Internet via mobile connection not working after leaving WiFi area
Hi, has anyone experienced this problem: When I leave my Wifi area, and the phone thus disconnects from Wifi, it does not connect to the mobile internet. This seems to happen almost every time I leave my home Wifi. I first noticed this problem after the software update to FP5.UT2L.B.107.20250218 a week or two ago. Switching airplane mode on and off again fixes the problem every time.
More detail: Fairphone 5 with the latest updates, mobile carrier is DNA with 5G enabled. This isn’t the same issue as After leaving wifi there is no mobile data - reboot is necessary (because that one depended on VPN; there’s no VPN on my phone). It could be the same issue as Phone doesn't connect to mobile data after leaving home wifi, and for information, when I check the Developer mode, the switch for “Always keep mobile data active” is on. I don’t want to change developer-only settings without clear guidance from a developer, though.
I have contacted Fairphone support about this (they have a backlog of 16-18 days) and will post here if I find a solution. Thanks.
Hi, I have noticed the exact problem, happened three times for the past couple of days. And I have the exact same mobile carrier as well.
First thought was that it’s because of my phone but just heard that few of my colleagues were having the same issue with DNA (not all of them having Fairphone), so it might be also the mobile carrier side issue.
I’ll drop the DNA helpdesk a message, too. Thanks for the advice!
Edit: I spoke with the DNA helpdesk and technical service - they both think it’s not their problem. I could test if it works with the SIM card in another device, and maybe I will, but it sounds more like a device or settings problem to me.
Same problem, when i drive from home with a map, i fuel my car (so switch off) it does not reconnect again?? I will try the flight mode hack next time. I have a FP5.
No reply from Fairphone customer support yet. The recent system update (FP5.UT2M.B.113.20250319) hasn’t fixed this issue.
Actually, I think this is not related to the Wifi at all because I’ve had the 5G mobile connection disconnect a few times when I was not near my home Wifi (or other "known Wifi"s).
I saw another post that is potentially related (🇬🇧 🇩🇪 No network service 5G problem? FP5 verliert Netz), which prompted me to disable the 5G on the mobile network. I’m testing if that would fix the issue.
A better workaround than switching airplane mode on/off is actually to switch the SIM off/on. (Click on Settings, Network & Internet, then Internet, then the settings icon to the right of the mobile operator name, there “Use SIM” → switch it off, wait a few seconds, switch it on again.) Usually this gets me back online.
Hi there. I’m the writer of the other (english/german) post.
Since I switched to the 4G settings, all works fine. No connection losses since a couple of days now. Looks to me like the problem stands in relation with the 5G settings or the net (frequencies).
It’s not solved, but at least it works like this for the moment.
I actually noticed the same thing.
Thanks for sharing the tip to switch the network from 4G to 5G, I’ll also try that while waiting for the final solution.
I can confirm that this seems to be an issue with 5G mobile, and had nothing to with the wifi. It’s just that you notice there’s something wrong with the 5G when you leave the wifi.
So, the best workaround is to switch the preferred networks to 4G/3G/…, instead of allowing 5G. But I don’t know what’s the problem with the 5G, is it software or is it some faulty phone component?
Still no reply from Fairphone customer service.
Funny enough, after a week with only 4G/3G/…-settings, I switched back to 5G 4 days ago. No problem with losing connection since then! It seems to work just fine again…
Is there any news from Fairphone support regarding this problem? I’m still having this problem, switching to 4G solves the problem of course but it would be great if you can use it also with the 5G :smiley:
Haven’t heard anything from Fairphone yet…
Finally got a reply from Fairphone (and they apologized for the delay). Unfortunately, none of their suggestions below helped in my case. I’ve asked them for further advice. Let’s see what else they will reply next.
Step 1: Update
Make sure to update to the latest software: Android OS 122 (Build number FP5.UT2P.B.122 ) is from June 2025
The release of some updates may be delayed by up to a few weeks. This depends on your country and phone carrier.
Step 2: APN settings
Your APN settings affect how your Fairphone 5 connects with the network. To check if they are causing issues:
  1. Reset your APN settings.
  2. Depending on your network operator, you might need to set your APN settings manually.
Note, you’ll need to do this step separately for each SIM card you’re using, including eSIMs.
Step 3: Try different connection protocols
If the issues persist, the phone might be trying to connect using a network protocol that is not supported by your contract.
  1. Go to SettingsNetwork & internet → Mobile network → Preferred network type.
  2. Try the available options (their naming can differ based on operator).
  3. Let me know if you get connection and on which protocol it happens.
Step 4: Disable 4G Calling (VoLTE) and Wi-Fi calling
These technologies are used for high quality phone calls, however sometimes they can have a negative effect on network connectivity.
  1. Go to Settings → Network & internet → SIMs (select the SIM you want to configure) and scroll down.
  2. If 4G Calling (VoLTE) or Wi-Fi calling (VoWi-Fi) are listed in your options, disable them and retry.
  • These settings may be called differently and might be hidden depending on your operator’s wishes. If they are hidden for you, switch your preferred network type to 2G or 3G if possible.
Test again. If the issue remains, continue with the next step.
Step 5: Set preferred SIM card for mobile data
Your Fairphone 5 uses the default SIM card for mobile data. So, if you’re using two SIM cards, you will need to set your preferences:
  1. Go to SettingsNetwork and Internet → tap on one of the 2 SIM cards.
  2. Select Data preference. Usually, SIM card 1 is selected by default, but you can change it in these settings for the one you prefer.
  3. Check if the issue is gone.
You can read this support article for more information on this.
Step 6: Try a couple of different SIM cards
Borrow a couple of SIM cards from family members or friends and test them on your device. It’s best if you try with at least one card from the same provider and one from a different provider. Make sure to go through all the steps you already tried with your own SIM card.
If you get a data connection, something is wrong with either your SIM card or your contract/data plan. Please, contact your provider if that’s the case.
Does your SIM card work in another phone? Let me know.
Step 7: Check your network operator
Make sure your Fairphone 5 connects to the right network:
  2. Disable the option Automatically select network. The phone will scan for all available operators. This might take some time.
  3. Manually select your operator (provider).
  4. Check if the issue is gone.
Get in touch with your network operator and ask if there are any issues on their network in your area (local antenna might be broken or eSIM services might be down).
Step 8: Additional settings (5G, eSIM)
If you only have issues connecting to 5G mobile data:
  1. Make sure you’ve enabled 5G in the settings from Step 3.
  2. Power saving options often turn 5G off. Go to SettingsBattery & ChargingBattery Saver and make sure that it’s turned off.
If you have issues connecting to mobile data via an eSIM card:
  1. Reinstall your eSIM card.
  2. If you’re using a dual SIM setup, remove the other SIM card, test only the eSIM. Your provider(s) must support a feature called Dual SIM with an eSIM and this is an easy way to check if it works. If removing the physical SIM fixes your issue, contact the provider(s) for both SIMs and ask if this is something they can support you with.
Step 9: Safe Mode
To exclude the possibility of a corrupted third-party software:
  1. Reboot your Fairphone 5 in Safe mode.
  2. Disable Airplane mode and make sure your mobile data is enabled.
  3. Check if you have mobile data while in Safe mode.
In Safe Mode, downloaded apps are temporarily disabled to help you identify the cause of an issue. In our article on Safe Mode, go through the steps and make sure to read the Important notes. You can easily exit Safe Mode by restarting the phone.
