Camera experience on FP4
Hi there,
Since having my FP4, i’ve noticed a vast difference mainly with the camera and have a few questions:
  1. camera speed from pressing to taking is really noticeable. Is there any way of.improving this?
  2. accessing photos - seems like the only way is either through the file management (terrible experience basically by file name) or uploading to Google (this just duplicates photos). Is there a better way of managing photos?
  3. camera quality is a bit dubious but seems like it should be way better. Any tips / thoughts on this?
Thanks,
Rich
Hi and welcome to the community.
I would advice to search a bit the forum for answers and Tipps
E.g.
You can install any other gallery app like the one from simple mobile tools and you dont need to back up using Google, you can back up on an SD card (DO NOT Format as internal), your PC another cloud option…
Wen you say dubious, what does that mean in terms of picture quality? Any examples?
Die meisten Tests wurden gemacht, als das Kameraupdate noch Ausstand. Das hatte FP auch immer kommuniziert. Die Tests wurden aber nicht aktualisiert. Dein Handy kenne ich nicht persönlich, aber es gibt im Forum einen Thread mit Beispielbildern. Da kannst du einen Einblick bekommen.
Today I took a first shot with the installed camera app and i was shocked.
This is ISO112 and the clouds looks like painted and in the details ithas a sharpening out of hell - W-T-F-!!!
I don’t expect wonders about the camera, but even a fair phone for 650€ should be able to produce something really better than this. Is there any chance for better results, maybe with another camera app? just need an intuitive GUI, where I can set fast ISO and shutter speed and produce RAW-files.
go and have a look at the topics linked above.
Thanks, but is there any short trouble shooting?
No time for scrolling through tons of photos and answers (i tried).
I’m a user as well and neither have time to summarize this for you… overall note, this is a user forum and no official support.
Ok, my research brought me to Pro Camera X and FV-5.
Both apps have their advantages - FV-5 brings more features to the cam (for example long exposure up to 60s), but it don’t seems to be able to use the OIS. For that you have different meter modes (multizone, integral, spot, …)
For this Gcam thing I’m not smart enough - I need apps that I can install via the Google playstore.
Ok, I do some reseach and there seems to be some alternatives for the (in my eyes) useless camera app.
So i need some simple advise for a camera app, that:
  • has a simple user interface for setting shutter speed and ISO easily
  • don’t need google photo as gallery app (I’m using DV gallery)
  • can use the OIS
  • can use both cameras (the main and wide angle one)
I read a lot about this gCam thing, but I’m not into this thing and it don’t seems to be something like opening the playstore and installing an app. so is there a short explaination for that? How save is it? I don’t using clouds and de-activated the most google apps.
When you do some search in the forum you will see that points 2+4 are not possible or you need to test (open Camera can open via another gallery e.g.)
For 2 just follow the link above for further information.
Reg 4:
Also for GCam Plesse search the forum and read, the information is available and already to be found in the links above
I moved your post to this other topic where you already started the Discussion.
Edit: not sure if you can achieve what you want reg OIS, overall just download some apps and do some Tests,
Here is a link to a version of Gcam
Download and click on downloaded file etc
More options
Maybe I should tell about my last phone
BQ Aquaris X Pro - from 2017. The camera app was simple but effective. The sensor and lens were ok, but no high tech. Together it was easy to make good pictures. I don’t understand what is the problem five years later to get a fair solution with a much better hardware. The Fairphone cost 650 bucks (twice my old phone), so quality in hard and software should not be an issue. I don’t expect wonders, but a good midclass quality. I’m a photographer - i know what I’m doing in case of photography.
And a second time: I don’t understand this whole app thing above selecting an app from the playstore and installing it. This gCam thing seems to be some more complicated. For this I opened a new topic here. Thanks for puting it into another topic with not that specific reason.
It’s not that arduous.
Download the file, double click to install ???
Try the Nikta one as mentioned
I assume you already tested the Pro Mode of the installed App where you can set ISO, White Balance, AF etc manually? There is no other way then testing a bit what suits you best, one likes an app for some reason, another one another app for another reason. Apologies, without a bit of reading and testing it will be difficult to find what you are searching for.
In my eyes the quality is good enough in good lightning conditions and I think what one finds good enough is quite subjective…
Here an example from somone who also understands what he is doing in terms of photography
Here some shots (incl Tutorial) shared on Instagram
https://www.instagram.com/p/CgrNdKGAReh/?utm_source=ig_web_copy_link
Those are ideal conditions for the Fairphone. Grainy skies, not too much or too low light. No bright colors. The environment is basically tuned to what the FP camera will most it the time produce :slight_smile:
And now?
You need to go to App info of Firefox and enable Install unknown apps.
So I tried the gcam, but there seem to be no chance to choose shutter speed or ISO or HDR or not HDR.
Not my style. I need control about the parameters.
The lite version of Pro Camera X often freezes.
C-FV5 is ok, but somehow not intuitive. Both lack about the wide angle lens.
This can definitely be chosen. I use the one by BSG. Try that one instead of the one by Nikita
Not sure which gcam you are using. But with Nikita 8.*
