🇬🇧 🇩🇪 Random reboots with (official) Lineage OS?
:musical_note: i feel good :musical_note: (20 characters)
Why not opening a new topic for CVE questions? This is about random reboots.
Chris
Today the first reboot. :slight_smile:
last_ksmg_15112017_01.txt
Steven
Thanks! This is a nice and clean one to analyze, great! :slight_smile:
and this is with the boot.img I gave you, correct? You reflashed boot after the upgrade?
Chris
Correct?
Steven
Yeah, sigh. Seems this doesn’t fix it then :slight_smile:
Chris
As far as I know, until now only @StevenHachel reported one reboot with your latest build, and that crash - again - seems to be related to the Apple router in his office. As long as nobody else will post another unrelated reboot, I believe that your intensive effort to fix the WiFi issue of @StevenHachel might have fixed another problem, possibly some memory corruption, and your hard work has been worth while so far.
Indeed, thank you very, very much for your commitment, it is very appreciated! :point_up: Please, keep it up! :slight_smile:
Exactly, the restart took place in the office with the Apple router. :slight_smile:
Steven
If you can imagine memory issues, it might be worth considering doing a memory test. Seems like there is a port of memtester for Android (needs self-compiling), maybe this could be worth a try?:
@chrmhoffmann, I’ve installed yesterday’s LOS build (together with your boot_rollback.img) today in the morning. Haven’t seen a reboot since (but to be honest, I haven’t found the time to use the phone very much today). But no reboot so far is good news imho. So, thanks for the image, I’ll keep you updated :slight_smile:
Still without random reboots today! :slight_smile: Not even a single one, all day long. :slight_smile:
So, :thumbsup: from my side
Thanks, @chrmhoffmann!
For me it is also very stable. Unless I use my (Apple) WLAN on work, it crashes at some point.
With your bootimage the Bluetooth does not work anymore, right?
Correct Bluetooth is broken with your special boot image as I need to revert stuff on the device tree.
Chris
So, unfortunately, as there have been reports of random reboots, I decided to roll-back kernel. SIGH
Big breath…
Kernel is now still
  • CAF merged rb1.15 also for prima (wifi)
  • alarm timers remerged
  • seccomp enabled
  • f2fs capable
  • latest fairphone kernel merged
What is gone: linux stable merge (kernel reports again 3.4.0), linux common merges.
I think I have to go through all CVEs again to see what is not fixed :frowning:
This hopefully will reduce device reboots.
Chris
Thank you for all the work.
Steven
@StevenHachel @struppi please update on tuesday with new image and keep reporting random reboots. Looks like not all problems will be solved (notabily the one that is potentially connected to apple wifi routers).
Chris
No reboots for the last six days from last Tuesday til today! I am really pleased, but is it possible with the next update to get Bluetooth back?
@chrmhoffmann For our test images that will probably not come in first, right?
You will not need to flash test image anymore. With the next update from lineage you should have the same as in test image (with working Bluetooth).
Chris
