Yes I had the same issue. The battery would lose ~50% in ~10 hours. At some point I wasn’t even able to charge the phone anymore, but rebooting it did the trick. I think the last update solved the problem for me. I might have to check again to make sure.
P.S: I’m on lineageos for microg
Hi. How can you tell that ? Thank you. ![]()
I’m very glad that the May 17 build installed and rebooted without me having to press the Power button
Hi folks.
I am running out of things to [attempt to] fix on the 17.1 release and I think it is time to freeze 17.1 and concentrate on 18.1. I aim to get the upgrade released without people having to lose data and wipe their device - or at least be able to use SeedVault for migration.
Let’s do a little poll using the heart icon below the following two posts to get an idea on what the opinions here are.
Go for 18.1, never mind possible data wipe or open bugs.
Nah, let’s wait a while longer and stick with 17.1 for now.
I voted for a little wait, still, because I’m needing the phone. Still, I’d definitely would like to see the upgrade possibility and not mind a freeze, if a migrate later on still would be possible…
That said, i do have seedvault activated, but just no experience with that…
I think it is on the system info page in Settings
FYI to whom it may concern, 18.1 skips the AOSP email app, and the calendar app is replaced with the open-source Etar calendar app with some enhancements from the LOS team. The native exchange account support is skipped as well.
I guess we can add back Email/Exchange support. This should be device specific. I’ll have a look once.
Hi all,
The latest UNOFFICIAL version of LOS 18.1 is now ready(with just one bug of display becoming too small on first boot). I have tested 17.1 to 18.1 upgrade and it works fine without data loss.
More here: [ROM][UNOFFICIAL] Unofficial LineageOS 18.1 for Fairphone 3/Fairphone 3+ - #33 by TeamB58
Exchange support (for calendar and contacts) would be the dealbreaker for me. If it works on LOS 18.1 I’d go for that, currenlty I’m on /e/ where there is no exchange support.
Sure. I’ll look into it once we’re official.
I would wait a while. Even if 18.1 will be released I will wait till opengapps are available. Because I like the different packages they have and I need some google functions.
How would I do that? I’ve just looked into the archive that can be downloaded for manual FairphoneOS install over here and it does not look like I would be able to do a partial manual flash using these files. At least not for all the partitions you mentioned here
At least some of the partitions are either not present or in a format that I don’t know how to handle.
Technically speaking the archive I downloaded isn’t an OTA after all so where would I find the actual OTAs that are shipped to FP3s?
I would be interested in creating either a script that would update said partitions ore create a flashable zip to do so. Would that theoretically be possible?
First of all, please note that the recent LineageOS OTA zip files contain all the partition images and install these automatically. You might not need to do anything manual at all.
Second, the FairphoneOS zip files do contain all the partition images as well, but with different file names and a mapping to translate the file names into partition labels. See the file partition.txt included in FP3-REL-Q-3.A.0101-20210420.163631-user-fastbootimag.zip as an example.
Hi there
I have been using LineageOS for years on a Wileyfox Swift (codename: crackling).
As I remember, the LOS camera app on the Wileyfox had a built-in QR code reader.
I can’t find this feature on my FP3 with LOS, so I was wondering if it would be possible to integrate? This would come in handy for restaurant visits in corona time, where one has to registrate
Perhaps, you can simply use Firefox which comes with a built-in QR code reader (you just have to tap on to the address bar and a “scan” button will appear).
Most likely, they are using the Qualcomm Snap Camera app, which has QR reading according to this. There were attempts to use this app for LineageOS on FP3 as well, but no stable performance until now.
As there were also some attacks via qr codes I’m using a standalone qr reader from f-droid, to not just land on some website or whatever…
