ATTENTION!!
- This wiki is just a list by FP4 users.
- It is there to share experience with USB-C to headphone jack adapters.
- It is nothing official by Fairphone.
- Fairphone sells an adapter as well: USB-C to Mini Audio Jack Adapter (3.5mm) - Accessory | Fairphone
There is already some information in the following thread, please use this thread for metadiscussion
All posters of this thread are invited to update or specify the information or add anything new.
This is a wiki, so everyone can edit to add experiences.
Which adapters work and which don’t? What exactly works (incl. Volume control etc)? Does it include a DAC chip?
Fully functional adapters
Sharkoon Mobile DAC PD
todo: edit which exact features work -
[cellularline music enabler type c] (https://hybris:9002/en/Audio/General-audio-accessories/MUSIC-ENABLER-TYPE-C/p/MUSICENABLERTYPECW). Tested with sennheiser CX 2.00G, audio output and all three buttons work.
hama Audio-Adapter, ArtikelNr.: 00122338 (gold plated contacts; tested only playback)
Works with a mini mic, a device for streaming audio to hearing aids, cochlear implants, etc. OEMed by many manufacturers; output to devices via FM; input via audio jack (among other possibilities)., -
hama Audio-Adapter, ArtikelNr.: 00200318
(sound with InLine Woodon-Ear headphones great, nothing else tested) -
hama audio and charging adapter, ArtikelNr.: 00187206 (includes DAC, audio playback works, simultaneous charging does work using the FP USB-C 3.2 cable with apple USB charger)
hama audio and charging adapter, ArtikelNr.: 00200319 (same as the one above, just without gold contacts)
Google GA00477-WW USB-C Digital to 3.5 mm (Play/Pause, Volume, Microphone - work fine)
Samsung EE-UC10JUWEGWW - audio playback works fine
[“Sandstrøm USB C to 3.5 mm audio adaptor - S6UC3519”]
Audio tested ok -
Vention USB-C Male to 3.5MM Earphone Jack With DAC Adapter 0.1M Gray Aluminum Alloy Type Works okay with simple earbuds, volume is good. Haven’t tested volume control/mike. ~ 200 CZK/ 8 EUR.
Fiio BTR3K Tested in USB DAC mode, which needs an USB-C to USB-C cable (not included) to function. Media controls weren’t tested.
Logilink UA0356 usb-c to 3.5 mm jack Audio and mic ok
UGREEN 90°, https://www.amazon.de/gp/product/B08TR7LWQH works nicely, including microphone and the control button, audio seems to be good.
Delock 65842 works fine with fp4. Interesting is, that they say which dac Chip they use (cmedia cm119B).
https://www.reichelt.de/adapter-usb-c-stecker-klinkenbuchse-delock-65842-p207729.html?&nbc=1 -
Sharkoon Mobile DAC - tested with a Marshall Mode and a Sennheiser HD 380 Pro. Audio playback works fine with both. There is soft but noticeable noise with the lower impedance Marshall Mode (30 Ohms), which is not an issue with the Sennheiser (54 Ohms). Play/pause and voice recording work fine with the Mode (Sennheiser doesn’t have an inline remote). Skipping ahead/to the next song (by double clicking) works as well, although some app behaviour is weird (e.g. double clicking in Podcast Addict sometimes pauses, sometimes skips ahead, and sometimes does both). This is a DAC suitable for high-impedance headsets, not low-impedance ones.
Anker USB-C to 3.5 mm Audio Adapter - tested with Marshall Mode and Sennheiser HD380 Pro. Everything works as intended: no noticeable noise, playback button functions flawlessly. Sturdily built: all-metal housing and thick, braided cord. Only available on the US & German Amazon store.
ddHifi TC35B 2020, https://fiio-shop.de/988/ddhifi-tc35b-2020 - tested with beyerdynamics Soul Byrd and active speakers from Nubert.
Audio Playback works fine, no noise, no crackling, wonderful sound. The buttons for volume, play, pause are working. Used as headset the microphone is working as well as the buttons for volume and for hang up. And you won’t find a smaller one, just one piece of metal, with a plug on one side and a jack on the other, no cable between them. Recommended. -
sunnylan, simple but efficient adapter with a 2 in 1 function : you can charge and use a 3.5 headphone. It has no DAC inside, but it’s only 17€ : USB C to 3.5 mm adapter for headphones and charging, C-type 2-in-1 audio adapter with fast 60 W charging (<–amazon .fr link) I use it every night.
Problematic adapter
Describe problem:
Apple “USB-C to headphone Jack”
Audio tested with a video and mic tested with the voice recording. The buttons on the remote (of a Sennheiser CX 2.00G) seem to work partially though: the single press centre button works, but volume buttons only raise the volume all the way up or all the way down and double pressing the center button to skip a track is not recognised by e.g. Spotify. Please note that this adapter hasn’t worked for every user, as some report hearing a loud hissing/static noise during playback. -
[Baseus Audio converter USB-C to 3.5 mm jack charging and audio] - audio does not work, have not tested charging
TINICR, https://www.amazon.de/gp/product/B07WZN9QXM: charging worked, phones did not.
Teufel, https://teufel.de/usb-c-auf-kopfhoereranschluss-adapter-106314000:
does not work with every headset:
→ works perfectly with separate headphone and no-name-microphone without buttons
→ with Beyerdynamic Soul Byrd playing music is fine, wonderful sound, incl volume setting and pause/resume-button - in telephone modus the buttons for volume and hang up are working, I hear my partner, but the microphone is dead.
(contacted Teufel: they confirm problems with the Soul Byrd and offered me a return.)
So, for just music or a headset without buttons this adapter is a recommendation, for others not. -
NIMASO Adaptateur USB C Jack 3,5mm : sturdy looking cable, but noisy hissing sound at low sound level, does not work on my windows 10 PC, no jack detection. I replaced it with an apple adapter, without issues so far.
Adapters not working at all
- Huawei CM20 USB-C/3.5mm-jack adapter: not working at all, one forum member mentioned that there’s no driver chip in the adapter, so this adapter only works with certain huawei phones.
