Hi there!
I’m considering buying a power bank for my FP3. What would you recommend?
Cheers,
Nhezumi
Hi there!
Cheers,
Nhezumi
Any! All Power banks will be compatible with your device, as long as you check it has USB-B output (standard USB), and you have your charging cable.
For more technical specs, all depends what you want as power, but all powerbanks should be compatible. I don’t really understand what recommandations you are asking for.
Well, if you want it to match up with Fairphone, you should have a look here:
Not the most shiny or tiny ones and totally not cheap, but socially responsible.
Otherwise - as @Alex.A already wrote - it depends on your needs and wishes.
Edit:
And you might take a look at these threads:
Thanks guys for your answers. I’ll check Waka-Waka.
Actually, what I’m looking for is a power bank that would give me enough power for a text or a phone call until I can charge my phone. Nomad usage mostly then. So size and weight are things I’ll need to consider.
