My review of the Fairbuds
So i’ve been using the fairbuds for about a month now.
I won’t comment much on the audio quality because there’s people out there that can do a much better job of that than me. For me it’s good. I don’t really care that much.
DISCLAIMER: I’m just making this ‘review’ to point out to Fairphone what they need to do to improve them. I LIKE THEM, AND I WANT TO LOVE THEM. I want to be able to recommend them with as few asterisks as possible. But it’d be lying if I said that currently they didn’t have a lot of problems.
My previous earbud experience: Samsung Galaxy buds2 (and a bunch of other buds from other companies that aren’t even worth mentioning-)
  • Repairability: The biggest pro of the Fairbuds is obv that they’re actually repairable. That’s the main driver for me buying a product like this. And knowing it’s Fairphone who have a long trackrecord of supporting their products as long as possible, I’m very confident they’ll do the same with the buds.
  • Size: They’re bigger than normal buds, both the buds themselves as well as the case. I put this in neutral cause it’s not a dealbreaker for me. This is just the result of having to make it repairable, so I’m not bothered by it. I do like small cases for buds because then I can easily put it in my pants pockets, now it’s… more of a backpack thing than a pocket thing.
  • ANC: The ANC is not as good as the buds2. Don’t get me wrong: both are pretty bad when it comes to ANC during a bike ride for example (on both I just turn ANC off then). But It feels like during ‘office work’, the buds2 are noticeably better than the fairbuds at ANC.
  • Staying in ears: Maybe because of the weight, I notice them being more likely to fall out after i’ve done a lot of jaw movements. The Buds2 didn’t have this problem probably because they just sit in my ear more than these do. But maybe having those silicone hooks that some buds have, would be a good addition on the fairbuds?
  • The app: … needs a lot of work… As seen in App does not see battery/firmware status of Fairbuds [Android] - #20 by Beurt, the connectivity just doesn’t work for many people including myself. When the app does work, you can do firmware updates (basic functionality obv but yeah). The app provides an EQ, I personally never touch that but good that it’s there. I find it weird how the app doesn’t auto know the color of the buds, you have to manually set that in the app… weird. You can see the battery life of each bud which is nice, but you can’t see the battery life of the case in the app. Sure you can click the button in the case and see the light, which will give you an estimate of how much bat life you have depending on the led color. But it would be nice it showed it in the app. The app shows you tips and explains the modularity of the device, which is nice.
  • Controls: related to the above point: the controls aren’t customizable as far as I can tell. In the Galaxy Buds2 app you can actually set what the controls are. For example changing the ANC modes on the buds on themselves. On the Buds2 you can go as far as saying “my left bud should switch between these modes and in this order. while if I hold down on my right bud it should do these modes and in this order”. Fairbuds doesn’t allow you to do any of this. Sure there’s only 3 modes. But it was such a nice thing, I had grown accustomed to never having to long press more than once. ‘I want ANC on mode, long press the right bud.’ ‘I want Transparancy mode, long press the left bud’.
    • Another annoying thing is that you can’t turn off the buds controls. So with the Buds2, in the app you can actually turn off the touch controls on the buds. This is A MUST if you are riding your bike in the rain so you have a coathood touching the touch surface of the buds because it will constantly trigger them.
  • Battery life: Good. I don’t need more. Have never really ran into empty battery (unless I’m dumb and forgot to charge the case in a while.)
  • Bluetooth: I think it’s related to my laptop and not the buds themselves, but sometimes the connection drops out a lot when i’m connected both my laptop and my phone at the same time.
  • Microphone: as with any earbud: it’s bad. This isn’t a nock against the Fairbuds, I’ve seen heard of a Bluetooth earbud that doesn’t have the microphone arm that goes to your mouth, have a good microphone, except the airpods. But doesn’t mean I don’t want it to be better.
  • Small things:
    • usb-c. I know it’s the standard now, but I’m glad it’s using usb-c
This review might appear negative, and yeah i’m pointing out a lot of negative things.
But in the end: They’re earbuds, they connect over Bluetooth, they play audio. A lot of basic things that they do, it does… so I kinda just have to point out the negative points instead.
EDIT: for clarification, this review was made before the V6.5 firmware update Software Update: Fairbuds App V2.1 (Android) / V2.0.4 (iOS)
Thanks for that review. It’s been helpful.
still having all these problems with them.
An issue I haven’t mentioned yet (and this might be related to your lawn mower problem).
sometimes the buds with certain types of repetitive movement seem to stutter in the audio and such
Another problem I actually often run into but haven’t mentioned it here yet either:
sometimes the case is charged well (green light) but i’ll take my buds out and one of them will already start complaining about being low battery… so it didn’t charge from the case… but it did shutdown (because when i put it in, it disconnected from my phone)… I don’t get how that’s possible though. Surely if it disconnects from my phone because I put it in the case, that’s because it’s started charging…
I’m going to contact Fairphone, this is unusable.
If i’m only using my right bud, it will just shut down after like 5 minutes of active listening, being in my ear. fully charged.
ALSO another thing: taking out the right earbud and having it lay on the table turns it off after like 10 seconds or something. the left earbud doesn’t have this short of a turn-off timer
This is certainly not expected behavior and you should definitely let them know, yes!
Thanks for this. I have used the Fairbuds for over a year and not been massively impressed, non of the issues you mentioned with the app have been fixed.
Saw a deal for Galaxy Buds 2 for £39 and decided to sell my fairbuds and use Galaxy Buds 2, thanks for the direct comparison between the 2.
sorry, forgot to mention this here. this has been resolved. water damage happened: My fairbuds case under warranty need a repair that costs the same as a new pair of buds?! - #28 by Thibaultmol
I have also not seen any firmware updates except the one close to launch. which i’m honestly surprised by. I get that it’s a small team. But not a single tiny fix happened since?..
Somewhat relatedly, I see the Fairbuds are now 25% off on the official Fairphone shop. I sent mine back a few months ago (too many issues with sound output, I got a full reimbursement) and I don’t have anything as a replacement right now. I wonder if it is worth trying again…
Edit: it’s part of an official campaign :slight_smile:
I read your review after I had ordered the Fairbuds - and the fact that you can’t turn off the touch panels freaked me out: I live in Norway and cover my ears more or less half the year! However, the support chat told me to try it for two weeks - they would give me a full refund if I was not satisfied. Now, I have tried them for a few weeks with woolen hats and fleece hats and whatever: No problem at all :slight_smile:
I have not had any other issues either - they are reliable, easy to use and the connection is far more stable than the Bose and Sony I have had before. The sound and fit is good, as well as the look. (Ok, the Sony XM4 had even better sound than the Fairbuds, but they were twice the price and not repairable or fair. And without the XM4 (lost one, can’t by a replace…) I don’t notice any more. Also, the Fairbuds fit my ears better than the XM4).
I would be interested in upgrading from my Fairphone True Wireless Stereo (TWS) to these new Fairbuds, but according to the manual the one issue that irritates me the most about the TWS is still there also in Fairbuds: it’s not possible to reprogram the controls.
Skipping backward or forward in titles always requires tapping left or right buds 3 times. If even one tap misses the bud even slightly then playback stops (since start/stop is hardwired at 2 taps). This is infuriating especially when listening to podcasts (where rewinding a couple of seconds is also done by tapping back). That’s a lot of careful tapping one needs to do!
If I read correctly Fairbuds also don’t offer an option to reprogram these Bud controls with the Fairbuds App.
I can do that in my Sennheiser Sport True Wireless Buds (only 2 taps for rewind, they are more precise in detecting my taps) and I find myself preferring these to my TWS even in everyday non-sport settings, as I listen to many podcasts.
I won’t be upgrading to Fairbuds any time soon as long as this is not addressed.
Is there any outlook for adjusting controls in Fairbuds with future SW updates?
