my fairphone suddenly had no reaction. after trying a normal restart its dead. no way to turn it on since two weeks now. charging shows nothing, no blue led, nothing. The Akku was almost full when it happened.
I wrote to the support team and got one response: I shall try different chargers and cables and clean the USB port. I did, with no success. since 10 days the support team does not answer, I wrote several times.
I’m quite disappointed. I´d like to send it in to fix that, its just two years old:(
do you have any glue what to do?
greetings to the swarm!
philipp
Hi and welcome. I would advise to call support, number can be found here contactsupport.
There are a few reports with similar description
So you did get a response and presumably carried out soem instructions, which were to try other chargers and cables. ??
Cleaning the port isn’t easy , you may have tried but failed, there is a post a bout that ~ i’ll try to find it.
The other issue is that you say you wrote several times.
It only clogs up the in-tray if you ‘write’ email etc. more than once. Yvmuell has indicated you can call, which often makes a huge difference as you get to speak to a person, not an inbox.
Still meanwhile try to find someone with a battery to check it is just a charging problem.
Remove the bottom module and more to clean and ensure the module contacts are seated. There are lots of posts on such.
the appliance has never been exposed to moisture…
I found threads where the problem was the motherboard and only sending it in could solve the problem. where can I send in my fairphone?
Follow this link
https://support.fairphone.com/hc/en-us/requests/new
I wrote several times…
You mean you have filled out the online request several times? Did you get a new ticket number each time or ‘what’ response did you get, any? Not even an email of acknowledgement ?
email of acknowledgement - yes
further reaction - no
Not to forget, this is still valid …
I have exactly the same problem! I bought a fairphone 3 in 2020 with only 2 years warranty. On the day one month after the warranty expired, the phone stopped working. I received no help from support as the phone is no longer under warranty and bought a new battery to see if that was the issue. Today the new battery arrived and my phone is still dead. Which other part could be the issue? I noticed that there are several other people here with the same problem. Does fairphone have planned obsolescence?
I doubt it but modular phones can be a bit frail.
Regarding your issue:
You can dismantle the phone and check and clean all the module contacts. I’m surprised you bought a new battery? Did you test the battery voltage etc.
Power to the main module is controled by chips on the motherboard and the USB port has a path to charge the battery.
So sadly if the main module has failed it will be an expensive repair. So the best you can do is read a lot of similar topics to see what others have done.
Given the warranty has expired all Fairphone can do is a paid for repair.
hi there,
i finally reached support, i think via phone and they still accepted my phone as a warranty case. i wrote many emails before and got upset and hoped for goodwill. that worked out. i got a return order and sent it in for repair. 2 weeks later I had my Fairphone back and since then it runs wonderfully.
the mainboard was broke, the heart of the phone.
I wish you much success. stay tuned!
I spoke with support today, and after having a look at the price list for repairs, I came to the conclusion that my fairphone journey ends here. I had faith in this project as a path towards more sustainable electronics and towards repairability. Therefore it comes as a huge disappointment that the phone died after precisely 25 months, I can’t actually repair it myself and having it repaired would yield me a phone with no warranty for the price of a new Samsung A33 with 5 years of warranty. ![]()
I was wandering that Samsung brings a product in the cheap “A” class with 5 years of warrenty.
Or is this maybe a typo?
In Germany all Samsung mobiles have only two years of warranty. Maybe the update promise was meant.
So as 5 years isn’t standard maybe you could provide a ref: for such a buy.
Further see
