Fairphone 4 "locked in fastboot mode"
Hello all,
I have installed my Fairphone 4 according to these instructions.
Unfortunately, the phone always restarted after that. I was able to go into recovery mode once from /e/ and do a wipe.
Now I can not do anything on the phone. I only get into the fastboot screen.
The message is “DEVICE STATE - locked”.
Whether I select “Restart bootloader” or “Recovery Mode”, it always reboots into this mode.
What can I do now?
The phone is just 10 days old. :frowning:
Regards
Andy
Welcome to the forum :wave:
A bit more information would be helpful to get this fixed.
  • What was your starting point? Was your phone modified before?
  • Which instructions did you follow?
  • Did you see any error messages when you flashed your phone?
That just means your bootloader is locked again. If you followed the instructions provided by /e/, that is expected to happen:
Lock the device with the following command
  • fastboot flashing lock
  • Approve with Voume + then power
Edit:
What happens if you select START? :thinking:
change active slot, that’s all
what do you mean exactly?
Yeah, that’s probably it, should have thought of that before writing an essay :man_facepalming:
$ fastboot getvar current-slot
current-slot: b
$ fastboot --set-active a
Or vice versa (if your current slot is a, change it to b).
Then I get the following error message
Setting current slot to ‘b’ FAILED (remote: 'Slot Change is not allowed in Lock State
You need to unlock the bootloader again:
$ fastboot flashing unlock
Thank you, that was it. :+1:
I have now tested this again, but on startup the /e/ logo appears once and the phone reboots.
I can then only boot in recovery mode from /e/.
E: emulated failed to bind mount /mnt/staging/emulated/media/0 on /storage/emulated: No such file or directory
That sounds like something went wrong while the partitions got flashed.
Instead of trying to debug this, I would suggest just starting the whole installation again from the top.
Try to copy and paste those lines one by one, when you get to that step
3. Flash /e/ with the following commands:
fastboot flash bluetooth_a bluetooth.img
fastboot flash bluetooth_b bluetooth.img
fastboot flash devcfg_a devcfg.img
fastboot erase userdata
fastboot erase metadata
And look for any errors that might come up.
Yes, I have already done the installation twice.
I will try this again.
I have now run the installation again.
Once completely and also test only with the “b” variants, because the phone is in “b” mode.
The only thing that works is the /e/ recovery mode.
In recovery mode I get the following messages
E: Failed to bind mount /mnt/staging/emulated/media/0 to /storage/emulated: No such file or directory
E: recvmsg failed (No buffer space vailable)
E: Open failed: /metadata/ota: No such file or directory
E: Couldn´t mount Metadata
E: [libfs_mgr]Faile to find block devie for partition
Now it worked.
I have switched the phone to “a” mode.
fastboot --set-active=a
After that it worked.
Although I had to set up the phone twice.
Once after the “fastboot flashing lock_critical” and once after the “fastboot flashing lock”.
Hello
Thanks guys, the same problems with A/B and locked fastboot I also had. :face_with_raised_eyebrow:
On the pc nothing , on the laptop (win7) nothing, read a bit here and already it works on the pc :man_dancing:
Good job and thanks a lot :beers: :metal:
Only as a note:
Those people to whom the “fastboot --set-active” and “fastboot flash unlock” commands yield to an error like “is not allowed in Lock State” should continue at this topic Trapped in fastboot mode with locked bootloader and corrupted /e/ OS .
Unfortunately there is no solution for this issue up to now.
Only if they aren’t able to boot their phone normally.
If the phone is still bootable enabling OEM unlocking in Settings → System → Developer options is still enough to get that capability back.
Ok, my statement refers to the title of this topic "Fairphone 4 locked in fastboot mode” (which means the OS and recovery is not bootable anymore) :wink:
Had the same issue driving me mad, tried everything including switching active from a to b and back again.
Finally got things working, I used IMG-e-0.21-r-20220123158735-stable-FP4.zip first but then switched to IMG-e-0.21-r-20220112156786-stable-FP4.zip . The older release now boots :wink:
