My wife bought a Fairphone 5 last year and is also experiencing the (phantom) debris/liquid bug (alert on/off) and the main problem is that apart from charging extremely slowly, the battery also empties very quickly. actually, the situation is so bad, that she can‘t even perform a back-up, as the battery drains so quickly. no new cable, adapter, plug or even the second battery helped. Given that she is quite desperate and would really like to avoid a full factory reset and waiting for weeks for a repair, I wanted to ask:
Does anyone know of potential software hacks? We tried several we saw on the web (switching plane mode on and off quickly, restarting the phone in safe mode), but none worked. Some users suggested empting the usb setting cache, but this appears not to be available in the FP’s android settings. also, stopping the android system app did not help.
Anything we could try (esp. if it resets the usb-warning) would be great, as my wife depends on her phone for several ID-confirmation apps (also for work).
Thank you!!
ps: this is not a great promotion for Fairphone, but from what I read other android phones can have the same issue.
thank you for your reply. the safe mode restart did not change anything and the battery is draining so quickly, you can watch the phone dying. it will now either be a warranty case or she will have to buy another, new phone. what a shame…
The phone was just repaired by Cordon Electronics in France and the following two parts got replaced: „FP5_SECONDARY_PCB_BOTTOM_V1“ and „bulk - FP5_USB_C_PORT_V1“. I will report back, when received and hope this does the trick.
Little update: sent it back to the network provider to get it fixed under warranty, and got the phone back saying oxidation was detected, which doesn’t fall under warranty.
I now spent 600 or so on the phone, 150 on a replacement USB port and battery and 200 on a cheap replacement phone while the Fairphone was out for repairs (I actually had to buy 2 as the first one was total rubbish and unusable - my fault). All since February.
And now it looks like I have to buy another proper phone. Won’t be a Fairphone, I can guarantee you that.
Can’t really blame them: a company is essentially just about making as much money as possible, and they’re doing it by pretending to be ecological and ethical, but of course in the end it is all about the bottom line.
While its always an issue when they find red indicators for water ingress… Have you seen Cordons repair quote? Why would thwy have to exchange the core module instead of the bottom PCB as others reported?
So the infamous notification got me too. I’ve been charging my 2-year-old FP5 with always the same charger (Xiaomi 67W QC3) and cable. I know the charger+cable is working 100% because it’s been used to also charge a Redmi Note 12 Pro which shows the speed of charging. For the sake of troubleshooting I tried differente cables and connect to pc - nothing worked, always the same message and no charging. Also did the Service test: FAIL. Contacted support and got the response that “using incompatible chargers and cables, such as Xiaomi’s SuperCharge, can cause permanent damage to the USB-C port.” and I’m really suprised by this because I thought the only issue of using this charger was just maybe charge I bit slower because it is QC3 and not QC4?! Can the USB-C port really be damaged for using a QC3 charger??
The charger info:
POWER ADAPTER | Model: MDY-14-EW | Input: 100-240V~, 50/60Hz, 1.7A | Normal Output: 5V, 3A, 15W | Fast Output: 5-20V, 6.2-3.25A (67W Max) | QC3 symbol
Got this notification using an USB-C to HDMI adapter then unplugging it after use, TV still on, and then plugging a charger fires the “debris” notification.
Reboot solves this.
After some testing, this notification doesn’t come if I shut down the TV first (OLED TV, need to wait the antiburning feature to finish, which can take from 30s to 2mn after turning it off), waiting for the phone to kill the external display connection notification in top bar, then unplug the adapter.
There is no setting to manually trigger the disconnection of the HDMI over USB-C feature, either “brutal” disconnection with phone still having the “display out” notification active or waiting the TV goes to sleep then unplug “safely”.
I think this is a lack in the phone features, not being able to shut down the HDMI over USB-C connection manually, USB-C chip on the phone doesn’t like “brutal” disconnection and nowhere there is user manual that tells this.
However HDMI over USB-C is a very usefull feature.
Please see my reply from Oct 25: the phone was sent in and the mentioned parts got replaced. when we got it back, it showed the „liquid notification“ once more, but since then it works fine again. let‘s hope it stays that way, as wiping a phone and having to set it up anew (incl. online banking apps) is not fun.
I have exact the same problem like many here with my FP5. Tried to replace USB-C-Port first - but no success.
As soon i connect the charger - i get the message “Liquid or debris in the USB port”, when i disconnect the charger - i get the message that anything is ok and i can use USB now. When i connect an USB-C-Stick to the FP5 - it works without any problems… Send it for repair…
