This one is merged now @snevas would you please trigger a new build.
Building
please test the testbuild.zip after it has finished. See
progress here:
https://fp2.joutubes.nl/jenkins/job/FP2-LineageOS14.1/41/console
You can see the SVN changes to the device tree and the build information here. If you look at the build start date you can trace it back to a release.
I am trying to follow these steps (from a FP2 open OS 17.04)
Flashing OTA fix went (finally) ok
But when I come to flash the lineage-migration-signed.zip and the lineage-14.1-20170609-UNOFFICIAL-FP2.zip, my phone always answers âzip signature verification failedâ (doesnât change a thing if I do it queuing the 2 files or step by step).
Does someone have an idea what I could try?
Thanks!
Vero
20170609 isnât a OTA build. Download the latest here:
https://fp2.joutubes.nl/builds/full/
20170803 is the latest build. This one will flash after the migration zip.
Also disable the verification step checkbox before you flash.
I thought you didnt need the migration zip, as the instructions in the 1st post donât mention flashing it if coming from FPOS. I didnât use it when I came from Open Android 5.1 and I can get OTA updates with Lineage.
Iâd say that if you follow the instructions in the 1st post under âif coming from any other buildâ then it should be a ok
As I have a Mac, I had trouble getting fastboot to work, so instead I was able to use the TWRP App, which I downloaded from the play store to the phone, to flash the TWRP OTA Fix to recovery. This skipped the fastboot trouble. I can still successfully install Lineage OTA updates through the updater. What do you think about me adding a line or two with installation instructions in the beginning of this thread for those who canât get fastboot going? It might help Lineage to reach a wider audience
Itâs a wiki post, so you can edit it yourself. But try to keep the instructions as simple as possible
Thanks! But I am still tryingâŚ
I updated open OS to the very last one 17.07.
(actually I had a look at lineage because it was impossible to get the file from here 2 days ago, but it worked todayâŚ
Everything was still okay (apps, contacts, sms,âŚ
I flashed modem-17.07.6 (myabe it was not useful now I had the latest open OS?)
Then lineage-migration-signed (the latest one 08-03)
What should I choose now in the team wine recovery project page?
reboot?
Edit : Actually, I finally manage to get Lineage OTA updates through the updater so I made a step (or at least I hope soâŚ). But after the reboot, I have this same screen and I donât kow what to do
If coming from open OS, follow this part from the 1st post (no migration zip needed):
Be aware that youâll need to factory reset and youâll lose all data that you donât backup.
Ok, thanks, I will start from scratch ![]()
Edit: sounds like it doesnât work⌠I am âstuckâ in open OS 17.07 whatever I try⌠![]()
Maybe is it because I get an âerror 7â message (while flashing lineage-14.1-20170803âŚzip)?
I keep trying ![]()
Edit2: I did exactly what is written here
And I still get this get this error7 message :-/
Edit3: No, it worked finally⌠in 2 steps
- factory reset
- flashing lineage 14.1-20170614-UNOFFICIAL-FP2.zip
@sky I just installed the testbuild.zip of 05/08/2017 and I also confirm that the SIM2 for SMS setup doesânt survive a reboot
Pushed a update with the new security patches. Nothing else changed. Timestamp is 20170808.
Be aware of the following bugs:
As I still canât OTA successfully (âDie ĂberprĂźfung ist fehlgeschlagen, beschädigter oder âŚâ), I got me a logcat:
08-08 20:13:10.945 10081 18291 D DownloadManager: [269] Finished with status SUCCESS
08-08 20:13:14.691 7880 7890 I art : Background sticky concurrent mark sweep GC freed 139423(6MB) AllocSpace objects, 5(168KB) LOS objects, 28% free, 19MB/26MB, paused 1.564ms total 203.863ms
08-08 20:13:24.540 10081 10093 V DownloadManager: Deleting /data/data/com.android.providers.downloads/cache/lineage-14.1-20170808-UNOFFICIAL-FP2.zip via provider delete
08-08 20:13:30.775 18216 20682 E DownloadComplete: Verification failed
08-08 20:13:30.775 18216 20682 E DownloadComplete: java.security.SignatureException: signature digest verification failed
08-08 20:13:30.775 18216 20682 E DownloadComplete: at android.os.RecoverySystem.verifyPackage(RecoverySystem.java:315)
08-08 20:13:30.775 18216 20682 E DownloadComplete: at com.cyanogenmod.updater.service.DownloadCompleteIntentService.onHandleIntent(DownloadCompleteIntentService.java:99)
08-08 20:13:30.775 18216 20682 E DownloadComplete: at android.app.IntentService$ServiceHandler.handleMessage(IntentService.java:68)
08-08 20:13:30.775 18216 20682 E DownloadComplete: at android.os.Handler.dispatchMessage(Handler.java:102)
08-08 20:13:30.775 18216 20682 E DownloadComplete: at android.os.Looper.loop(Looper.java:154)
08-08 20:13:30.775 18216 20682 E DownloadComplete: at android.os.HandlerThread.run(HandlerThread.java:61)
(How do I format this best?)
Is it possible that the LineageOS/android_frameworks_opt_telephony tree isnât used in our LAOS builds?
Itâs included. If you search within the buildservers console log youâll see:
00:01:19.506 Fetching project LineageOS/android_frameworks_opt_telephony
But Iâve heard there have been some other changes yesterday that could fix it. Could you test this one after is finishes?
Iâve seen that, but no more hints to the content of that tree and also no hints to SubscriptionController.java in my logcat after booting the phone.
Iâll try the new build as soon as possible.
No, the new testbuild didnât fix it.
