Fairphone 3 doesn't turn up but the light/vibration does
I had a water issue with my Fairphone 3 and dried it completely before charging it again. When charging the light turns green white/yellow and eventually green - the battery is warming up like a normal charging.
When I turn it up it vibrates and small light turns up but not the screen. Do you think it is a screen issue or deeper than this? Do you think I might be able to recover it?
Thank you for your help, it has been a long way through already but would like to make it last more :wink:
Perhaps there is a Fairphone Angel in your neighbourhood.
If he/she has a display for a Fairphone 3 you could test if only your display is faulty.
Have you tried calling the phone? If it’s just the display then it should at least ring and then you’ll know if it’s just the display :slightly_smiling_face:
