Main Issues (Reboots, Speech gaps, Missing noise output, Back cover) | Support
As it appears to me that I have issues with my FP3 which a lot of people share, I will state them here and update it regularly according to the info from the customer support.
Answers provided below are from FP’s customer support (July 15, 2020)
  • September 16, 2020: Support has no update.)
  • September 22, 2020: Some update on Nr. 1 and Nr. 3
  • October 3, 2020: Update on Nr. 3
1. Random reboots during calls
Answer:
We are sincerely sorry for the inconvenience of your reboots during calls.
Currently we are investigating this problem. To help us further, if not specified already, please provide the following information:
  1. Network provider(s)
  2. In which country are you experiencing this issue?
  3. Frequency of the issue. How often does it happen? Once a day, once a week, every phone call, etc.
  4. Does it seem connected to the use of any particular app? Only during regular phone calls, only during WhatsApp calls, only if the Maps app is open in the background, etc.
In this way we will be able to log your issue with all the information and then forward them to our product team.
Please allow us a reasonable amount of time to investigate this.
If additional details are necessary we might come back to you soon for further communication.
New: We still do not have an update on this, and no timeline. We are currently investigating the root of this issue. Unfortunately, at the moment there is nothing we can do to solve it. Please allow us a reasonable amount of time to investigate this. Thank you for your cooperation and understanding.
Related Topics:
2. Speech gaps during calls
Answer:
Concerning the speech gaps in calls, we received seemingly similar customer complaints with this specific issue, so I will forward it to our Technical Department that might get in contact with you.
Thank you in advance for your cooperation and patience. We are truly grateful to our customers for supporting our mission.
Related topics:
3. Removing headphones, missing noise output
Answer:
We received seemingly similar customer complaints with this specific issue, so I will log it and forward it to our product team.
As the issue is not solved, to proceed we will need to ask you to remove your display (read this article for correct instructions) and take the following pictures of your device:
New: This has been solved with the second Android 10 update (8901.3.A.0045.20200905)
Related Topics:
4. Factory fault back cover
Anwer:
Let’s replace it in warranty.
Related Topics:
https://forum.fairphone.com/t/back-cover-letters/60038/3
Experiencing ALL these issues. No reply from customer service, can’t call Amsterdam on the phone plan I have.
Dear Aisling_Roche,
You should get a response if you submit a request here:
Best, endgame
