Just got Android 10 on my FP3. Will try with that any time soon. I just realized I never tried with cable. As I recall Android Auto uses Bluetooth for audio, right? @HMZ What car do you try to connect your FP3 to?
Itās a Ford C-Max. But actually, it doesnāt really work with USB cable, just the Android Auto display will show up for some seconds. Then the car system will ask for a parallel Bluetooth connection, which cannot be established. Iām curious if it will work with the latest update.
I have good news. It works with Android 10!
I installed it right now and immediately testet it.
I think thereās a big chance that the update solves the Problem for all of you.
It worked for me, too. Seems like Android 10 did the trick.
Yippie!
Thatās great news! The only thing missing is the Android 10 update. Still doesnāt show up for me⦠
The update Android 10 did it for me aswell. I have a Ford Tourneo and paired it today after the update for the first time with my Fairphone 3.
You have seen the post, by @formerFP.Com.Manager, that the update availability differs by network providers.
So, if you have another SIM card available from another provider, switching cards (just for the update) could do the trick.
Edit:
Typo corrected.
I donāt have a second SIM card, but Iāve tried it without any SIM card today - still no update.
Maybe some friend or relative; if you want the update now?
Without SIM wonāt work, as you have no network access.
Well, I have wifiā¦
Thatās not enough.
Yout have to insert a sim card from a different provider in order to get the update.
That at least was the case with vodafone within the last monthsā¦
But - as far as I understand it - the normal update process is distributed by the network providers to customers of that network. And the SIM is a kind of identifier/key.
SIM plus phone identify you as someone eligible for the update
WiFi will not help, as it lacks the key.
Android 10 did the trick. Bluetooth connection to Sync 3 on Ford Ranger finally established
I can confirm that it now works with Android 10
ā¦at the cost of noumerous other Bugs.
