Bootloader Unlocking Code for Fairphone 3 not working
Hi guys,
I am trying to install /e/ on my FP3.
I got a bootloader code from this FP page : https://www.fairphone.com/en/bootloader-unlocking-code-for-fairphone-3/
When i go for the OEM unlocking and enter the code I get :
“Password verification failed”.
I have reset the code to give it another try, same result.
Anyone with a magic wand to help me ?
“Password verification failed” sounds like you entered the OEM unlocking code in a place that expects your password or PIN.
The system asks first the phone password, then the OEM code
I get Password verification failed at the OEM code stage
Just an idea: perhaps you could try with the alternative code generation on z3ntu website, mentioned on the wiki?
It looks like the unlocking implementation changed in one of the recent versions (maybe with the switch to Android 10). I am trying to look into this once more.
A few questions:
  • What Fairphone OS version do you have?
  • Are you connected to the internet (e.g. Wifi) while unlocking?
  • Could you try to obtain a logcat when trying to unlock?
    Something like adb logcat | grep Oem would be nice, but you probably want to check the output before posting as it might contain your IMEI and Serialnumber.
Perhaps worth a try …
Android version : 9
Build number : 8901.2.A.0111.20200131
I am connected to the internet through my sim card (if I use wifi it will try to upgrade to android 10 which I red is unwanted for my purpose).
LOGCAT :
~$ adb logcat | grep Oem
11-04 15:40:33.242 2068 2120 I QcrilOemhookMsgTunnel: [0]processOemHookIndication length=62
I see, it is not just the code on the phone that changed but also the code on the fairphone website backend. So to unlock your phone using that website you need to be running a more recent version, probably Android 10.
You can try to generate an unlock code with the unofficial script / website mentioned here:
PS: You can remove the logcat output from your post as it doesn’t provide any relevant info.
I worked with this website !
Thank you guys !
I’ve had a similar problem trying to unlock an FP3+. Neither code generated by either the official for the alternative web site worked, but I found fastboot oem 8901_unlock works, which makes enabling unlocking on the phone a bit redundant.
This command is not being officially communicated, it was found by clever examination. It looks to me like this mainly exists as a tool for support and repair folks for the same situations in which it helps users here now.
As I just got a new F3+ I am trying to in stall /e/ os in F3+, in Developer Option I have been trying to unlock the OEM which call for a code.
After getting the IMEI (slot 1) number and the Serial number, went to get the code at https://private.z3ntu.xyz/FP3/verify-code.php and https://www.fairphone.com/en/bootloader-unlocking-code-for-fairphone-3/
One after another none of these codes worked, each time at the bottom of the screen a small message pops up “Inner Unknown failure” while the another message says “Processing”
With ADB adb reboot bootloader the phone screen menu says “DEVICE STATE - locked”
Got the latest F3+ buitd 3.A.0054. and thoroughly imput the IMEI (slot 1) and the SN without typo.
Fastboot oem unlock command does not work either.
Did a factory reset still doesn’t work !
Please help!
Hello !
I tried to unlock the F3+ Bootlader by following the procedure described in the link above :
I received a code but my keyboard displays numbers only. I wrote the code in text message, copied it and pasted, but I have a message : wrong password…
The letters a deleted to keep only the numbers when I paste the code
Can you help me please ?
Best regards,
Kristien
Yes, indeed. We switched the implementation with Android 10. The code retrieved from the website only works with Android 10 and up.
Franz, Unfortunately it does not seem to work on the Fairphone 3+ with Android 10 (Build #8901.3.A.0054). Support Request #397991
Pasting select logs from adb logcat below the line. Please replace the items in CAPITAL with the relevant values:
11-17 16:57:57.113  8036  8036 I OemUnlockPreferenceController: mVerifier == null ? true
11-17 16:57:57.113  8036  8036 I OemUnlockPreferenceController: invoke mVerifier.queryVerifyResult()----password=UNLOCK_CODE
11-17 16:57:57.116  8036  8036 D OemLockVerifier: queryVerifyResultGet--targetUrl=https://factory.fairphone.com/api/unlock-codes/IMEI1/PHONE_SERIAL_NUMBER/UNLOCK_CODE
11-17 16:57:57.117  8036 11102 D OemLockVerifier: queryVerifyResultGet--oem Lock verifier Start
11-17 16:57:57.117  8036 11102 D OemLockVerifier: acquireWakeLock
11-17 16:57:57.118  8036 11102 D OemLockVerifier: wakeLock acquire.
11-17 16:57:57.198  2141  2141 E PhoneInterfaceManager: [PhoneIntfMgr] getAllowedCarriers: CommandException: com.android.internal.telephony.CommandException: REQUEST_NOT_SUPPORTED
11-17 16:57:57.208  2141  2141 E PhoneInterfaceManager: [PhoneIntfMgr] getAllowedCarriers: CommandException: com.android.internal.telephony.CommandException: REQUEST_NOT_SUPPORTED
11-17 16:57:57.712  8036 11102 D OemLockVerifier: WARNING: Hostname is not matched for cert.
11-17 16:57:57.936  8036 11102 D OemLockVerifier: queryVerifyResultGet()--resp_code1=404
11-17 16:57:57.936  8036 11102 D OemLockVerifier: queryVerifyResultGet()--verify_code1=
11-17 16:57:57.936  8036 11102 I OemUnlockPreferenceController: Verify oem lock Result : 404,msg: URL not found
Best Regards,
Hi @rohan, that’s strange. The unlocking seems to fail because the request returns the status 404 Not Found. The most likely problem is that the unlock code is wrong. Is it possible that you filled in an old unlock code? It is important to know that any new request for an unlock code invalidates the previous unlock codes.
So the order of the steps is relevant:
  1. Generate a new code from the website
  2. Try unlocking with the code that you just generated.
When doing that and if fails again, can you please verify that the logs show the correct IMEI, serial number, and unlock code?
One other strange thing is the message in your logs OemLockVerifier: WARNING: Hostname is not matched for cert. The certificate should be for factory.fairphone.com (the current one has fingerprint SHA-256 93:CE:7B:13:80:F8:A1:0F:2A:44:10:EF:43:7E:89:88:54:CD:09:58:73:A1:C5:51:DC:82:B0:29:D5:73:E0:CE). Is it possible that you are using a proxy or anything that would strip the certificate?
Edit: Clarified that the code must be generated from the website
Have you managed to unlock it by now?
This error might appear when the phone is not connected to the internet while unlocking. See Problem OEM unlocking "Inner unknown failure"
Yes after connecting to the Internet the code worked and the OEM was unlocked. Thank you.
Thanks @jftr. In my case I noticed from the logs that the last digit of IMEI1 was removed, supposedly an issue witnessed with my provider, whether it be Fairphone or any other device. Bizarre but true. Removed the SIM card, post which the device started reporting all of the 16 digts and the un-lock worked. Thank you for your help! Cheers,
Whaaaat? This is crazy and I don’t know how it happened. However, I am happy that you solved it.
