Do you mean you didn’t have the problem before the update?
As this topic is a ‘microphone’ issue, which is rather broad, would you
clarify the version numbers before and after the update,
the network you are using,
does it happen to all your contacts, as it may be related to their network
is it happening only via wifi calling with What’s app or other instances
What network are you on?
The only issues I have are irregular and consist of two issues only during wifi calling via WhatsApp, I sometimes get low volume early in the call which resolves itself and less frequently echo.
I have this issue since the last system update - colleagues who could hear me fine on Zoom before now struggle. None of those settings have changed and Zoom is up to date.
Have the same problem - not with Zoom and WhatsApp (I don’t use them), but with Jitsi.
I just realized that the problems described in this thread could be the same as I mentioned in a seperate thread. So I doubled the threads about one and the same problem; sorry for that.
But I guess it clearly shows that microphones are really not working properly for some apps since the update.
Hello everyone,
I also received a new FP3+ and had the same problem. I have the last FP3+ android 10 update… It is a problem on Signal, WhatsApp, kMeet, Google Meet, etc. So this should come from the microphone itself.
Has anyone solved this problem somewhere in the forum?
Thanks!
Your post isn’t clear. You say the microphone isn’t working properly but how do you know? Do you mean that the recipient of you call can’t hear you very well, that is different.
To be clear, do you have the 0084 update which was designed to fix the audio on phone calls not WhatsApp. This is an ongoing issue and is not a microphone problem per se. You can check the microphone via the phone call keypad.
Dial *#*#66#*#* >Service tests > Test single > Microphone
There are two mics and the second one is the noise cancelling mic and is quite.
It seems that often, for some people, when using WhatsApp, a previous demand for the main Microphone 1 is not released and so only the top microphone for noise cancelling is being used resulting in a very low volume at the recipients end.
As I said this seems due to other apps not letting control of the main mic so you may want to disable other apps that may intertere, ~ I removed a recording app ~ and reboot the phone. Try a WhatsApp call again before you re-enable other apps and you main find the issue.
This clearly shouldn’t happen and Fairphone will need a few requests from users to take it an important issue to resolve software wise.
@anon9989719 thanks for your reply and sorry if my post is not very clear.
As I had exactly the same problem as the others with the microphone i.e. once the speaker is activated on a video call (WhatsApp, Signal, Google Meet, or any other Zoom type application), the contact person can hear oneself talking with a more or less loud echo depending on the day… Also, on WhatsApp and Signal and sometimes on Google Meet, they don’t hear me loud enough.
I’ll try your suggestion but honestly it’s not acceptable to tinker with the recording app and release the mic even if one has a “Fair” and sustainable phone…
So yes, I’m sure it’s either a microphone filter issue, a hardware issue or maybe a software issue that should have been fixed by now.
@anon9989719 I also tried out the service tests on mic 1 and 2. It seems to work properly. Maybe this is due to a bluetooth speaker connection as it was detailed in the following post:
As we said together, they should notice this problem and fix it with a new update…
Any idea if the next Upgrade will solve the problem ?? I have still very bad microphone quality by whatsapp or video call ( free hand). When will be the next update available ???
There are updates every 4 or 5 weeks at the earliest but I see no mention of this issue being taken up. It may well be that you could ask for official support to make this a priority issue. support@fairphone.com
