Juhuu, that worked already… afterwards I entered TWRP I installed the LOS-update right away, but what is the problem? Is it a known issue? Do I need to change something?
It is a known issue, that with the new camera module installed, you can’t boot to recovery from within Android. Workaround is to press Vol + until it (hopefully soon) get’s fixed.
I don’t have the new camera module and I have the same issue.
Are you sure? If you got a brand new Fairphone 2 in October 2017 …
… you should have the new camera …
Did you install an old one afterwards?
The new module most notably has a white “separator” between the lens and the flash, the old module didn’t have that … here’s a picture of the two modules.
You’re right, I do have a new module and I did not even know it (I thought it was upgrade only). Sorry for the confusion.
Hi, FP-Community.
Sry if i do a re-post or asking a question already solved, but i have a problem with twrp 3.2.3.0 an LineageOS 15.1 (Build 20181022).
I have installed twrp 3.2.3.0 and LOS 15.1 today and encrypted my FP2 in LOS. I can reboot or shutdown/start my FP2 and enter my encryption key. Normal boot, normal function and login in LOS. So far so good.
But when i want to boot into twrp-recovery (manual or enhanced restart-menu in LOS) i can not enter the encryption key. This error appears:
Updating partition details…
…done
Unable to mount storage
Full SELinux support is present.
Failed to decrypt data.
Im sure, ive typed the correct code, the key works by starting into LOS.
Does anyone have a solution for this situation or more information…?
Greez BIOHAZARD
That’s an issue with TWRP, see https://github.com/omnirom/android_bootable_recovery/issues/224
If you want a fix now, install one of Fairphone’s OSes (Android 6 currently), set a lock screen pin/password/pattern, then encrypt the phone, then install TWRP 3.2.3-0 and wipe everything (only wipe, no format!), then install LineageOS 15.1 . That way TWRP can still access the encrypted data partition, and LineageOS 15.1 is fine with it, too.
I installed LineageOS 15.1 for microG on prior encryption myself, works like intended.
Thanks AnotherElk, seems to be a little tricky for me…
I have tested de update to the lastest LOS-Build (20181029) with encrypted phone and all worked perfectly. So its only the access to the encrypted partition in twrp, that doesn`t work. And i will need this access only, if i have a problem with my phone/LOS, to wipe, format or something…
By the way, the same twrp works perfectly on my samsung s7 (also encripted). Seems to be only a problem of a few twrp-recoverys / phones, including the fairphone 2…
I will wait for a (hopefully fast) solution/update of twrp.
Hey.
Will this help us to decrypt our FP2 in TWRP?
I’m no developer either … so, perhaps you really have found something here.
I only saw at first glance that the fix seemed to be for bacon (= OnePlus One), and since fixes for several devices exist already and didn’t translate over to the Fairphone 2 as per the statement of @z3ntu (the maintainer of Fairphone 2 TWRP) in the other topic, I thought I’d link to his statement here, too.
