)
      • Pointer location (Screen overlay showing current touch data) (On/Off)
      • Show surface updates (Flash entire window surfaces when they update) (On/Off)
      • Show layout bounds (Show clip bounds, margins, etc.) (On/Off)
      • Force RTL layout direction (Force screen layout direction to RTL for all locales) (On/Off)
      • Window animation scale
        • Animation off / Animation scale .5x / Animation scale 1x / Animation scale 1.5x / Animation scale 2x / Animation scale 5x / Animation scale 10x
      • Transition animation scale
      • Animator duration scale
      • Simulate secondary displays
        • None / 480 p / 480p (secure) / 720p / 720p (secure) / 1080p / 1080p (secure) / 4K / 4K (secure) / 4K (upscaled) / 4K (upscaled, secure) / 720p, 1080p (dual screen)
      • Smallest width
        • (enter dp value)
      • Force GPU rendering (Force use of GPU for 2D dawing) (On/Off)
      • Show GPU view updates (Flash views inside windows when drawn with the GPU) (On/Off)
      • Show hardware layers updates (Flash hardware layers green when they update) (On/Off)
      • Debug GPU overdraw
        • Off / Show overdraw areas / Show areas for Deuteranomaly
      • Debug non-rectangular clip operations
        • Off / Draw non-rectangular slip region in blue / Highlight tested drawing commands in green
      • Force 4x MSAA (Enable 4x MSAA in OpenGL ES 2.0 apps) (On/Off)
      • Disable HW overlays (Always use GPU for screen compositing) (On/Off)
      • Simulate colour space
        • Disabled / Monochromacy / Deuteranomaly (red-green) / Protanomaly (red-green) / Tritanomaly (blue-yellow)
      • Set GPU Renderer
        • OpenGL (Default) / OpenGL (Skia)
      • Disable USb audio routing (Disable automatic routing to USB audio peripherals) (On/Off)
      • Strict mode enabled (Flash screen when apps do long operations on main thread) (On/Off)
        • Off / On screen as bars / In adb shell dumpsys gfxinfo
      • Don’t keep activities (Destroy every activity as soon as the user leaves it) (On/Off)
      • Background process limit
        • Standard limit / No background processes / At most, 1 process / At most, 2 processes / At most, 3 processes / At most, 4 processes
      • Background check
      • Show all ANRs (Show App Not Responding dialogue for background apps) (On/Off)
      • Show notification channel warnings (Displays on-screen warningwhen an app posts a notification without a valid channel) (On/Off)
      • Inactive apps
        • (tap on App) (toggle Active/Inactive)
      • Force allow apps on external (Makes any app eligible to be written to external storage, regardless of manifest values) (On/Off)
      • Force activities to be re-sizable (Make all activities resizable for multi-window, regardless of manifest values.) (On/Off)
      • Reset ShortcutManager rate-limiting (without further confirmation!)
      • Kill app back button (Kill the foreground app by long-pressing the back button) (On/Off)
Google settings
(probably added by installing Open GApps pico, but pure speculation at this point, feel free to move parts which are “normal” settings to the “normal” settings)
Settings
    • Google Play Protect
      • three-dot menu
        • Help & feedback (info + feedback form)
      • FIND OUT MORE (info)
      • Scan device for security threats (Google will regularly check your device and prevent or warn about potential harm) (On/Off)
        • Improve harmful app detection (Send unknown apps to Google for better detection) (On/Off)
    • Find My Device
      • three-dot menu
      • On/Off
      • Find My Device (link to Find My Device App)
      • Web (link to Find My Device website)
      • Google (link to Google Search)
    • Smart Lock
      • three-dot menu
        • How it works (info)
        • Help (info)
      • On-body detection (Keep your device unlocked while it’s on you)
        • On/Off
      • Trusted places
        • Add location where device should be unlocked
          • Home (Set a trusted place in Google Maps)
          • Add trusted place
      • Trusted devices
        • ADD TRUSTED DEVICE
  • Google (Services & preferences)
    • three-dot menu
      • Clear app data
        • CANCEL / OK
      • Usage & diagnostics
        • three-dot menu
        • On/Off
      • Open-source licenses
        • (info)
      • Show debug items / Hide debug items
    • Google account (Info, security & personalisation)
      • (Google account settings)
    • Ads
      • three-dot menu
      • Reset advertising ID
        • CANCEL / OK
      • Opt out of Ads Personalisation (Instruct apps not to use your advertising ID to build profiles or show you personalised ads.) (On/Off)
      • Ads by Google (link to Google Ads settings online)
      • Enable debug logging for ads (Instruct apps to write ads debugging information (such as network traffic) to the system log. (On/Off)
      • Your advertising ID: (info)
    • Android Auto
      • GET THE APP (link to Google Play Store)
      • FIND OUT MORE (link to website)
    • App preview messages
      • On/Off
      • Add your number here (To start getting messages on this device, register your number)
        • (enter telephone number)
      • Manage storage
        • Remove messages after 7 days (On/Off)
        • Delete all app preview messages
    • Apps connected
      • All apps & devices / Apps with Google Sign In / Google Fit apps & devices
      • (tap on App)
        • three-dot menu
          • Help (info)
        • DISCONNECT
    • Backup
      • Backup to Google Drive (On/Off)
        • Account (Add backup account)
    • Cast media controls
      • three-dot menu
        • Help (info)
      • Media controls for Cast devices (Control media from Cast devices through a notification) (On/Off)
    • Data management
      • three-dot menu
      • Update Drive-enabled app files
        • Over Wi-Fi or mobile / Over Wi-Fi only
    • Device phone number
      • (connection to Google’s My Account)
    • Google Fit
      • three-dot menu
      • Connected apps and devices
        • three-dot menu
          • Help (info)
        • (tap on App or device)
          • three-dot menu
            • Help (info)
          • DISCONNECT
      • Manage data
        • three-dot menu
    • Google Pay
      • three-dot menu
        • Settings
          • Purchase notifications (Get transaction details after your purchase) (On/Off)
          • Email updates (Get exclusive offers, tips and invites to give feedback) (On/Off)
          • Promotional notifications (Receive offers and recommendations to help you get the most out of Google Pay) (On/Off)
        • View Privacy Policy (link to website)
        • View Terms of Service (link to website)
      • Get the app (link to Google Play Store)
      • Manage payment methods
        • three-dot menu
          • Settings
        • Add a credit or debit card
    • Location (link to Location settings)
    • Nearby
      • cogwheel
        • three-dot menu
        • (tap on notification category)
          • On/Off
          • Importance
            • Urgent (make sound and pop up on screen) / High (Make sound) / Medium (No sound) / Low (No sound or visual interruption)
          • Show notification dot (On/Off)
        • Debug mode - Include debug results (On/Off)
        • Using Nearby - (list of supported Apps)
      • three-dot menu
      • TURN ON
    • Restore contacts
      • three-dot menu
      • From account
        • (account selection)
    • Security
      • three-dot menu
      • Find My Device (link)
      • Google Play protect (link)
    • Set up nearby device
    • Set up your work profile
    • Smart Lock for Passwords
      • three-dot menu
        • Help (info)
      • Smart Lock for passwords (Offer to save passwords to your Google account) (On/Off)
        • Auto sign-in (Automatically sign in to apps and websites connected to your account. Wehn disabled, you will be asked for confirmation every time before signing in to an app or website.) (On/Off)
      • Never save - Add app not to be saved
    • Developer - Firebase App Indexing
      • CAPTURE ACTIONS AND ERRORS (Enable collecting and displaying recent user actions and errors.) (On/Off)
      • (tap on App)
        • Indexable Types - (tap on type)
          • (type log)
        • SEND UPDATE_INDEX
    • [Internal] - GCM Diagnostics
      • PING
      • CONNECT
      • DISCONNECT
      • EVENTS
    • [Internal] - Google Play services modules
      • three-dot menu
        • Check for updates
      • MODULE SETS - (tap on set)
        • three-dot menu
          • Check for updates
        • (info)
      • NON CONTAINER MODULES - (tap on module)
        • three-dot menu
          • Check for updates
        • (info)
      • CONTAINER MODULES - (tap on module)
        • three-dot menu
          • Check for updates
        • (info)
    • [Internal] - Growth debug
      • SYNC
      • LIST REGISTERED APPS
      • SHOW REGISTERED ACCOUNTS
      • LAUNCH WEBVIEW
      • LAUNCH WEBVIEW WITH URL
    • [Internal] - SmartDevice Target flow
  • System
    • Backup (link to Google settings)
Thank you for this LineageOS 15.1 settings tree reference as I can find in it some stuff that does not show-up when using the Search box in Settings of LOS 15.1.
May I ask you how you made it? I would like to do something similar for my S3 i9300 LineageOS 14.1 but cannot find anything when looking in https://github.com/LineageOS/android_packages_apps_Settings/tree/cm-14.1
Or did you do it manually?
Yes, the hard way :wink: .
Wow, that deserves an even BIGGER THANKS then. :+1:
Edit: @AnotherElk I will link to your post in https://www.reddit.com/r/LineageOS/ Do you have a reddit user account I could credit to?
No, I don’t have one.
