How to Install Lineage OS on FP2 for dummies
Hi, I tried to find the relevant information and learn about rooting, flashing etcetera…, but I’m far from an IT-specialist. So now I’m drowning in all the information. Can anyone tell me how I, step by step, should install Lineage on my FP2? That would be great!
tnx
btw I already know where to find the ota zip (https://www.androidfilehost.com/?fid=817550096634770220)
  1. Download the file on your phone or move it there from your computer.
  2. Reboot your phone to #dic:recoverymode
  3. Perform a #dic:hardreset
  4. Install the file via recovery mode.
PS: Sorry, since I never used the standard Android recovery I forgot to mention that you need TWRP first. So, as @Paule says it’s best to install FP Open first (Thanks for the hint @Sietse).
  1. Make a backup.
  2. Make a backup.
  3. Make a backup.
    :wink:
    Than continue with the points mentioned above.
Btw, one of the easiest ways to install it is with FP Open installed - at least that’s how I did it.
  1. Download the file onto the external SD card of your phone.
  2. Start into TWRP.
  3. Perform a full backup of your system to the external SD card.
  4. Wipe the phone.
  5. Install the downloaded image of Lineage.
  6. Reboot.
Enjoy! :grin:
If all of this sounds like black magic or vodoo, I would not recommand to try it. :jack_o_lantern::japanese_ogre:
Tnx all!! I’ll let you know if it all works out :smiley::smiley:
If you have doubts, you can at any time ask questions at the community chatroom: :slight_smile:
https://chat.disroot.org/#/room/%23wearefairphone:matrix.org
Shouldn’t you first make sure TWRP is working, for which you first need to root the phone.
Or am I missing something?
Is the download link for Lineage OS down?
EDIT: link is up again: https://www.androidfilehost.com/?fid=889764386195904774
No, you don’t need to root the system for TWRP recovery to work, :slight_smile:
Again tnx for the comments! I tried to get everything to put it into a step-by-step procedure to be sure. Right now I’ve got FP OS Open 16.07.1 on my phone. I don’t have any personal information, like contacts, photos or apps I want to keep. My phone contains primarely the apps from the FP OS Open. That leads to the next questions:
1a. Do I need to backup in this case? I suppose that it’s not nessecary to backup for the apps which come along with FP OS Open, cause Lineage will provide for the most basic apps and if not I can download apps from F-Droid for example.
1b. If I don’t need to backup to keep personal information etc, do I still to backup to have an image of my current system to be able to go back?
1c. If I do need to backup, can I do this by using the system option ‘Make a backup and reset’ on OS Open?
1d. If 1c is ‘yes’ do I need to put the backup on my computer or can I put it on a sd-card in my phone?
1e. If I have to put the backup on my computer, do I have to download and install Android Studio on my computer first?
Further on I understood that, if I do need to backup, I need to root my phone to be able to make a backup with Titanium. When I don’t need to do a backup with Titanium, I am now confronted with the next question whether I actually have to root my phone to start into TWRP. I read in one of the comments that that is necesarry. That leads to my next questions…
2a. Do I acually need to root my phone to start into TWRP (I just read that that is not necessary…)?
2b. If I root my phone, I suppose I have to use the option ‘ ADB only’. Is that correct?
2c. How do I know if TWRP is working?
2d. What happens next? Do I have to write command lines myself, or can I just reset the phone and install the image of Lineage?
And my last questions for now ;-)…
  1. Do I need to download and install modem firmware?
  2. I am still missing something?
Thnx a lot! That’s it for now :wink:
No, Lineage OS can be used out of the box and anything you’ll need you can get from F-Droid. (F-Droid is not pre-installed, but a browser is ;))
No you can simply wipe data in TWRP and install Open OS or FP OS to go back.
If you wanted to do a backup you should do it with TWRP
Open OS comes rooted. You just have to enable it in Settings > Developer Options (which is visible after you tapped 10 times on the build number in Settings > About Phone).
TWRP doesn’t need root.
If you want to use Titanium Backup you’ll need to enable root for apps
If you boot to dic:recoverymode and that recovery is TWRP, then it works. :wink:
Just wipe data in TWRP and install the Lineage OS zip file in TWRP.
I didn’t but some people say this fixes some dual SIM issues.
I don’t think so. :wink:
This totally worked, very straight and simple. Thank you Paul!
Btw. I updated my modem drivers to those from FPOS 17.04.08 prior to installing Lineage OS as recommended in this thread Porting LineageOS to FP2.
For this purpose it contains a flashable zip file to be used with recovery. Very convenient I must say.
@paul tnx!
I just tried to do it, but unfortunately it failed. I got the message ‘Zip signature verification failed’. I don’t know what went wrong… :neutral_face:
if I tap on the button in the middle below the twrp menu I get to see the following:
E: unable to find partition size for '/misc’
E: unable to find partition size for '/bootselect’
Updating partition details…
…done
Full SElinux support is present.
E: unable to set bootloader message.
MTP Enabled
Did I brick my phone or can I get back tot FS Open?
tnx…
some more information:
I had ‘me.twrp.twrpapp-26.apk’ on my sd-card and the adviced ota_zip for lineage. Maybe I had to download another image? The other possible mistake is that I tried to do everything in TWRP v2.8.7.0?
First thing: don’t Panic! :grin:
You did the Wipe before, right?
In TWRP, do the following: go to “install”, select “lineage_FP2-whatever.zip”, uncheck “Zip file signature verification”. Than “swipe to confirm flash”.
If you want to install open GAPSS as well, repeat the last step (of course without the wipe…). You can download them here. Choose ARM/7.1/nano.
Than reboot.
And remember: don’t panic!:grinning:
It’s a better idea to do this with the latest TWRP-Version. You can flash it from the old TWRP version (Install → Image). Then do what @Paule said. :wink:
@Paule It worked!!! :grinning::slight_smile:
Unfortenatly the setup wizard after the connection with wifi is made… Just install lineage again?
I don’t know what you mean? Does it crash?
You can always bypass the setup wizard by touching all four corners clockwise, beginning from the upper left (here is a quite old video about this, but should still work).
