Hi
There are numerous topics/posts by Fp4 users
and
- you can degoogle the FP4 manually via ADB no root or
- install /e/
Hi
and
Probably not. The iPhone (I assume you got a new one?) is only two years old, so you should probably keep it longer ![]()
Apart from that I’m sad to read that you retired your FP2 for some screen issues where you could easily have exchanged the screen. And that there were some software glitches that could have been fixed with some effort. At least these software issues were caused by the possibility to use a Google-free OS. Your iPhone probably doesn’t allow you to break free from the Apple environment. So by taking more freedom there’s also responsibility connected to that (e.g. take more care of your software than with everything in a very much integrated environment) and that will most likely not change with the FP4 if you want to avoid the “convenience solution” (for legitimate reasons).
I’ve been using my FP2 every day for 5 years. It’s still running fine except lately it’s been freezing and saying System UI isn’t responding but other than that I’ve had no problems.
I don’t have an exact date for when I got my FP2, but it was some time in January 2017. So mine too is 5 years and counting. Hoping it will make to 8.
Its predecessor, a faithful Sony Ericsson W350i, has just reached 13 years of age. It is going to outlive the network that it runs on, as that closes end of this month. Still be my quick camera (1MP!) and alarm clock.
Sadly, it's not coming. With prospect of emigration, I went smart (@Fairphone) in Jan. But still using #Luddyphone day to day.
— Ian Garman 🇸🇪 🏴 🏴 (@bestdeadends) February 11, 2017
Nothing much changed, apart from the four years part … it’s five years now.
I ordered my FP2 in August of 2017 and received it by the end of October that same year. I switched to it as my daily dirver and only mobile phone in July 2018 after flashing SailfishOS on it. For Christmas of 2021 I got the camera upgrade, a ‘new’ (used) bottom module (as a spare since they went out of stock) and a brand new battery (not desperately required at this point but nice to have while at it). Switched the bottom module to make sure it works and started using the new camera. In July 2022, after four years of daily use I finally swapped out the battery for the new one before going on vacation just to loose my phone on said trip.
I guess it goes without saying that I ordered a ‘new’ (used, obviously) FP2 before even returning home. It arrived before my replacement SIM card giving me just enough time to flash it with SailfishOS and install all apps I need. My ‘new’ FP2 has some reboot issues (I knew that when I bought it, though I had hoped they would disappear with the OS switch) and I have two old batteries instead of a new one but I am still happy with it. I doubt I’ll buy the camera upgrade again - I just don’t take that many (important) pictures with my phone - but at least I still have a spare bottom module in case my mic goes silent. Not sure what I would do once it dies for good. Maybe a used FP3+ if @mal has a working Sailfish port of it.
Lack of 3.5 audio jack is a big downer of the FP4 and FP5 likely won’t support any OS that I’d feel comfortable with for quite some time. Let me know if you have suggestions. I hope I won’t have to think about it for some years to come. ![]()
Bought my FP2 in June 2018, and after testing all applicable free OS’s on it I had only once to purchase a new battery for it. Running UB-Ports on it now. Everything works fine.
I’ll only buy a new phone when governments and banks decide to make their essential applications for identification an payments available for all mobile operating systems including GNU/Linux Mobile.
