Can't Flash LineageOS
Flashing LineageOS in TWRP fails with an error:
Can't install this package on top of incompatible data. Please try another package or run a factory reset.
Updater process ended with ERROR: 7
Error installing zip file `/sdcard/Download/lineage-14.120170626-UNOFFICIAL-FP@.zip'
Updating partition details...
...done
Here is what I did:
Any tips on what to do now?
Edit: looks like I am doing rubber duck debugging here on you all. Sorry about that…
I should have done a factory reset first. Now it works.
I hope my mistake helps other people in the future stuck in the same place. :slight_smile:
If you come from FP Open, don’t do anything with the migration zip, but follow the instructions under “When coming from any other OS”:
You need to backup and factory reset in stead.
Sorry, didn’t read your last 2 sentences. Glad you made it work :slight_smile:
