So, here is some news, which could be of interest to many of them here:
Have a beautiful day!!!
Installed Xposed yesterday on LineageOS without any problems via the Xposed Installer App. I chose Framework 88.1 and install via recovery. The phone restarted and installed the framework in TWRP automatically.
Installing of Gravitybox [N] and Rootcloak work, however I had my first (!!!) random reboot ever on LineageOS this morning.
I removed now Rootcloak (since it might not be up to date with Nougat).
Will test further and let you know about issues
I don’t think that it is a good idea to use Gravitybox on LineageOS. From the release thread:
and
Maybe it’s a good idea to move the XPosed-for-LineageOS-Discussion to a separate thread (@paulakreuzer ?). Nobody will find it here.
But I think I already mentioned (some 100 posts ago…), that it’s not the best idea to use XPosed and it’s modules with Lineage. I filed a LineageOS Bug some time ago and they clearly excluded any support when using XPosed…
I have installed Xposed and I can’t complain. I am happy to have Xposed.
However, I do not have GravityBox. This sentence, which I found in the description page of the GravityBox(N) module refrained me from installing GravityBox: “SHOULD NOT be used with custom ROMs like Lineage, AOSPA, or any other derivative- it makes no sense since most of the features are already in the ROM (may cause conflicts and unexpected behavior)”
The modules I use so far:
FakeGapps (for microg: I could not patch the signature with Tingle, so that is why I use this module, for signature spoofing)
RootCloak ( works fine so far)
This App will Run Without Google Play Services (for the App from my local football team)
Regarding battery life, I did not notice any difference. Battery life has been pretty poor ever since I started using Lineage. I have gotten used to it. I do not use Greenify. I have never been a fan of it.
Hope these lines are of help…
Cheers
has anyone installed it along with Magisk ?
I installed only magisk to hide root from my banking app. It works like a charm. But I have not tested it with Xposed, since I prefer the PrivacyGuard from LineageOS.
but Xposed moduls allows to do much more as what PrivacyGuard can do, not only in the sense of privacy and apps permission. I think of OS customization etc.
In particular it allows to run apps (e.g. Amplify ) what hopefully allows me to improve battery life
how to you hide root, to have an app switching root on/off such as iSu?
When I enable root in the Developer Options the banking app complains about the device being rooted. However with Magisk you can enable root for specific apps only.
I did the following:
/storage/emulated/0/MagiskManager/patched_boot.img) with TWRPthx for the tutuorial
what apps your are running as I’ve got
I am only using TWINT, which keeps complaining about missing google service framework but works nonetheless.
I might try others in the future.
Would you mind to try DKB-TAN2go as it even doesn’t start on my FP2.
Stuff like exposed is not supported on official lineage builds. This means you cannot file bug reports.
Chris
DKB-TAN2go does not work for me either…
thx for trying, what a pitty ![]()
hallo again,
another question is OTA working properly?
I asking as isn’t that simple Fairphone OS
For me, OTA update of LineageOS works properly. But I’m not aware of Magisk things, I use plain LineageOS.
When you use Magisk you can’t use LineageOS superuser binaries, can you?
