My Fairphone 4 is on the B.079 build. It says that the system is up to date when I manually check for updates (settings/system/Sytem update) even though it seems like B.086 and B.089 have been released. I tried on cellular, wifi, while charging (>90% battery) or unplugged.
Is it normal or is there a way to force the update in some way?
Sometimes updates are delayed with some networks (hereās a recent example). Perhaps thatās the case here.
I guess your Support request included your network/carrier? If it didnāt, you can still add information to your request, Support usually only works Mo-Fr anyway.
Then you could have problems with the other SIM cardā¦
The networks donāt need to talk to each other. It would be enough to implement a rule in Android indicating that an update is offered if and only if validated by the two networks.
As already stated updates are sometimes delayed for certain operators.
If you indicate your country and operator we can maybe compare your experience with those of others.
As a rule I would advise against trying to force the update, unless advised to do so by official support.
Ah! I didnāt think about that. Iām on Voo (which uses the Orange network) in Belgium. but I bought the Fairphone directly from Fairphone, not through my carrier.
Support asked me to use another SIM to update.
I had a spare O2 SIM lying around that I use sometimes in my mobile hotspot. I inserted it and checked for updates again. It worked!
Whatās confusing to me is that my Aldi Talk sim and my O2 Sim both use the same operator but still only one of them gave me an update
Iām also stuck on B.079
Provider is āYesssā, using the āA1ā network, Austria.
So many security issues not fixed
The Samsung phone of my wife gets updates every month.
I cannot imagine, that the service provider is the reason to not getting updates.
ĀÆā \ā (ā °ā _ā oā )ā /ā ĀÆ
