This is a collection of guides for customising Fairphone OS on FP4.
You can link to it with the unique tag #fp4guides.
It is a #wiki post, you can edit it by clicking the green pencil icon in the bottom left corner go improve or modifiy it.
Check out the Fairphone Forum Dictionary (#dictionary) for explanations of certain words.
Bootloader
Unlock bootloader
Unlocking the bootloader will erase all your data.
Follow the instructions here: fairphone.com - FP4. Manage the bootloader.
Short version
- Get your bootloader unlocking code here:
fairphone.com - Bootloader Unlocking Code for Fairphone 4 - Enable USB-Debugging
- Reboot to fastboot mode with
adb reboot bootloader. - Unlock the bootloader with
fastboot flashing unlock.
Root
Custom recovery
Alternative app stores
F-Droid
Download from f-droid.org.
If your FP is rooted, you can install the Magisk module F-Droid Privileged Extension from within Magisk to let F-Droid install, update and remove applications on its own.
Aurora Store
Download from auroraoss.com or F-Droid.
If your FP is rooted, you can install the install Magisk module AuroraServices from within Magisk to let Aurora Store install, update and remove applications on its own.
Debloat
Alternative apps
Open Source apps
- F-Droid → Search for category of app
- Privacy Guides → Software
AlternativeTo → Search for proprietary app to replace and set
Platforms -> AndroidandLicense -> Open Source - Kuketz IT-Security Blog
Camera
Forum discussion about different camera apps
Google Camera
Forum topic
Download from GCam Hub and take the Snapcam version.
Try this workaround if you have Google Photos disabled.
System tweaks
Hide Google search bar
You can’t disable the search bar in the default launcher Quickstep,
but you can install another launcher which doesn’t contain the search bar and set it as default.
For example, Lawnchair from the IzzyOnDroid F-Droid Repository.
Set hidden options in Android
Try SystemUI Tuner (Play Store) to do things like showing clock seconds or hiding the VPN icon.
