LED problems are a good old Fairphone tradtion scnr
But I don’t think that you will find a solution in this old thread, as long as you don’t have root rights
Hi Paula, for the time being we are monitoring and quantifying any the issues that are reported via the customer support form/calls. The bugtracker we created for FP2 had issues we tested and confirmed. It’s too soon to create such a format for FP3 - and the process in itself might be different this time - with regards to reporting.
As I see in this thread, there are 3 mention off this LED issue and I encourage all to contact customer support with this information.
since Tuesday l‘m a proud owner and user of the FP3 (supplied by Digitec/CH).
Basically everything works fine, except the LED notifications. When charging, the LED (red/green) works. But with mails, WhatsApp messages and other apps nothing happens, even though the settings are made that way.
A support contact form for the Fairphone 3 can currently be found here (just choose Fairphone 3 as your model) …
Official response from the support team:
For the Fairphone 3, the LED options are only dedicated to charging statuses. It is unfortunately not a feature to assign LED colors to notifications or other statuses.
I have trouble to believe that it can’t be link to notifications through software level, and I find this very VERY disappointing…
@NicoM I believe either you or the support member you talked to misunderstood the issue being discussed here. This topic is about LED not working at all for notifications, not about assigning different colors to LED notifications.
Or maybe I’m misunderstanding the support team answer.
I think the answer is pretty clear:
So, it is not a bug to not have LED notifications. It is just not present on FP3.
I never ask the support about how to change color or anything, I just said that I have an issue with my FP3, that on notification I only have sound, and no LED, but LED are functional with battery status.
Really bad news imho.
I think it is indeed you that misunderstood. The support confirms that the LED is not supposed to blink to notify New messages or other notifications.
But what’s the point in having an LED when you can’t use ot for notifications. Always activating the screen to see if there is anything new isn’t that great at all.
Honestly: in this case Fairphone can keep its crap!
They are saying they went through the trouble to put in a LED but then decided to not let it be use for notifications?! That sounds… super weird…
I agree the lack of such feature is a bummer but is it such a huge dealbreaker?
Everyone has their priorities.
That sounds like the software is rushed/ not finished to me.
Should be interesting whether they set up a public bugtracker for the Fairphone 3, too.
It sounds to me like the LED is due to a hardware limitation only able to be used as a charging status. If it were merely a software limitation, the reply would be “we are aware of the issue and will look into it.” The gist of the current quoted reply is WONTFIX.
I could understand a “we’ll fix it when we have time”, but just plain WONTFIX is absolutely bizzare to me. it’s a huge missing standard feature to me.
Also, I don’t see how it could be a hardware limitation if the testing app can turn it on just fine.
Exactly, this is what I repy to the support:
Hello and thank you for this (sad) answer.
If I may, are you really 100% sure? Because these LEDs can be controlled through developper’s options, Service Menu, Services Test, meaning that a software can control them, not only when the battery is charging or low.
So maybe there is still hope that on a next OS upgrade, these LED will be functioning for notifications?
Let see the answer :-/
Yes for me it’s a dealbreaker, because most of the time my phone lays on the table and only this little light tell me to switch it on.
I don’t care for best cpu, camera, display etc, I could deal with the lack of FM radio, but lack of notification light is a show stopper for me.
Anyway I will not decide what to do next this year, so there is still hope.
Having the same issue - no LED notifications. However, reading the reply of the support, what I understand is that there are no LED options assigned to notifications. This does not mean that there are no LED notifications, it only means you cannot change the light colour.
I hope I am right because otherwise this would be a show stopper for me, too. I still can’t believe this could be the case since LED notifications have been a standard feature for many years now.
Nowadays, a color LED isn’t much more expensive than a one color LED. That’s why the whole Chroma hype and hype of putting LEDs in your PC case is kinda ridiculous (as it barely has a function). It is hard to imagine they decided to save costs on such a feature.
