In this project I want to build a prototyping shield with space for a uC and a area where you can set up your own wiring. Additional I want to have also a charging port in which you can solder the wires of your qi-charger or whatever.
If you eant to increase your soldering skills, or need somthing soldered, just text me. Looks like it would not be a long drive as your are located close to me
PCBs are produced and will be shipped
Parts should have been delivered but I wasn’t at home since monday…
And today I will order the stencil to get a good soldering result !!
I already have my qi-charger ready and think about installing magnets for an usb-adapter-cable (like the macbook-plugs), so i can use my keyboard on my phone
-> IR communication ( https://learn.sparkfun.com/tutorials/ir-communication )
-> adding environmental sensors like LDRs or air pressure sensor (temperature sensor allready included)
=> basicly you can add allmost every sensor
-> doing some light shows with the build in 8 blue LEDs or the WS2812B (also on the board)
=> so basicly the use cases are allmost endless and you can build whatever you like
