Hello
Since the software update yesterday my phone says: ‘quickstep keeps stopping’.
It’s is teally anoying. I tried different things without a solution:
reboot the fairphone
forced stopping of the app
clear cash and stored data of quickstep
reboot the FP in safe mode, the problem stays
Inm on holiday, so factory reset and installing all my apps is the last thing I want to do. Are there other things I can do to solve this?
I’m facing the same issue after the android 15 and the google play updates (so I’m not sure about the culprit). I’ve done the same steps as explained above.
I don’t have any other launcher btw. I have sent a message to the support, I hope that they will be able to solve the problem.
Follow-up message: I did perform a factory reset again and the issue is resolved.
I also had issues with phone calls where the other side couldn’t hear me, that was resolved by the factory reset as well.
Same problem here.
Of course tried deleting app data, same result as above, lost customized home but still crashing.
And I really don’t want to perform a device reset and loose all my data.
So, like proposed in another topic here, I installed another launcher and made it default in system settings.
That’s what I did (you can read it just few posts above), but, do you think it’s a normal situation?
Next update if it’s settings app that crashs, will that be an option to “install a different settings app” ?
