LineageOS 15.1 encryption:
TWRP 3.2.2-0 and TWRP 3.2.1-0 detect there is encryption, but fail to decrypt even with the correct password, or with a default password (?) if Screen Lock was set to “None” before encrypting.
Automatically installing updates from the LineageOS 14.1 Updater:
TWRP 3.2.2-0 doesn’t ask for the decryption password anymore when just installing OTA updates, now instead presenting the initial “Keep Read Only” prompt first, afterwards not doing the intended automatic install regardless of the user’s choice in this screen.
TWRP 3.2.1-0 worked in this case before, and still should (just needs confirmation now).
So everything basically still works on 14.1 except that this prompt is annoying? Now I understood the message. Will report upstream.
EDIT: Use https://paste.omnirom.org/ and upload /tmp/recovery.log and the output of dmesg - the issue template wants this
For the 14.1 stuff I can do the logs when I’m back on 14.1.
As for 15.1 …
The few lines listed there under ADDITIONAL INFORMATION are not the recovery.log, but the TWRP console (?) output you can view with the button at the bottom right.
For Screen Lock in LineageOS 15.1 set to “None” it reads:
Failed to decrypt data.
Unable to decrypt with default password. You may need to perform a Format Data.
Updating partition details...
...done
Unable to mount storage
Full SELinux support is present.
At this point TWRP prompts for a decryption password, but there is none. Every attempt to enter one adds the following line to the output:
For Screen Lock set to an actual lock (pattern/ PIN/ password) it reads
...done
At this point TWRP prompts for the decryption pattern/ password (TWRP doesn’t distinguish between PIN and password with this prompt, worked with PINs nonetheless in the past).
Every attempt to decrypt with the pattern/ PIN/ password given by the user adds the following line to the output:
recovery.log for Screen Lock set to “None” … Edit: is on GitHub.
recovery.log for Screen Lock set to an actual lock … Edit: is on GitHub.
I noticed TWRP 3.2.1-0 also doesn’t automatically install OTA updates if it has to present the “Keep Read Only” prompt first.
So this prompt seems to break the OTA installation, encrypted data “only” triggers the prompt.
Yes.
And if you want to have the automatic install feature working, boot into TWRP 3.2.1-0 after installing it and enable “Never show this screen during boot again” at the Keep Read Only prompt.
After updating to the lastest LOS version, I can confirm that the problem must be included in the last update. With TWRP 3.2.1-0 the update went like a charm.
I’m not sure if it belongs in this topic, but I have the problem that I can’t enter anymore the recovery mode.
Last week I did the upgrade to LOS 15.1 and wanted to update to this weeks update of LOS today, but couldn’t install anything because it seems like I can’t enter TWRP anymore? Afterwards the failed update, my FP2 simply rebooted instead of enter the recovery mode, so I tried to reboot into recovery without the LOS updater app, but even this didn’t work.
So I’m not sure what is wrong? Do I need to reflash TWRP or did I brick something?
In LOS everything seems to work, at least I didn’t imagine anything wrong.
before the update to 15.1 I installed the latest version of TWRP.
Please confirm … if you press Vol + all the way through rebooting (from the moment the screen goes blank to the moment TWRP appears) … this doesn’t work?
If in doubt, you can do this anytime.
Well, there’s always booting TWRP without flashing it …
the guide to boot into recovery without flashing doesn’t work for me, because similar to @bastoGrande my phone after flashing last weeks’ LOS 15.1 can now only reboot into OS.
Any adb reboot recovery or adb reboot bootloader (or power + Vol+ or power + Vol-) always results into booting OS instead. Even when using the previously installed TWRP app I experience the same problem.
fastboot doesn’t recognize the phone when OS has booted and with adb I cannot flash anything…
