Hello to everyone,
I’ve got the problem that after i installed the Fairphone OS “1.8.5 Kola Nut” manually from the “Download” directory, like in this explanation:
First I explain you what I’ve done:
My Fairphone was or is this Version: FP1 old partition layout - Late 2013 / Early 2014 (1st batch)
So I’ve downloaded the Updates:
FP1_KolaNut_v1_8_5_OTA and Storage_Upgrader_1_8_5 like it is adviced in the Step-by-Step tutorial.
After I followd every step, the Fairphone worked correctly with the new system "KolaNut 1.8.5"
BUT
everytime I restarted the Fairphone there comes the Message that I should install the “Google Apps” so I install them, the Updater download the Google Apps, than it says "Restart your Device"
I tap the Button Restart, the Phone Shuts down, than it Starts, the Blue Fairphone screen comes for 5 seconds, the Android Robot comes, there is an status bar how much is installed, and after about 20% of this installing bar, the installation aborts, the phone start again and booting into the not updated Fairphone OS.
So at the next times I’ve tried many things for example to press the Powerbutton wenn the Loading bar stocks. there comes the “Phone Recovery Mode” and it is displayed the Message “Signature verification failed”.
Also in “Recovery Mode” I can’t even browse to the directories where the update.zip is. So I can’t even install Updates manually th the Fairphone.
I’ve really no Idea what I can do. I’ve also tried to install Previeous Versions of Fairphone OS and Stock Android Version 4.2.2 but nothing can be installed everytime the phone reboots at 20% or when i go in recovery Mode it shows me “Signature verification failed.”
Please help me with this prob,
There is another abnormal thing: If I try to install Google Apps there is no question to Superuser for the Fairphone OS.
Thanks, fdblvw
thanks for your great work.
