When you lost the settings comlpetely your issue is a different one.
Does this update fix the issue for you?
I just updated but I am still experiencing the issue of the fingerprint just doing nothing, even though the debug menu says it’s working correctly.
At this point not even toggling Find my Phone changes that.
Hi @Sandruin,
Welkom to the Fairphone community form.
The fingerprint scanner dit work for my before and after FP5.UT2L.B.107.20250218.
can you clarify what the problem is that you are facing?
you can try walking true those staps:
Set up face and fingerprint unlock – Support
if still not work you can walk true this instruction:
Troubleshoot the Fingerprint Sensor – Support
please share if the problem is not solved.
Can you tell us at which step the instructions no longer matched your situation?
Greetings
Tom
4 posts were merged into an existing topic: Fingerprint stopped working, setting completely gone
I’m also experiencing this issue, but for me it only appeared after upgrading to FP5.UT2M.B.113.20250319
