Re-opening this topic as after the previous and the current update ( FP4.SP2J.B.086.20230807) I noticed that it took long to find a fix, GPS test had very few sattelites only and the time is incorrect and only after refreshing time data and PSDS and rebooting its fixed
Yep, can confirm. I thought I was going crazy.
I got around this bug by using GPSTest and clearing assist data, injecting time and psds data. I then turned the phone off, removed battery and SIM.
On reboot, without SIM, GPS time was accurate again.
Turned it off and replaced the SIM and it’s still accurate.
It doesn’t help find the bug itself but it might resolve the bug for others. With luck the gps time will remain accurate.
Yeah, that usually fixes it. And it’s great that there’s actually a simple workaround like that. But the thing is, it shouldn’t happen in the first place.
I have never had this problem with any other phone.
I just had to reboot, no need to take out the SiM or are you saying this is a permanent fix, i.e. it survives updates?
No idea of permanence. I just chucked all the advice,saw someone say that support claimed the SIM was to blame.
One would hope it survives the updates!
I can confirm that I’m currently also getting a wrong time: Jan 26, 2004 currently.
Just asking the obvious, you are outside when you test the gps?
it doesnt matter really, there is something broken… the fix isnt staying after this update the time is repeatedly wrong… so to use navigation, plan ahead and be prepared a reboot is needed before it works…
In my case the time might be wrong, but neither do I lose the fix nor did I experience any problems with navigation so far.
Yes, it happens outside.
After the A13 upgrade I had a fix withing seconds, and correct date and time. Maybe finally fixed.
I haven’t experienced this problem since the Android 13 update either. I would wait a while longer before marking this as solved (again), but it’s possible that it’s finally fixed.
This issue is definitely NOT fixed! If anything, the issue got worse for me.
Unfortunately I also have to say that it is NOT fixed with A13. The date rollover still happens, and the fix is slow. Compared with my wife’s Motorola One Vision (5 years old) also the signal strength in the same situation seems to be weak. Her smartphone keeps the track with google maps even in the middle of the car while my FP4 has to be kept close to the windows to get a sufficient signal.
Now my GPS is completely broken. I cannot get a fix after the update to Android13 in no location based applications. Location on/off does not help. Device on/off does not help.
What else could I try?
(update: will try “clear assist data” with GPSTest like suggested earlier)
I’m pretty happy with the Fairphone hardware, the future perspective, the guarantee and repairability etc, but in the past and now the software quality is bad (and kind of unstable) and the commercial Email support I get is unprofessional and embarrassing.
