Lastly I want to finally shortly report about my UpdateProcess from FPOS/Android5 –> LineageOS14/Android7, promised one month ago some posts above:
Here we go:
- My starting point was: FPOS 1.12 / Android5.1 / rooted with SU manager app / TWRP already installed / working ADB (from root process some time ago) with ADB Minimal (and now again tested for emergency cases
) - First I did a backup:
- Choosing “Backup” in TWRP (Boot, System & Data), to ext. SD card
- using TitaniumBackup for all Apps and their settings
- using EasyBackup (4.9) for Call logs, SMS, contacts, calendars)
- copied all data from internal storage to PC
- During update I kept external SD Card inside FP2 (data should be copied to a PC).
- I downloaded and saved to external SD card:
- addonsu-14.1-arm-signed.zip (For superuser / root access)
- latest modem files ZIP
- OpenGApps pico (which I did not used at all, thus having still a google-service-free FP2)
- TitaniumBackup as APK
- basically I followed the official instructions of the LOS-wiki:
- inclusive the “swipe cache” point
- I put all ZIPs in the install queue of TWRP and let it work (~2 min)
- queue order: LOS-nighlty.zip → addonsu.zip → modem.zip
- reboot took some minutes but could already watcht the LOS boot logo
- Funny fact: all my data in the internal storage survived. I thought with “wiping” in TWRP they should be gone…but they wasn’t
- After first boot I restored my data:
- installed TitaniumBackup and tried to recover as much as Apps & App-data as possible. Not worked with TitaniumBackup the restore of:
- Contacts, SMS, call logs
- Calender settings of DAVDroid (I had to manually re-create them)
- Conversations with XMPP and OMEMO encryption account: I forgot to first deactivate my account before creating the backup (as stated in ReadMe). If I would have made this, the move of the data had been no problem!
- Contacts and SMS I restored with EasyBackup (contacts directly to Phone Storage without any Google Account, which was much more difficult in FPOS-Android5.1! )
After all this in principle very easy procedur if one once figured out how it works, I was very happy wiht a nicely running LOS, that:
- provides nearly all features which I loved in GravitiyBox before directly built in
- additionally:
- finally the bug of the disconnecting WiFi after 10mins in Sleep mode is gone
- I finally found and successfuly uses the app “Battery Charger Limit” to stop charging automatically at a certain value (e.g at 90%). FP support told me once, that this is not even feasable - but it is!
- finally, the delay between dialing a number and the establishing of the caller signal-beep-beep is very small (~1-2 seconds) in comparison to FPOS before (5-10s).
- It was not neccassary to install any SuperUser-Manager (seems to be built-in in LOS already).
- Activating the root access was easy (in developer options, which you active by tapping 5 times onto „Build number“ in “About Phone”)
- I installed the bare GoogleMaps APK and have a working google maps, without the need of first installing GApps!
- But until now AFAIK it is not possible to install XPosed Framework.
Bottom line: moving to LineageOS was much easier than I expected and makes much more fun than I hoped ![]()
After that gigantic post…I have to stop now ![]()
Cheers, Robert
