As it was previously announced, all icons have disappeared after the update.
But that’s actually not my problem. I have set back all icons to their original locations, and then started my Fairphone new, to see if everything works. After the restart, almost all icons were gone. Only those that were originally installed on the Fairphone are still there (like the browser, camera, …). I have put the apps several times again to the place where I wanted them, but to no avail: Once you reboot, all are gone again.
Ok, this is the problem. Apps not being stored on the SD are still on the home screen after restart. But that’s not how I want to handle this. Is there any other solution? Is this a bug you can fix sooner or later?
I used to have this exact problem with my HTC phone - I’m not sure why the update would have caused this change, but what you could do is move the apps onto internal memory. If the reason for you not doing this is that you’re still running your FP1 without the integrated storage solution and you’ve run of space.
If that’s the case, I think the better solution is to run the update (but I believe you have to be running v1.6 to run it!)
Marco can probably give you a more official answer
I’m not sure but what could have happened is that a fix in this upgrade to enable ringtones on your SD card on a FP with the storage upgrade somehow impacted this situation again. I am not sure.
@Jonas_Pilatus and @sandy did you already perform the storage upgrade? The nasty thing is that this is only possible from 1.6 - so to do it you would have to downgrade to 1.6. You also need proper backup as the storage upgrade will wipe your system.
You could try this way - as it might just fix the issue. But I will also raise it as a bug here and see what we can do about it. If you can let me know what kind of storage (two partitions or unified) you have that would really help me out!
No, I don’t think that I’ve already perform the storage update… How do I know? (But I upgraded every time when there was a new update…)
So, to be clear, I should downgrade to 1.6, then do the storage update (what is this, btw? O:-)), which will wipe my system (sorry, but what does this mean? Is everything gone then?), and upgrade again to 1.8?
I think, I have two partitions (internal memory and phone memory) and the SD card. But I can only use the internal memory of 1 GB for my apps…
Thanks!
Edit: Actually I did not know anything about this storage upgrade… It would have been nice to know it in advance before upgrading to 1.8. AND - I did not get this “e-mail” where the new update to 1.8 was announced, because my fairphone was a gift.
@Marco@anon90052001:
I also emphase the sillyness, that to apply the “UnfiedStorageUpdate” (USU) only can be done from V1.6! What the hell ???
I did not installed the USU up to now, because I did not want to loose all my data/apps and spent hours to re-set all my stuff + At the moment I don’t need it
I hoped that I could wait until a better way of applying the USU is available by FP
But now you are coming with the information (quite too late for some), that if I want to apply the USU later, I first have to downgrade to 1.6, make USU, upgrade to current version AND have to re-set all my stuff ??
practically this means for me I can/will not update the OS to 1.8+, before doing the USU, which I don’t want to make before neccassary…With this, you cancelled my out of using updates. Thanks.
Sorry…regardless what the technical reason is behind this ---- in my opinion this procedure is NOT acceptable!
Unfortunately FP now has supported my view, that I hate applying Updates! “Never change a running system” is since than my slogan after early microsoft days, where updates everytime crashed my system and wasted hours of time to have it like before
@Sandy: Yes, if you apply the UnifiedStorageUpdate ALL your installed APPS and their settings as well as pics, contacts etc. will be deleted. Only way to get back is to make backups and/or reinstall the apps (either by backups or by GooglePlaystore, which rememberes your installed apps, if I am right)
I have the same problem i.e. app icons disappear again after each restart. I have NO SD card, I upgraded from 1.6 to 1.8, re-installed Google and have not applied the 1.6 UnfiedStorageUpdate previously.
Sorry, I don’t understand that. You deliever an update, which kills every restart the configuration of the icons? Are you for real? I expect working and tested updates. I don’t have the time to read 100 pages in forums since I found what I have to do.
And fairphone restarts so often by itself, so I’m very stressed out. That’s buggy.
I expect, that you deliever soon a fix or you write an instruction step by step for that (via email.)
yours!
Thanks, for writing this post: It’s more than not acceptable. I made the update, and now, I’m stressed out about the time it will take to undo it. It’s a wasting time and I expect that fairphone will fix it as soon as possible!
