I want to use the Breezy-Weather live-background for the lock and the start screen on my Fairphone 5. This does not work anymore since the upgrade to Android 15. If I configure that in the Breezy-Weather app the live-background is reset to the default Fairphone background after a short time. Also this just worked for the start screen (on Android 14) before the upgrade to Android 15. I can remember that the lock screen background worked on my FP5 on Android 13.
I also tested another live-background, but it was also killed after a short time.
I don’t have a solution for your exact question, but interestingly enough, since the upgrade to Android 15 my custom wallpaper keeps being replaced by the stock one, several times a day.
Not exactly the same issue, but also a matter of background being randomly kicked.
now I had the wallpaper images OK (see other topic, using 2 different images for home and lock screen) I tested setting live wallpaper only for the lock screen. but that disappeared after restart (went back to my image) and after a few minutes the wallpaper went back to the default (blue with patterns)
