FP5 charging issues
My FP5 is having charging issues, I need to restart the device several times until it starts to charge.
It shows it’s charging but it’s not. It already happened several times and it messed up my whole day. I used to put my phone to charge before leaving the house, and when I grabbed it I always saw it didn’t charge at all in the past hour.
Tried different cables, different chargers, cleaned the ports, etc. It won’t charge until I have restarted several times. This is very annoying.
I posted on Reddit too and I see others are having the same issue too.
Is this a known issue already? Are there any fixes coming for it? Is there a way to report it to the developers and send logs if needed? Thanks!
https://www.reddit.com/r/fairphone/comments/1j0y30t/fp5_not_charging_what_to_do/
I dont think so
You have to contact support, infos here contactsupport
Yeah this happens to me too, occasionally. Normally when using the official Fairphone charger.
Just gets to some random % and then stops charging (but it says it IS charging). Normally taking it off charge and putting it back on again gets it going again.
The FP5, in my experience has been a flaming bin fire.
Today it started a new “bug”. Put it on charge and it boot looped until I took it off.
In my case, I have to restart it (sometimes even several times) until it charges again. If I plug it out and then back again it does nothing, I tried a dozen times.
The charger is good and so is the cable.
The most annoying thing as you said, is that IT SHOWS THAT IS CHARGING, but is actually not. So now I constantly live with anxiety and check the phone if it actually charges, so I won’t leave the house again with an empty battery.
i charge FP5 over 2 years using:
  • some qc3 wall charger with USB-A
  • some dumb 5V/2A wall charger with USB-A
  • lenovo notebook USB-C 65W adapter
  • powerbank with USB-A or USB-C
  • car/cigarette charger with USB-C (PD3.0 65W)
and never have problem with not charging, not (non-manually) stoping before 100%, reboot when connect cable, nothing…
but not all (be correct not any :wink: charge with max supported 30W…
maximum is ~24W using one lenovo notebook (travel) adapter (but not other/older (clasic) model) and with car charger, others charge ~8-12W, so maybe be problem with official charger or non-official which charge at 30W?
Get it RMA’d before the warranty runs out. If it already has might be time to sell it and buy something else. I wouldn’t even want to throw parts at something like that because it “might” be the battery, or the USB-C board, but its probably the main board which can’t be changed.
IF you are in warrenty, RMA it. One of my biggest regrets with mine was not pushing harder for an RMA
I have noticed the same issue since applying the security update for march… If this is software related that could be the culprit.
Well mine actually started doing it somewhere in February or end of January… but yeah my overall guess is that it’s a software issue somewhere…
Mine started doing this sometimes as well, i think it started happening after I removed the battery to swap the SD card. Only having issues with standard 5 volt chargers so far.
similar issue: the phone (FP5) shows it’s charging with the charger/cable combination i regularily use, but it is not. Sometimes, changing the cable helps, sometimes changing the charger. a (single) reboot does not help (haven’t tried several reboots yet).
The chargers/cables that won’t charge the phone, do charge other phones - so i would exclude the charger/cable as cause.
Happened the first time this week and today the second time.
Android 14, BUild FP5.UT2M.B.113.20250319
I put aside the FP charger and cable that I usually use, and used the charger and cable from my old phone for a week. Surprisingly, it worked fine every time. Now I went back to the FP charger and cable, and at least 1 in 5 times, I have the same issue. It shows it’s charging, but it’s not, or charging extremely slow, like 1% in half an hour. This is really weird, so now I’m pretty sure the FP charger and cable are somehow the problem. The funny thing is that when this happens (that it’s not charging correctly or at all), it always starts with the FP charger and cable, and when changing from the FP charger and cable to another charger and cable, it still won’t charge until I restart the phone. But it always happens first with the FP charger and cable, and never with another one. I don’t even know how to demonstrate this issue to support. If there could be some logs that show all of this info. And once again, I cleaned all ports, on the phone, and on the charger too, they are perfectly clean. The FP charger is relatively new (less than half a year old). My other charger and cable are more than 6 years old.
Update from me, I just ordered a new charge port, it’s getting really bad on mine. Happens with dozens of combinations of chargers and cables at multiple different households and even in the car. And now even on my 100W laptop charger that used to work flawlessly with it. I checked with a little USB meter and it charges at ~65 mA on my 5V3A per port charger that dozens of other devices have 0 issues with. Cleaning the port also hasn’t helped.
I really hope the new port will fix it, otherwise this is strike 3 with the FP5 and my FP journey will come to an end, not intending to spend more money on parts and I cannot wait half a year for an RMA because I cannot be without a phone because of work.
I can also confirm this issue.
What do you think is the issue on your side? With the FP charger/cable? Hardware issue, maybe the USB port or battery? Or do you think it’s a software issue?
Update from my side, the new charging port fixed it!
I also found a neat application that can show in the status bar how much power the device is currently using, made it super easy to spot if it wasn’t charging when the watt value stayed positive:
Thanks for the update and for the app suggestion, will try it.
I also got an update from support after months of waiting, they asked me to do a bunch of tests and send back a lot of stuff, I did. And now they are telling me to send my phone in for repairs. But they won’t tell me what the issue is. I thought I could fix my phone in cases like these, and they would just provide the parts. Anyway, I told them I am currently unable to send it in as it’s also my work phone too, and I don’t currently have another one. I will get another phone in the future when I can, and send my FP5 in for repairs.
How should they without sending it for diagnostics?
Hi - I am having the same issue, and have emailed support with (so far) no response. Most of the time, my phone won’t charge easily through the charging port (I can manually charge the battery on a charger).
Restarting doesn’t seem to help, but I have found that cleaning the (spotless) charging port with isopropyl alcohol will trigger charging sometimes - I have no idea why that is.
According to the phone self-test, the charging current varies wildly - from 1000mA to -75. The cable and charger are high quality and work fine for multiple other devices. The problem persists irrespective of whether the phone is set to Eco or Fast charging.
Has anyone at all got any ideas, or do I just buy another charging port and hope it works better>?
R
