How to close the settings app? I needed to add a fingerprint because I removed it. And that’s something I need to do in the settings app
I did the following: I removed my unlock pattern and added a fingerprint. Rebooted the phone. Now when I’m closing the screen my phone automagically unlocks.
I tried using ’ adb logcat’ and got an insane amount of lines between closing the phone and that the phone unlocks itself. I’ll try capturing it.
This is the relevant output of adb logcat I think; I started logging when the phone went to sleep and let it wake up without my interference. I put it in a text file due to the length.
I can’t confirm that. As of may 28, with working frequency scaling, battery usage is ok. Not as good as with LOS 17 (which might be caused by the test UN’s debug features), my drain is at .8% the hour (in airplane mode, though). Still something to look into, but I’m not charging twice a day as with the first version
I’m trying to build lineageos 18.1 for FP3+, but i get this error:
FAILED: out/soong/build.ninja
out/soong/.bootstrap/bin/soong_build -t -l out/.module_paths/Android.bp.list -b out/soong -n out -d out/soong/build.ninja.d -globFile out/soong/.bootstrap/build-globs.ninja -o out/
soong/build.ninja Android.bp
error: device/fairphone/FP3/light/Android.bp:16:1: module "android.hardware.light@2.0-service.msm8953" variant "android_vendor.30_arm64_armv8-a": depends on //system/libhidl:libhid
ltransport which is not visible to this module
error: device/fairphone/FP3/light/Android.bp:16:1: module "android.hardware.light@2.0-service.msm8953" variant "android_vendor.30_arm64_armv8-a": depends on //system/libhwbinder:li
bhwbinder which is not visible to this module
00:25:03 soong bootstrap failed with: exit status 1
Thank you for the welcome, I’m glad to be here, also i got my FP3+ last Wednesday.
So, I did the fix, and the build started, but failed with a new error:
make[1]: Leaving directory '/LineageOS_18.1_src/out/target/product/FP3/obj/KERNEL_OBJ'
make: Leaving directory '/LineageOS_18.1_src/kernel/fairphone/sdm632'
depmod: WARNING: could not open modules.order at /LineageOS_18.1_src/out/target/product/FP3/obj/PACKAGING/depmod_vendor_intermediates/lib/modules
/0.0: No such file or directory
depmod: WARNING: could not open modules.builtin at /LineageOS_18.1_src/out/target/product/FP3/obj/PACKAGING/depmod_vendor_intermediates/lib/modul
es/0.0: No such file or directory
23:06:14 ninja failed with: exit status 1
These are screenshots after i ran brunch FP3, and the build fails just after Building Kernel Image.
It seems I have to wait till the merge happens, also I do not know how to manually checkout with the latest HEAD, or Which directory should I be while doing the checkout?
I have very recently bought a Fairphone 3+. As a first step I’m now planning to install LOS on the phone. But as LOS 17.1 will probably soon be replaced by 18.1 I would prefer to wait till 18.1 will go official - in my experience with my old phone (a 10 year old Samsung Note 3) it’s not so easy to go from 17.1 to 18.1 or from inofficial to official - I had in any case to make a full wipe, so better wait. Is there any hint how long it will take?
Thank you, looks good! But my old Note does still works, only small problems like loosing my stored contact data - but which can be restored on the way. So I’m waiting for the LOS and hoping there will be an updated Nanodroid Patcher as well soon.
WoW, I just saw now on LineageOS download link, lineage-18.1 for FP2, so i guess we can expect lineage-18.1 for FP3 anytime on the coming days. lineageOS 18.1 is going official for FPs, YESSSSS.
