Just got the Fairbuds and linked them to my phone.
The app recognizes that they’re connected but doesn’t seem to be able to get the status.
Trying to change the equalizer settings does not work either.
Images added below
Images added below
After a first report of a serious issue with the latest Fairbuds firmware update, Fairphone reacted by halting the distribution of the update (and withdrawing the Fairbuds app from app stores temporily). See here:
I have indeed already read up on this. My issue seems to be unrelated to this however, that’s the reason I made this post.
I do not have any status from my Fairbuds in the app at all, they are usable without the app though.
Hi Sakloui,
The Fairbuds have both a Bluetooth Classic (used for audio playback and calls), and a BLE connection (used to communicate with the app). What you are seeing now is a state where the Fairbuds are connected to your phone, but the app can’t connect to the buds’ BLE connection. This can be fixed in a few ways:
After removing the Fairbuds and reinstalling the app I got it to work.
I already did these steps before but 3rd time is the charm I guess. Thanks!
Same here, brand new fairbuds, andriod app doesn’t show the percentages and the EQ doesn’t seem to be working. Latest app, the buds hasn’t been updated with any firmware.
I tried unpair, reinstall the app, location services on, but it doesn’t help. (Oneplus 10 Pro)
Any suggestion?
Update: It works in the updated app (2024.apr.17.)! Thanks!
I just paired a pair of Fairbuds both with an FP3+ running /e/OS and an FP4 running Fairphone OS (latest system version each). While the Fairbuds app version on both devices seems to be the latest, the Fairbuds app apparently cannot get the charging level nor the firmware version of the Fairbuds:
Any idea how to make the app retrieve the information? Or do I need to wait a long time until this gets shown in the app?
As far as I recall, especially with the old firmware, there was the need to pair the fairbuds twice:
Once for the audio via “normal” BT and once via BT LE for the firmware and battery information. The LE functionality usually requires location permission on the phone. Have you tried that already?
If I understood correctly, this should not be required with the new firmware any more.
(@BobVI must have been the one mentioning this somewhere, but I can’t find it right now.)
you can search for people as well ![]()
We faced the same during our HH meetup
, so good to know. ![]()
@urs_lesse do you have the latest version of the app?
Yes, 2.0 (15 April 2024). Will try the Reset thing later.
And I only allowed Location later, not upon the first launch of the app.
Curious, please let me know how it goes ![]()
Unfortunately no change. Still the status as originally described and shown in the screenshots above.
I actually did a factory reset (10 seconds button hold on the Fairbuds case, then close the box for 5 seconds) before renewed attempts. I deleted the app, then reinstalled it (still 2.0) – from Murena’s App Lounge on the /e/OS FP3+, then from Aurora Store on the Fairphone OS FP4 (I do not have a Google Play Store account). I then tried the same (for the very first time) on the Fairphone OS FP5 with Fairbuds installed through Aurora Store. Same result. I also chose the most “permissive” settings for each attempt now (most generous permissions possible).
Just to mention it: I can listen to music with the Fairbuds, although I tend to think that it’s the pre-firmware sound (could be shinier in the highest tones).
It’s been my fault, of course.
I kept misreading this (although Bob actually spelled it out pretty clearly …
), just keeping thinking of and allowing location permissions while never thinking of the actual Location button in the quick settings. Once I – finally – activated the latter, it was a matter of seconds … ![]()
Just mentioning: Location Services need to be kept on to see charge level and firmware status in the app and to allow the Equalizer to work.
Curious: If BLE requires location services to be turned on, does this mean that my listening with my “old” TWS earbuds (with location services off) drew more energy than necessary?
Or would the extra energy for location outweigh this?
Do they have an APP as well? I understand BLE is only for the App and normal BT is used to connect and listen to music, so GPS on or off doesnt matter in this cas
Just bought some new Fairbuds as well. I have the same issue here. I have location services on and gave it the right permission. Deleted and installed the app 3 times. Connected the Fairbuds multiple times but still no success.
Same Problem here. I think the App is still buggy
same here, also don’t have a stable connection on the app, never see battery life (on latest firmware).
also: is the battery life of the case not something you’ll ever be able to see from the app?
Exact same problem for me: Brand new Fairbuds. The app detected correctly the buds, then managed to update their firmware.
Afterwards, the app do not show the battery status anymore (but the Bluetooth parameter of the phone does it…).
And more: the EQ. seem to have NO effect.
The app is VERY disappointing.
Edit: I have red https://forum.fairphone.com/t/app-does-not-see-battery-firmware-status-of-fairbuds-android/107235/15 and my location IS activated.
